Wireless
8873 Discussions
Intel 3160 on ASRock H97M
AFaug
I was wondering if anyone knows if the Intel Wireless-AC 3160 (the one that comes in the Alienware Alpha) is compatible with the ASRock H97M motherboard. I would assume it is because of the chipset but I wanted to make sure.
ASouz7
Alpha1701,
Intel® Wireless Adapters are meant to be installed by OEMs as they suffer modifications in order to be compatible to the type of system the OEM is installing it. We recommend that you contact the motherboard manufacturer and obtain the list of Intel® Wireless Adapters that are compatible with the mentioned motherboard.
