Wireless
8781 Discussions
HID proxy with Intel Wifi/Bluetooth adapter AX200?
Zaphod_Beeblebrox
the Intel M.2 adapter mentioned above supports Bluetooth 5.0 besides WiFi6. Does it also support HID proxy so I can use a bluetooth keyboard on BIOS level? If not: is there a similar adapter supporting this feature?
Thanks in advance!
Alberto_R_Intel
Zaphod_Beeblebrox, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In order to provide the most accurate response to your inquiry, I will do further research on this topic. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello Zaphod_Beeblebrox, I just received an update on this matter.
For this scenario, after reviewing the case, it is important to mention that the term "HID" most commonly refers to the USB-HID specification under USB interfaces. Based on the fact that we do not manufacture any USB Bluetooth dongles, then, we recommend to get in contact directly with the manufacturer of the device for further assistance and additional suggestions on this subject.
Albert R.
