Wireless
8606 Discussões
Intel AX101 WRDD/DFS issues on Debian 13 Trixie
RicoBelo
Principiante
1.057 Visualizações
I have a chinese Mini-PC with an Intel N150 CPU and a soldered Intel AX101 wireless card running Linux Debian 13 (Trixie)
want to use the wireless card as an AP, which is supported by AX101 chip and driver, in 802.11ax mode on the 5GHz band.
As I live in France, I forced cfg80211 module to load WRDD for France with the kernel parameter
cfg80211.ieee80211_regdom=FR
The global registration is then correctly globally set to FR, but the wireless card is kept unconfigured with no country and no DFS information:
# iw reg get
global
country FR: DFS-ETSI
	(2400 - 2483 @ 40), (N/A, 20), (N/A)
	(5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
	(5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
	(5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS
	(5725 - 5875 @ 80), (N/A, 13), (N/A)
	(5945 - 6425 @ 320), (N/A, 23), (N/A), NO-OUTDOOR
	(57000 - 71000 @ 2160), (N/A, 40), (N/A)
phy#0 (self-managed)
country 00: DFS-UNSET
	(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
	(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
	(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
	(5170 - 5190 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5190 - 5210 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5210 - 5230 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5230 - 5250 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5250 - 5270 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5270 - 5290 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5290 - 5310 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5310 - 5330 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5490 - 5510 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5510 - 5530 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5530 - 5550 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5550 - 5570 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5570 - 5590 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5590 - 5610 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5610 - 5630 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5630 - 5650 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5815 - 5835 @ 20), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
At least I can see many channels in the 5GHz band available for DFS. So I try a minimalistic hostapd.conf file to start an AP centered on channel 100 with 802.11ax, but it fail : hostapd enumerates all channels in the 5GHz band with "No IR" flag :
nl80211: 2402-2437 @ 40 MHz 22 mBm
nl80211: 2422-2462 @ 40 MHz 22 mBm
nl80211: 2447-2482 @ 40 MHz 22 mBm
nl80211: 5170-5190 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5190-5210 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5210-5230 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5230-5250 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5250-5270 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5270-5290 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5290-5310 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5310-5330 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5490-5510 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5510-5530 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5530-5550 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5550-5570 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5570-5590 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5590-5610 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5610-5630 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5630-5650 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5650-5670 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5670-5690 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5690-5710 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5710-5730 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5735-5755 @ 80 MHz 22 mBm (no IR)
nl80211: 5755-5775 @ 80 MHz 22 mBm (no IR)
nl80211: 5775-5795 @ 80 MHz 22 mBm (no IR)
nl80211: 5795-5815 @ 80 MHz 22 mBm (no IR)
nl80211: 5815-5835 @ 20 MHz 22 mBm (no IR)
nl80211: Added 802.11b mode based on 802.11g information
nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED]
nl80211: Mode IEEE 802.11a: 5180[NO_IR] 5200[NO_IR] 5220[NO_IR] 5240[NO_IR] 5260[NO_IR][RADAR] 5280[NO_IR][RADAR] 5300[NO_IR][RADAR] 5320[NO_IR][RADAR] 5340[DISABLED] 5360[DISABLED] 5380[DISABLED] 5400[DISABLED] 5420[DISABLED]
nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED]
Frequency 5500 (primary) not allowed for AP mode, flags: 0x15b NO-IR RADAR
Primary frequency not allowed
wlo1: IEEE 802.11 Configured channel (100) or frequency (5500) (secondary_channel=0) not found from the channel list of the current mode (2) IEEE 802.11a
wlo1: IEEE 802.11 Hardware does not support configured channel
Could not select hw_mode and channel. (-3)
wlo1: interface state COUNTRY_UPDATE->DISABLED
wlo1: AP-DISABLED
 So I tried to enable DFS and force 80MHz band centering between channel 100 and 106 with a more elaborated hostapd config. Bu once again, hostapd fails to start because it fails to start DFS scan.
I was able to start hostapd in 802.11ax on the 2.4GHz band as there is no DFS gotchas on the band, but at the price of terrific bandwidth of less than 90Mbps.
I join my dmesg, config files, and iw outputs in attachements
So at this point I assume the firmware forbid me to use the card in AP mode on 5Ghz band because of DFS, I don't really understand how and why. So can you help me to fix this ?
12 Respostas
JedG_Intel
Moderador
976 Visualizações
Hello RicoBelo,
Thank you for posting on Intel Community Forum. I appreciate your effort for sharing as much information as you could. This will definitely help with the investigation moving forward.
To address the issue properly, kindly share the information below.
1. What is the make and model of your Mini-PC? If possible, kindly share the direct link to it.
2. Were you previously able to configure and use the wireless card according to your preferred settings?
3. What is the Kernel and firmware version?
Best regards
Jed G.
RicoBelo
Principiante
938 Visualizações
Hello Jed, thanks for your support
1. I brought this mini-pc on a French second hand market website called "leboncoin.fr" which will obviously not your :D, but the miniPC is branded "SOAYAN N2" and I found references on Alibaba and also Amazon :
https://www.amazon.fr/SOAYAN-Lake-N150-Computer-Business-Heimkino/dp/B0DTF11ZFT
https://www.alibaba.com/product-detail/SOAYAN-2025-Factory-Direct-N2-Mini_1601390125662.html?spm=a2700.details-description.0.0.79eeM2XVM2XVqW
This is obviously a generic product sold to many distributors, and unfortunately I was not able to find the manufacturer or any support.
2. Initially I didn't used the wireless at all : I use this server to share and transcode media files with Jellyfin over Ethernet, thanks to it great CPU and IGP (the N1xx series are really great and green products !)
 But as I recently added a new FireTV 4K with a weak wireless connection because my "real AP" is too far, and the mini-pc is just next to the FireTV stick, I through bridging the wireless card would be an far more elegant option than adding another AP !
The FireTV 4K is the reason why I want 802.11ax over 5Ghz : I want to archieve at least 500Mbps bandwidth with low latency
3. You can find kernel and firmware details in dmesg.txt output. For reference :
# uname -a
Linux jellyfin 6.12.48+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.48-1 (2025-09-20) x86_64 GNU/Linux
# dmesg |grep -P 'iwl|80211'
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-6.12.48+deb13-amd64 root=/dev/mapper/vg_sys-root ro cfg80211.ieee80211_regdom=FR
[    0.021764] Kernel command line: BOOT_IMAGE=/vmlinuz-6.12.48+deb13-amd64 root=/dev/mapper/vg_sys-root ro cfg80211.ieee80211_regdom=FR
[    3.414369] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.510206] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.519644] iwlwifi 0000:00:14.3: Detected crf-id 0x501, cnv-id 0x80400 wfpm id 0x80000030
[    3.520291] iwlwifi 0000:00:14.3: PCI dev 54f0/0244, rev=0x370, rfid=0x10c000
[    3.520940] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101
[    3.526646] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
[    3.527662] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    3.528420] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    3.529024] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    3.529612] iwlwifi 0000:00:14.3: loaded firmware version 89.4d42c933.0 so-a0-hr-b0-89.ucode op_mode iwlmvm
[    4.058973] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    4.059024] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    4.059032] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    4.059041] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
[    4.059802] iwlwifi 0000:00:14.3: Detected RF HR1 B3, rfid=0x10c000
[    4.060202] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[    4.101019] iwlwifi 0000:00:14.3: base HW address: 94:b6:09:42:1d:b9
[    4.150719] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
I also forced regulatory information database from upstream instead of Debian DB:
# update-alternatives --get-selections | grep regulatory
regulatory.db                  manual   /lib/firmware/regulatory.db-upstream
RicoBelo
Principiante
938 Visualizações
Hello Jed,
1. This is a generic chinese mini-pc, branded as "SOAYAN N2 Mini PC N150". You can find it on AliBaba as well as Amazon :
https://french.alibaba.com/product-detail/SOAYAN-2025-Factory-Direct-N2-Mini-1601390125662.html
I search for an eventual official website but didn't found anything suitable to request any support from the manufacturer.
2. Not really : I usually prefers Ethernet connection when possible so wireless was disabled. The reason why I need to activate it as AP is this host is exclusively used for transcoding media content using Jellyfin, and I just added an Amazon FireTV 4K stick with a weak Wifi connection because my "real" AP is to far away, so as the Mini-PC is just next to the FireTV stick, I thought far more elegant bridging its connection as an AP than installing another "real" AP for just one device.
3. I think you already have these information on the dmesg.txt attached file. FYI:
# uname -a
# dmesg | grep -P '80211|iwl'
 So:
kernel is stock Debian 13 (kernel 6.12.48)
firmware blob is 89.4d42c933.0 so-a0-hr-b0-89.ucode
I also need to precise that I switched to upstream regulatory database instead the the stock Debian provided :
JedG_Intel
Moderador
926 Visualizações
Hello RicoBelo,
Thank you for sharing all this information. I really appreciate that you shared a reference link to your Mini-PC. I'll investigate this matter internally and I'll get back in touch as soon as possible.
Best regards
Jed G.
RicoBelo
Principiante
889 Visualizações
Thanks for your help, I really appreciate
Hope you'll be able to find a solution
Eric
JedG_Intel
Moderador
688 Visualizações
Hello RicoBelo,
I'm getting back in touch to gain additional information that will help with our investigation. Please see below.
- Have you had the chance to contact the Place of Purchase about the issue?
- Please generate System Support Utility report - Help Guide for the Intel® System Support Utility
Best regards
Jed G.
RicoBelo
Principiante
666 Visualizações
Hello Jed,
I downloaded ssu_3.0.0.2_tar.gz and ran it on my system. the log is in attachment.
Eric
JedG_Intel
Moderador
545 Visualizações
Hello RicoBelo,
Thank you for providing the SSU report, I appreciate it. Can you please also confirm if you were able to contact the Place of Purchase already about this issue?
I hope to hear from you soon.
Best regards
Jed G.
RicoBelo
Principiante
516 Visualizações
Hello Jed,
The short answer: no !
The long one: I contacted the manufacturer on alibaba marketplace explaining almost what I detailed here... and he sent me a ZIP file containing Windows wireless drivers
JedG_Intel
Moderador
416 Visualizações
Hello RicoBelo,
Thanks for the added information. Could you please confirm whether the driver supplied by the manufacturer worked for you?
Best regards
Jed G.
RicoBelo
Principiante
384 Visualizações
Hi Jed,
As said, they only provided *Windows* drivers, while I'm running Debian 13 !
How do you expect me to use Windows drivers on a Linux system ???
Eric
JedG_Intel
Moderador
299 Visualizações
Hello RicoBelo,
I apologize for any confusion. I had assumed that you previously attempted to use the Windows Operating System, as the manufacturer provided you with Windows drivers. Nonetheless, I will continue investigating this matter and will reach out to you with an update as soon as possible.
Best regards
Jed G.
Responder
