Wireless
8716 Discussions
Intel AC 7260 5GHz VHT & uAPSD = Limited Access in WIndows 8.1
bblaa
As of right now I am running 7260 on 16.10.0.5, latest functional driver for Windows 8.1.
Ever since the option for enabling/disabling uAPSD is introduced in newer driver version, 17.x.x.x, VHT mode simply does not work anymore. It connects fine to the router but could not communicate with the router at all and ended up "Limited Access" in the Windows 8.1.
UAPSD Enabled + VHT = Connected but no network access
UAPSD Disabled + VHT = Connected but no network access
UAPSD Enabled + HT = No issues running at N speed
UAPSD Disabled + HT = No Issues running at N speed
I rolled back the driver to 16.10.0.5, WiFi works fine again running at 866.7Mbps. Has anyone got 7260 running at wireless AC speed in Windows 8.1 with the latest driver?
Kevin_M_Intel
Hello blahblahblahblaah,
We are working this issue on another thread. Please post your query and your feedback here:
/thread/49947 https://communities.intel.com/thread/49947
Kevin M
bblaa
Hi Kevin, thank you for the response.
Please note that mine never worked ever since the new driver was installed, regardless the system was awake from sleep or not. It simply refused to work. However I will post my feedback there anyway.
