Wireless
8664 Discussions
Est-ce que la carte Intel® Wi-Fi 6 AX201 est compatible avec le processeur Intel® Core i5 9600 ?
User1571911163053485
AlHill
A better question to ask is if the ax201 is compatible with your device.
Contact the manufacturer of your device and ask that question.
Doc
If device is about motherboard: Asus z390-p. Confirmed by Asus Support: Compatible
AlHill
Then, you are OK.
Doc
Unfortunately no. I have a wifi card that prevents the computer from starting. I think it is a defective wifi card but the seller says it's because of the processor i5 9600.
AlHill
ASUS has informed you that the card is supported. And, asus supports your processor on that same board:
https://www.asus.com/us/Motherboards/PRIME-Z390-P/HelpDesk_CPU/
So, your problem is with the seller.
Doc
