Wireless
8514 Discussions
Slow download speeds Intel BE200 card
JoyLee
Topology
Firewall---zyxel NWA130BE (((( WIFI 7 win11 laptop with  Intel BE200 wireless card and driver is 23.130.1.1
LAN port test (firewall---pc)
JoyLee
utility log is attached
JoyLee
utility log
Mike_Intel
Hello JoyLee,
  1. What is the complete brand and model of your laptop?
  2. Was it working fine before?
  3. What was the last change made in the system before the issue started?
  4. How is the speed if you are not connected to VPN?
Michael L.
JoyLee
1.
Brand: Dell Latitude 3540
Device name TS-WIFI7-2
Processor 13th Gen Intel(R) Core(TM) i5-1335U 1.30 GHz
Installed RAM 16.0 GB (15.7 GB usable)
System type 64-bit operating system, x64-based processor
Edition Windows 11 Pro
Version 24H2
Installed on ‎5/‎12/‎2025
OS build 26100.4061
Experience Windows Feature Experience Pack 1000.26100.84.0
2. DL never working fine
The DL is low in the begging
3.  No any change
4. not using VPN
Mike_Intel
Hello JoyLee,
Thank you for the update.
I am looking at the default specification of Dell Latitude 3540, Intel BE200 is not the embedded wireless controller. Did you manually install this wireless card on your laptop?
And also, please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
Michael L.
JoyLee
1. Yes, manually install this wireless card on my laptop
2. log attached
Mike_Intel
Hello JoyLee,
For customer's who manually upgrade their or install the Wireless controller on their system, we have this regulatory that you need to follow.
https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html
Kindly contact the manufacturer of your system for further checking and configuration assistance.
Michael L.
Mike_Intel
Hello JoyLee,
Regarding this thread, let me also add that upon further checking, the supported wireless cards according to the DELL manual, which are Intel AX211 and Realtek RTL8852BE. Here's the link: https://dl.dell.com/content/manual35722890-latitude-3540-setup-and-specifications.pdf?language=en-us
For additional troubleshooting, please refer to the following links:
However, it is best to coordinate and contact Dell regarding this issue.
Michael L.
