Wireless
8622 Discussions
How to change bluetooth tx power for ax200?
mscott
Can someone point me in the direction of how to change the bluetooth tx power of the ax200.  I am incorporating it in a new board design and would like to perform some tests at different power levels.  Thanks
Jocelyn_Intel
Hello, @mscott
Thank you for posting on the Intel® communities.
I will do some research about this, as soon as I have any suggestions, I will post them here.
Best regards,
Jocelyn M.
Intel Customer Support Technician.
Jocelyn_Intel
Hello, @mscott
Thank you for your time.
The TX power ranges information is antenna dependent, they are usually provided by the system manufacturers, however, since you are developing the product/system, you need to check for this information in the Intel Developer Zone
Best regards,
Jocelyn M.
