Wireless
8781 Discussions
How to make? Hostednetwork 802.11ac with Intel(R) Dual Band Wireless-AC 7260?
JSoto8
Hello, i have an Intel(R) Dual Band Wireless-AC 7260 built in MSI z87 MPower Max AC with 17.1.0.19 driver, Windows 8.1 Pro N and i'm trying to make a wifi network to connect my computer with my Galaxy S5. The problem is that this hostednetwork is created in 802.11n and i want 802.11ac but i don´t know how set this network to work in 802.11ac.
I hope that help me, thanks. Sorry my english. Regards.
tvete
Valued Contributor II
Intel prohibited setting a wireless hosted network for 5 GHz and for that reason, you can't get 802.11ac for hosting. This is to comply with regulations. You can buy a non-compliant card such as ASUS PCIE cards then you can set the hosted network frequency at the 5 GHz band without region restriction, letting you use 802.11ac
tvete
JSoto8
ok, thanks for your reply! Is there any way to skip this restriction? Haha I don't have free pcie slots...
tvete
If you can modify the drivers to add a "Ad Hoc Channel for 802.11ac" on the advanced settings and selectable channels from 36 - 165 including DFS. Right now it's only 802.11 b/g on channel 1 - 11 for USA drivers. My ASUS PCE-AC56 card can change the "wzc ibss channel number" without any restrictions and you can even select DFS Channels as well as 20 Mhz, 40 MHz or 80 MHz channel width for your wireless hosted network.
Jose_H_Intel1
A similar discussion took place here:
