Wireless
8696 Discussions
INTEL AX210 wifi and ping issues
cizek
So i recently bought a new wifi card (Intel ax210, i had mediatek mt7921) for my laptop and im experiencing wifi and ping issues in games and. Im playing on stable 50 ping and its spiking to 300 and it also disconnects sometimes. Does anyone know the solution for this?
Jocelyn_Intel
Hello, @cizek
Thank you for posting on the Intel® communities.
It is worth mentioning that Intel does not support wireless integrations (installing a different wireless adapter into your system/laptop). We recommend you speak to the Manufacturer of your equipment for support on wireless integrations and replacement parts to ensure compliance with the regulatory requirements of your country and support. It is important to check for compatibility with the System Manufacturer, as there could be certain cards that will not work with the system.
For more information, read the following article under the title "Regulatory Information Regarding Wireless Hardware Installation or Upgrade.
Jocelyn M.
cizek
Oh yeah, i know that the wifi card is compatible with my laptop so how to solve the issue?
Jocelyn_Intel
Hello, @cizek
Thank you for your reply.
As explained above,  Intel does not support wireless integrations. If you have issues with your wireless integration, contact your System Manufacturer for assistance.
Please, keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Jocelyn M.
Marxis95
Hey there buddy I think I may have a solution for you because I had the same problem and so far it seems to have been fixed do the following: go to device manager>Network adapters>intel Wi-Fi>properties>advanced>802.11n/ac/ax Wireless Mode>choose the 802.11n option and you should be good to go
