Wireless
8851 Discussions
Does the AX210 not support AP mode on Linux?
Logankim
In the OpenWrt (Linux 6.6) environment,
the driver and firmware are working fine. (I'm using 89.ucode)
However, AP mode is not working.
Does the AX210 support AP mode?
If it does, what should I do to make it work?
root@OpenWrt:~# lspci
0001:01:00.0 Network controller: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] (rev 1a)
root@OpenWrt:/lib/firmware# dmesg | wifi
root@OpenWrt:/lib/firmware# [ 557.441665] iwlwifi 0001:01:00.0 phy0-ap0: left allmulticast mode
[ 557.442233] iwlwifi 0001:01:00.0 phy0-ap0: left promiscuous mode
[ 557.442881] br-lan: port 5(phy0-ap0) entered disabled state
[ 558.526435] iwlwifi 0001:01:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 558.527000] iwlwifi 0001:01:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 558.527552] iwlwifi 0001:01:00.0: WFPM_AUTH_KEY_0: 0x90
[ 558.528037] iwlwifi 0001:01:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 558.618443] br-lan: port 5(phy0-ap0) entered blocking state
[ 558.618956] br-lan: port 5(phy0-ap0) entered disabled state
[ 558.619504] iwlwifi 0001:01:00.0 phy0-ap0: entered allmulticast mode
[ 558.620259] iwlwifi 0001:01:00.0 phy0-ap0: entered promiscuous mode
JeanetteC_Intel
Hello Logankim,
I will look into this internally for now and provide an update once it's available.
JeanetteC.
JeanetteC_Intel
Hello Logankim,
I am still currently working on this ticket.
However, to answer your questions, yes, the AX210 Wi-Fi card does support the AP mode on Linux, and before we could further assist, kindly share the answers to the following questions:
  1. What kernel version is being used on the system?
  2. What operating system is being used? (What is the flavor of Linux?)
  3. When did it start to happen?
  4. Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
  5. Do you remember if this issue happened after a new OS update or Wireless driver update?
  6. Have you installed any recent software or hardware in your system?
JeanetteC.
JeanetteC_Intel
Hello Logankim,
Let us know if you have any questions.
JeanetteC.
