Wireless
9047 Discussions
Error message
DeeDee64
Keep getting failed message Netws00.sys
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
JedG_Intel
Hi DeeDee64,
I'm just checking to see if you require assistance. If so, please share the SSU report and also the error message that you are seeing on your end.
Jed G.
JedG_Intel
Hello DeeDee64,
Jed G.
