Wireless
8787 Discussions
How to disable control frames on AX210 wifi card
David_Verbeek
I want to fully disable the ACK, RTS, and CTS layer 2 control frames on an AX210 to use it as a long-range (about 30k feet line of sight) S band transmitter, I already have all the equipment to get high enough gain on the receive end but want to fully disable the control frames to make this a one way protocol and improve speed a little bit. yes I know the many reasons why I should not do this but for my use case this is the best option to balance price and bandwidth at range, os will be linux
Thanks for any help
Mike_Intel
Hello David_Verbeek,
  1. What is the brand and model of your system?
  2. Just to check, did you upgrade the wireless controller of your system or this is the embedded wireless controller?
  3. What is the end goal for this inquiry?
Michael L.
Mike_Intel
Michael L.
Mike_Intel
I am sending another follow up on the information that I requested.
Michael L.
