Wireless
8871 Discussions
Dropping from network / immediate packet loss
lwilh
My issue started on May 27th. I play online games and my computer plays them perfectly, its a iBuypower Valkyrie CZ-17 laptop, with an Intel Centrino N 2230 network card, and I am running Windows 8.1, I use the Wi-Fi connection in my house. I started to experience lag in games. I normally run at around 12-30 ms of lag. I began having upwards of 3k+ as well as frequent disconnections from the games and my home network. I have been trying different fixes that I know of: powercycling hardware, moving locations in the house, re-installing drivers, rolling back the network card driver, etc. nothing seems to work. I have two room mates and their rigs are completely fine, one of theirs is a Mac book and the other is a desktop with a hardline. Neither rig has any issues.
I even tried to use a hardline in my own computer, the strange thing was that my computer didn't even recognize that there was a hardline even after I completely disabled the Wi-Fi. I ran a pathping to one of the game servers and here are the results of that. There is immediate and continuing packet loss.
Tracing route to 12.129.209.68 over a maximum of 30 hops
0 logan-pc [10.0.0.13]
1 10.0.0.1
2 * 10.93.52.1
3 dtr01glryca-tge-0-1-0-3.glry.ca.charter.com [96.34.120.0]
4 dtr03snloca-tge-0-1-0-2.snlo.ca.charter.com [96.34.120.52]
5 bbr01snloca-bue-3.snlo.ca.charter.com [96.34.2.0]
6 4.34.87.145
7 vlan80.csw3.LosAngeles1.Level3.net [4.69.144.190]
8 ae-81-81.ebr1.LosAngeles1.Level3.net [4.69.137.9]
9 ae-6-6.ebr1.Tustin1.Level3.net [4.69.153.222]
10 ae-106-3506.bar2.Tustin1.Level3.net [4.69.158.102]
11 192.205.37.145
12 cr2.la2ca.ip.att.net [12.122.129.106]
13 12.123.132.209
14 12-122-254-230.attens.net [12.122.254.230]
15 206.16.68.50
16 12.129.209.68
Computing statistics for 400 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
5/ 100 = 5% |
1 12ms 6/ 100 = 6% 1/ 100 = 1% 10.0.0.1
0/ 100 = 0% |
2 --- 100/ 100 =100% 95/ 100 = 95% 10.93.52.1
0/ 100 = 0% |
3 17ms 6/ 100 = 6% 1/ 100 = 1% dtr01glryca-tge-0-1-0-3.glry.ca.charter.com [96.34.120.0]
0/ 100 = 0% |
4 25ms 6/ 100 = 6% 1/ 100 = 1% dtr03snloca-tge-0-1-0-2.snlo.ca.charter.com [96.34.120.52]
0/ 100 = 0% |
5 28ms 6/ 100 = 6% 1/ 100 = 1% bbr01snloca-bue-3.snlo.ca.charter.com [96.34.2.0]
0/ 100 = 0% |
6 29ms 10/ 100 = 10% 5/ 100 = 5% 4.34.87.145
0/ 100 = 0% |
7 31ms 8/ 100 = 8% 3/ 100 = 3% vlan80.csw3.LosAngeles1.Level3.net [4.69.144.190]
0/ 100 = 0% |
8 36ms 9/ 100 = 9% 4/ 100 = 4% ae-81-81.ebr1.LosAngeles1.Level3.net [4.69.137.9]
0/ 100 = 0% |
9 34ms 6/ 100 = 6% 1/ 100 = 1% ae-6-6.ebr1.Tustin1.Level3.net [4.69.153.222]
0/ 100 = 0% |
10 38ms 6/ 100 = 6% 1/ 100 = 1% ae-106-3506.bar2.Tustin1.Level3.net [4.69.158.102]
0/ 100 = 0% |
11 54ms 5/ 100 = 5% 0/ 100 = 0% 192.205.37.145
1/ 100 = 1% |
12 --- 100/ 100 =100% 94/ 100 = 94% cr2.la2ca.ip.att.net [12.122.129.106]
0/ 100 = 0% |
13 --- 100/ 100 =100% 94/ 100 = 94% 12.123.132.209
0/ 100 = 0% |
14 --- 100/ 100 =100% 94/ 100 = 94% 12-122-254-230.attens.net [12.122.254.230]
0/ 100 = 0% |
15 --- 100/ 100 =100% 94/ 100 = 94% 206.16.68.50
0/ 100 = 0% |
16 35ms 6/ 100 = 6% 0/ 100 = 0% 12.129.209.68
Trace complete.
Here is an ipconfig as well
Windows IP Configuration
Host Name . . . . . . . . . . . . : logan-pc
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 60-36-DD-51-DA-66
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 2230
Physical Address. . . . . . . . . : 60-36-DD-51-DA-65
Link-local IPv6 Address . . . . . : fe80::4052:9fc1:df6a:b8ef%7(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.13(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, June 6, 2014 2:47:14 PM
Lease Expires . . . . . . . . . . : Saturday, June 7, 2014 4:15:13 PM
Default Gateway . . . . . . . . . : 10.0.0.1
DHCP Server . . . . . . . . . . . : 10.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 123746013
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-78-FA-5C-60-36-DD-51-DA-65
DNS Servers . . . . . . . . . . . : 10.0.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:3c38:3c0:f5ff:fff2(Preferred)
Link-local IPv6 Address . . . . . : fe80::3c38:3c0:f5ff:fff2%3(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 285212672
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{75F3731E-501B-4BA4-88E8-DD8A2B7C7DFA}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter # 2
Any help would be greatly appreciated.
Allan_J_Intel1
Thanks for joining the Wireless Networking community.
I would like to know what happens when you try to ping the router. I need to check if there is data loss between your computer and the router.
You may try the following commands
ping -n count IP address
ping -t IP address
Please share the results.
Allan.
lwilh
Ping reply for command: ping -n count IP address resulted in the prompt saying -n was a "bad value for option -n, valid range is from 1 to 4294967295"
Ping reply for command: ping -t IP address
First results are the default gateway.
Second are the preferred.
Pinging 10.0.0.1 with 32 bytes of data:
Reply from 10.0.0.1: bytes=32 time=1ms TTL=64
Reply from 10.0.0.1: bytes=32 time<1ms TTL=64
Reply from 10.0.0.1: bytes=32 time=2ms TTL=64
Reply from 10.0.0.1: bytes=32 time=4ms TTL=64
Reply from 10.0.0.1: bytes=32 time=7ms TTL=64
Reply from 10.0.0.1: bytes=32 time=5ms TTL=64
Reply from 10.0.0.1: bytes=32 time=25ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out. continued for many more lines and was starting more.... I had to stop the prompt
Pinging 10.0.0.13 with 32 bytes of data:
Reply from 10.0.0.13: bytes=32 time<1ms TTL=128
This one just kept going as well.
LPerr3
I am having this *precise* problem, Ender - and no help in sight it seems. Same results as you, but with my machine's ID info.
Why must this be so difficult??
Kevin_M_Intel
Hi Guys,
Thank you for sharing all this information with us. There are some troubleshooting steps I would like you to do:
  1. How far are you from the router? How is the connection when standing next to the router? Is there a strong signal?
  2. Have you tried updating the router's firmware?
  3. Are there other wireless/Bluetooth devices between the router and your computer? Can you try as troubleshooting steps, turning them off?
  4. Change your encryption settings on the router.
Here you have a link that contains important information about that.
http://www.intel.com/support/wireless/wlan/4965agn/sb/CS-028449.htm http://www.intel.com/support/wireless/wlan/4965agn/sb/CS-028449.htm
Kevin M
