Wireless
8975 Discussions
INTEL Wi-Fi Driver Installation Error
Kartal_Yildirim
Hello, I have a Wifi device called Intel® Wi-Fi 6 AX201 160MHz, a new driver version was released today, I downloaded it but I get an installation error. I restarted my computer but it still didn't work. Is there a solution to this?
I can only show it like this because the installation wizard interface language is Turkish, please excuse me.
Ekran görüntüsü 2025-03-04 175036.pngEkran görüntüsü 2025-03-04 175036.pngEkran görüntüsü 2025-03-04 175107.pngEkran görüntüsü 2025-03-04 175107.pngEkran görüntüsü 2025-03-04 175134.pngEkran görüntüsü 2025-03-04 175134.png
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
Kartal_Yildirim
Thank you for your answer, I scanned it in the program you mentioned and did not click the submit button you mentioned, I saved it and sent it here.
