- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I recently upgraded my Windows 7 x64 bit Dell laptop with a Dual Band Wireless AC + Bluetooth 4.0 adapter. Network drivers are from the Intel PROSet v.16.10.0 and the Bluetooth drivers are 10/18/2013 v 3.1.1311.400. The wireless is working well (cannot connect AC to my ASUS RT-AC66R router yet, but currently monitoring a discussion here for that problem) and the Bluetooth seems to be working well, connects good and stays connected. For headphones, I use a set of LG HBS 730 stereo headphones and problem is that the Bluetooth adapter assigns it as a Bluetooth Headset (understandable, as it does have a built-in microphone as well), but it locks (grays out) the sound quality to the "1 channel, 16 bit, 16000 Hz (Tape Recorder Quality)" setting (see attached screenshot). This setting is not changeable, so I have to assume that this is set via the driver software. I have removed the device and added back a few times, and each time is defaults to the headset settings with the limited sample rate/bit depth. How do I either get the sample rate/bit depth to change to a DVD (or at least a CD) quality setting, or get the Bluetooth adapter to see the device as a Bluetooth headphone, instead of a Bluetooth Headset? Bottom line: need better sound quality for a set of stereo headphones/headset.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Let's see what we can do to fix this. Did you try setting up the other audio device (Bluetooth* headphones) as default?
You may also want to verify the profiles listed for this headset in Bluetooth* Devices (Devices and Printers), Services tab.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Joe,
Sorry, have been busy lately. Today, I tried what you have mentioned currently the laptop speakers are the Default Device and the Bluetooth Headset is the Default Communications Device. I cannot select/change this, other than swapping between them. I find that it has to be the Default Device, otherwise there will be no sound in the headset. The "Set Default" button is greyed out when the Bluetooth Headphones is selected. As far as the Services tab, the following is checked: Audio Sink, Handsfree Telephony, Remote Control, Remotely Controllable Device. The following is not checked: Headset. Now, if I check Headset, is does not seem to make a difference. Otherwise the problem still persists.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I guess enabling "Headset" does not allow changing the default audio device in Sound/Playback, correct? I know a new Bluetooth* software is going to be released soon, we can see then.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I have the same problem.
- laptop with a Intel® Dual Band Wireless-AC 7260 + Bluetooth 4.0 adapter,
- network drivers are from the Intel PROSet v.17.0.0 and the Bluetooth drivers are v 3.1.1311
- Nokia BH-504 stereo headphones
The wireless is working well.
After pairing my laptop with headphones and double click on the device, I see message: service not available or no connection (translation from Polish - "usługi niedostępne lub brak połączenia")
http://imgur.com/DejDkJg http://imgur.com/DejDkJg
Sorry for my poor english.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
The new version of Intel® PROSet/Wireless Software for Bluetooth® technology is now available.
For Windows* 7: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3714&DwnldID=23770 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3714&DwnldID=23770
For Windows* 8: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3714&DwnldID=23760 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3714&DwnldID=23760
For Windows* 8.1: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3714&DwnldID=23761 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3714&DwnldID=23761
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I have a problem.
- Laptop with a Intel® Dual Band Wireless-AC 7260 + Bluetooth 4.0 adapter, Windows 7 64bit.
- Plantronics M165 headset.
The wifi is working well.
I have a problem in Bluetooth.
The sound quality of headset is very low.
In hands free profile, I can hear the unstable and out of phase sounds (:-<
In A2DP profile, there is no problem. Good.
The head set is working well with other Laptops anb Smart phones.
Please support.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Exactly same problem here.
After pairing my laptop with headphones and double click on the device, after searching for services it says: service not available
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Please allow us more time to investigate.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
The following information is available in the Help section of the Bluetooth* driver, under Product Description:
Advanced Audio Distribution Profile (A2DP) (Source/Sink): Windows 8 and Windows 8.1 support audio profiles natively. In turn, interaction with media players and VoIP software is out of scope for Intel® PROSet/Wireless Software for Bluetooth® Technology from Windows 8 onwards.
I suggest contacting Microsoft* in regards of this inquiry.
I apologize for the inconvenience.
