Wireless
8946 Discussions
How can I replace missing C:\Program files (x86)Intel\Bluetooth\btmshell.dll? I'm being told module can't be found on brand new Dell
starting C:\Program Files (x86)Intel\Bluetooth\btmshell.dll. The specified module could not be found. I am running WIN 10 Home, 64 bit. The only thing I did, was connect a Bluetooth mouse to the Dell Laptop, brand new.
Hello Duffer,
We do not have a way to insert a .dll file independently. If you are getting this type of error, the best recommendation is to perform a clean installation of the Bluetooth* drivers; this involves removing the software from Windows* programs, as well as deleting the Intel® Bluetooth* device in device manager, after this you should install the Bluetooth* driver from your http://www.intel.com/content/www/us/en/support/topics/OEMs.html Computer Manufacturer support.
Keep in mind that you should contact http://www.dell.com/support/home/us/en/4 Dell* Support as first option, specially if this a new PC. Their drivers and software may be customized to operate in your computer.
For further assistance on our side, please let us know the following information as we will be glad to help, and provide detail steps to reinstall the generic drivers for your Bluetooth* controller:
- Computer model.
- Wireless Adapter model
- Was this working fine before?
Jonathan.
KKing4
Hi there
starting C:\Program Files (x86)Intel\Bluetooth\btmshell.dll. The specified module could not be found. I am running WIN 8.1, 64 bit on a HP Notebook
Following your advice to remove software and reinstall
Attempt to uninstall or repair Intel (R) PROset/Wireless Software for Bluetooth (R) Technology
results in the following error message
Service "Bluetooth Device Monitor" (Bluetooth Device Monitor) Failed to start. Verify that you have sufficient privileges to start system services
Any suggestions?
Hello krisking,
In your case, the error you are receiving when you try to uninstall the Bluetooth* software may not be caused by the driver itself; this is often related to OS registry issues, software dependencies, or other causes. We encourage you to check other technical websites for different options about the error: Service "..." Failed to start. Verify that you have sufficient privileges to start system services.
In our best effort, we advise you make sure your system has any applicable Windows* updates (.NET, etc.), also, you might want to check with the http://www.intel.com/content/www/us/en/support/topics/OEMs.html Computer Manufacturer Support and verify you are using their recommended drivers and software.
Jonathan B.
Hello Duffer,
We have not received any response to our last message. Please let us know in case you require further assistance.
Jonathan.
Hello Duffer,
We didn't receive any reply to our last message. Please let us know if you require further assistance.
Jonathan.
