Wireless
9031 Discussions
Error when installing ProSet 18.40 driver
PEnis
I'm having some issues with my Intel network card (AC7260 desktop) like random wakeup, and limited access to my files after remote wake up.
Before addressing this I wanted to update everything. Unfortunately this won't work either:
"A problem prevented the correct execution of the program."
I also tried in safe mode of windows 10 and followed the instruction of uninstalling (where you have to delete a set of registry entries) without success.
Any ideas? An uninstaller/removal tool would be nice.
thank you
best regards
ASouz7
Hello mikrotubulus,
Have you tried a clean installation? Please follow the steps below and let us know the results.
1. Download and save https://downloadcenter.intel.com/download/25833/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10 Download Intel® PROSet/Wireless Software and Drivers for Windows® 10 according to your OS architecture 32 or 64 Bit.
2. Go to Control Panel, Programs and Features and Uninstall "Intel® PROSet/Wireless Software", if it is installed. When prompted, choose the option to "Discard settings".
3. In Control Panel, Device Manager, Network Adapters, right click on the Intel® Dual Band Wireless-AC 7260 and Uninstall it. Make sure you mark the option to "Delete the driver software for this device".
4. Reboot the PC or scan for hardware changes, check device manager and if an older driver is detected and installed, repeat the actions to uninstall and delete it as well. Repeat this process until the OS does not allow deleting the driver, or until the controller shows as Unknown Device.
5. Reboot or scan for hardware changes, then uninstall and delete any older driver versions as you did for the Wireless adapter.
6. Install the Intel® Graphics driver downloaded before.
7. Install the Intel® Wireless driver. During the first steps of PROSet/Wireless installation, make sure to customize the installation and install all the 3 driver components.
mikrotubulus,
We have heard from you for a while. We would like to know if the troubleshooting steps we have sent you recently helped you to resolve the issue. Please let us know as soon as possible or at your earliest convenience.
