Wireless
8668 Discussions
Intel 7260 (rev 83) wifi card not working properly under Linux
MD11
Dear Support,
Recently I have been experiencing very bad behavior of my Intel 7260 (rev 83) wifi card. I am using laptop Lenovo T440s and my operating system is Debian Jessie.
[quote]
03:00.0 Network controller: Intel Corporation Wireless 7260 (rev 83)
Subsystem: Intel Corporation Dual Band Wireless-AC 7260
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 49
Region 0: Memory at f0400000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00318 Data: 0000
Capabilities: [40] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port # 0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <32us
ClockPM+ Surprise- LLActRep- BwNot-
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Via WAKE#
DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis-, LTR+, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 7c-7a-91-ff-ff-7a-41-df
Capabilities: [14c v1] Latency Tolerance Reporting
Max snoop latency: 3145728ns
Max no snoop latency: 3145728ns
Capabilities: [154 v1] Vendor Specific Information: ID=cafe Rev=1 Len=014 <?>
Kernel driver in use: iwlwifi
[/quote]
I am using kernel version of
[quote]Linux debian 3.16.0-4-amd64 # 1 SMP Debian 3.16.7-ckt20-1+deb8u2 (2016-01-02) x86_64 GNU/Linux[/quote]
The modules and firmware are loaded properly. I am using most recent firmware (iwlwifi-7265-9.ucode) for kernel 3.14.9+
[quote]
[ 1.532330] Intel(R) Wireless WiFi driver for Linux, in-tree:
[ 1.533482] iwlwifi 0000:03:00.0: irq 64 for MSI/MSI-X
[ 1.538853] iwlwifi 0000:03:00.0: firmware: direct-loading firmware iwlwifi-7260-9.ucode
[ 1.539000] iwlwifi 0000:03:00.0: loaded firmware version 23.214.9.0 op_mode iwlmvm
[ 1.555375] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144
[ 1.556657] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled
[ 1.557158] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled
[/quote]
[quote]
root@debian:/home/user# ls -la /lib/firmware
total 13248
drwxr-xr-x 9 root root 4096 Jan 28 23:18 .
drwxr-xr-x 19 root root 4096 Nov 30 23:14 ..
drwxr-xr-x 2 root root 4096 Dec 1 18:41 av7110
-rw-r--r-- 1 root root 13388 Feb 22 2014 carl9170-1.fw
drwxr-xr-x 2 root root 4096 Dec 1 18:41 cis
drwxr-xr-x 2 root root 4096 Dec 1 18:41 dsp56k
drwxr-xr-x 2 root root 4096 Oct 2 2014 hp
drwxr-xr-x 2 root root 4096 Jan 9 00:00 intel
drwxr-xr-x 2 root root 4096 Dec 1 18:41 isci
-rw-r--r-- 1 root root 337520 Jun 16 2014 iwlwifi-1000-5.ucode
-rw-r--r-- 1 root root 337572 Jun 16 2014 iwlwifi-100-5.ucode
-rw-r--r-- 1 root root 689680 Jun 16 2014 iwlwifi-105-6.ucode
-rw-r--r-- 1 root root 701228 Jun 16 2014 iwlwifi-135-6.ucode
-rw-r--r-- 1 root root 695876 Jun 16 2014 iwlwifi-2000-6.ucode
-rw-r--r-- 1 root root 707392 Jun 16 2014 iwlwifi-2030-6.ucode
-rw-r--r-- 1 root root 670484 Jun 16 2014 iwlwifi-3160-7.ucode
-rw-r--r-- 1 root root 667284 Jun 16 2014 iwlwifi-3160-8.ucode
-rw-r--r-- 1 root root 666792 Jun 16 2014 iwlwifi-3160-9.ucode
-rw-r--r-- 1 root root 150100 Jun 16 2014 iwlwifi-3945-2.ucode
-rw-r--r-- 1 root root 187972 Jun 16 2014 iwlwifi-4965-2.ucode
-rw-r--r-- 1 root root 353240 Jun 16 2014 iwlwifi-5000-2.ucode
-rw-r--r-- 1 root root 340696 Jun 16 2014 iwlwifi-5000-5.ucode
-rw-r--r-- 1 root root 337400 Jun 16 2014 iwlwifi-5150-2.ucode
-rw-r--r-- 1 root root 454608 Jun 16 2014 iwlwifi-6000-4.ucode
-rw-r--r-- 1 root root 444128 Jun 16 2014 iwlwifi-6000g2a-5.ucode
-rw-r--r-- 1 root root 677296 Jun 16 2014 iwlwifi-6000g2a-6.ucode
-rw-r--r-- 1 root root 679436 Jun 16 2014 iwlwifi-6000g2b-6.ucode
-rw-r--r-- 1 root root 463692 Jun 16 2014 iwlwifi-6050-4.ucode
-rw-r--r-- 1 root root 469780 Jun 16 2014 iwlwifi-6050-5.ucode
-rw-r--r-- 1 root root 683236 Jun 16 2014 iwlwifi-7260-7.ucode
-rw-r--r-- 1 root root 679780 Jun 16 2014 iwlwifi-7260-8.ucode
-rw-r--r-- 1 root root 679380 Jun 16 2014 iwlwifi-7260-9.ucode
-rw-r--r-- 1 root root 690452 Jun 16 2014 iwlwifi-7265-8.ucode
-rw-r--r-- 1 root root 691960 Jun 16 2014 iwlwifi-7265-9.ucode
drwxr-xr-x 2 root root 4096 Dec 1...
ASouz7
MD11
Dear aleki_intel,
Thank you for your reply. I already know about those pages ... the problem is that I am using the latest firmware and my wifi card is still not working properly.
[ 2.256357] iwlwifi 0000:03:00.0: irq 64 for MSI/MSI-X [ 2.267512] iwlwifi 0000:03:00.0: firmware: direct-loading firmware iwlwifi-7260-9.ucode [ 2.267672] iwlwifi 0000:03:00.0: loaded firmware version 25.228.9.0 op_mode iwlmvm [ 2.298876] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144 [ 2.299211] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled [ 2.299707] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled [ 3.746892] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled [ 3.747393] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled
From your reply I understand that I should write to 'mailto:mailto:linuxwifi@intel.com linuxwifi@intel.com' or 'mailto:mailto:linux-wireless@vger.kernel.org linux-wireless@vger.kernel.org'? Is that right?
MD
ASouz7
_MD_
Yes, they are the ones provide support for ntel® Wireless Adapters on Linux* environment.
MD11
Okay, thank you I will try to write to those mailing lists.
ASouz7
