Wireless
8623 Discussions
Fedora 32 iwlwifi-3168-29 issue
Klu
Hi there, I am unable to get the wireless working. My details as follows;
kernel-5.8.17-200.fc32.x86_64
/sbin/lspci | grep "Network controller"
02:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev 10)
-rw-rw-r--. 1 fischer fischer 1012K Oct 23 22:10 Wireless/linux-firmware-20201022/iwlwifi-3168-29.ucode
-rw-rw-r--. 1 fischer fischer 6.6M Nov  3 19:31 Wireless/iwlwifi-3168-29.ucode
Have cp from kernel.org to /lib/firmware/intel and rebooted, then tried it again with the intel file. With the following outcome.
dmesg | egrep iwl*
[ 5.994559] iwlwifi 0000:02:00.0: uCode file size 6881709 does not match expected size
[ 5.994772] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-28.ucode failed with error -2
[ 5.994790] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-27.ucode failed with error -2
[ 5.994804] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-26.ucode failed with error -2
[ 5.994818] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-25.ucode failed with error -2
[ 5.994831] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-24.ucode failed with error -2
[ 5.994845] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-23.ucode failed with error -2
[ 5.994858] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-22.ucode failed with error -2
[ 5.994859] iwlwifi 0000:02:00.0: no suitable firmware found!
[ 5.994860] iwlwifi 0000:02:00.0: minimum version required: iwlwifi-3168-22
[ 5.994860] iwlwifi 0000:02:00.0: maximum version supported: iwlwifi-3168-29
[ 5.994861] iwlwifi 0000:02:00.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
modinfo iwlwifi | grep iwlwifi
filename:       /lib/modules/5.8.16-200.fc32.x86_64/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.xz
firmware:       iwlwifi-3168-29.ucode
Can someone shed some light as to how I can get it to work?
