Wireless
8537 Discussions
Intel AX200 failed to run INIT
MSD-Systems
Dear Deivid,
you have closed the old thread but i do not understand why.  You mentioned in the thread ubuntu 20.04 Intel ax200 Failed to run INIT ucode: -110  i have to check with the manufacture of the board.
Check the following with them:
1. PCIe clock request
2. PCIe reference clock
I am going to close this thread, for now. However, once the manufacturer provides you with any solution or information you can create a new thread and provide this one as a reference and we will continue with the support.
As already mentioned in the thread ubuntu 20.04 Intel ax200 Failed to run INIT ucode: -110 i have installed an Windows on it and the Module is working. Why should this be an Hardware issue when another OS is working?
Please provide me a feedback.
Many thanks for your support
n_scott_pearson
The driver has to load firmware onto the AX2xx card. If you see one working with Windows but not working with a particular Linux distro, then I would expect that the issue is the firmware being downloaded to the card. Try updating the driver in the distro.
Hope this helps,
MSD-Systems
this i have already tried. It is still the same windows works and linux not.
[ 1041.934865] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-64.ucode failed with error -2
[ 1041.935597] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 1041.935622] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 1041.936206] iwlwifi 0000:03:00.0: loaded firmware version 63.c04f3485.0 cc-a0-63.ucode op_mode iwlmvm
[ 1041.945983] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 1041.955121] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 1042.961305] iwlwifi 0000:03:00.0: SecBoot CPU1 Status: 0x4, CPU2 Status: 0x1
[ 1042.961352] iwlwifi 0000:03:00.0: UMAC PC: 0xc00c0eb2
[ 1042.961386] iwlwifi 0000:03:00.0: LMAC PC: 0x0
[ 1042.961394] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 1042.990583] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 1042.990595] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 976139064
[ 1042.990602] iwlwifi 0000:03:00.0: Loaded firmware version: 63.c04f3485.0 cc-a0-63.ucode
[ 1042.990608] iwlwifi 0000:03:00.0: 0xB24C89B5 | ADVANCED_SYSASSERT
[ 1042.990616] iwlwifi 0000:03:00.0: 0x9D2DBFF8 | trm_hw_status0
[ 1042.990621] iwlwifi 0000:03:00.0: 0xC9694029 | trm_hw_status1
[ 1042.990626] iwlwifi 0000:03:00.0: 0xCE5F764A | branchlink2
[ 1042.990630] iwlwifi 0000:03:00.0: 0x6FEFFA22 | interruptlink1
[ 1042.990635] iwlwifi 0000:03:00.0: 0x791B61D2 | interruptlink2
[ 1042.990639] iwlwifi 0000:03:00.0: 0x120B1D4F | data1
[ 1042.990643] iwlwifi 0000:03:00.0: 0xF0A3DCAA | data2
[ 1042.990648] iwlwifi 0000:03:00.0: 0x5BA97162 | data3
[ 1042.990652] iwlwifi 0000:03:00.0: 0x76E5FCAF | beacon time
[ 1042.990656] iwlwifi 0000:03:00.0: 0x3DB8D951 | tsf low
[ 1042.990660] iwlwifi 0000:03:00.0: 0x38C2BB61 | tsf hi
[ 1042.990664] iwlwifi 0000:03:00.0: 0x8B706985 | time gp1
[ 1042.990668] iwlwifi 0000:03:00.0: 0x26D1926D | time gp2
[ 1042.990672] iwlwifi 0000:03:00.0: 0xA9AC5D94 | uCode revision type
[ 1042.990676] iwlwifi 0000:03:00.0: 0xC06E6FFE | uCode version major
[ 1042.990680] iwlwifi 0000:03:00.0: 0x58C45005 | uCode version minor
[ 1042.990685] iwlwifi 0000:03:00.0: 0x2EA5464D | hw version
[ 1042.990689] iwlwifi 0000:03:00.0: 0x9E6C085A | board version
[ 1042.990693] iwlwifi 0000:03:00.0: 0xA8E07D54 | hcmd
[ 1042.990697] iwlwifi 0000:03:00.0: 0xFE05F4AF | isr0
[ 1042.990701] iwlwifi 0000:03:00.0: 0x13DEFE10 | isr1
[ 1042.990705] iwlwifi 0000:03:00.0: 0x392FB36B | isr2
[ 1042.990708] iwlwifi 0000:03:00.0: 0x8C9AA1CF | isr3
[ 1042.990712] iwlwifi 0000:03:00.0: 0x3CEE91FF | isr4
[ 1042.990716] iwlwifi 0000:03:00.0: 0x8097EC80 | last cmd Id
[ 1042.990720] iwlwifi 0000:03:00.0: 0xE7A9CEB0 | wait_event
[ 1042.990724] iwlwifi 0000:03:00.0: 0x4778E5F1 | l2p_control
[ 1042.990728] iwlwifi 0000:03:00.0: 0x37F8E0FE | l2p_duration
[ 1042.990732] iwlwifi 0000:03:00.0: 0xAFF0F58B | l2p_mhvalid
[ 1042.990736] iwlwifi 0000:03:00.0: 0xDCC9671F | l2p_addr_match
[ 1042.990740] iwlwifi 0000:03:00.0: 0x5DCE722C | lmpm_pmg_sel
[ 1042.990744] iwlwifi 0000:03:00.0: 0x6D3FF744 | timestamp
[ 1042.990748] iwlwifi 0000:03:00.0: 0x578465C6 | flow_handler
[ 1042.990886] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 1042.990890] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 7
[ 1042.990896] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 1042.990900] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
[ 1042.990905] iwlwifi 0000:03:00.0: 0x8045541A | umac branchlink2
[ 1042.990909] iwlwifi 0000:03:00.0: 0x00000000 | umac interruptlink1
[ 1042.990914] iwlwifi 0000:03:00.0: 0x80437408 | umac interruptlink2
[ 1042.990918] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
[ 1042.990922] iwlwifi 0000:03:00.0: 0x80437408 | umac data2
[ 1042.990926] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
[ 1042.990930] iwlwifi 0000:03:00.0: 0x0000003F | umac major
[ 1042.990934] iwlwifi 0000:03:00.0: 0xC04F3485 | umac minor
[ 1042.990938] iwlwifi 0000:03:00.0: 0x000FB700 | frame pointer
[ 1042.990943] iwlwifi 0000:03:00.0: 0xC0887F40 | stack pointer
[ 1042.990947] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
[ 1042.990951] iwlwifi 0000:03:00.0: 0x00000000 | isr status reg
[ 1042.991051] iwlwifi 0000:03:00.0: IML/ROM dump:
[ 1042.991055] iwlwifi 0000:03:00.0: 0x00000003 | IML/ROM error/state
[ 1042.991187] iwlwifi 0000:03:00.0: 0x0000670A | IML/ROM data1
[ 1042.991294] iwlwifi 0000:03:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 1042.991393] iwlwifi 0000:03:00.0: Fseq Registers:
[ 1042.991443] iwlwifi 0000:03:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 1042.991492] iwlwifi 0000:03:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 1042.991542] iwlwifi 0000:03:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 1042.991592] iwlwifi 0000:03:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 1042.991642] iwlwifi 0000:03:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 1042.991692] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 1042.991742] iwlwifi 0000:03:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 1042.991791] iwlwifi 0000:03:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 1042.991842] iwlwifi 0000:03:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 1042.991893] iwlwifi 0000:03:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 1042.991945] iwlwifi 0000:03:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 1042.991998] iwlwifi 0000:03:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 1042.992050] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 1042.992057] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
DeividA_Intel
Hello MSD-Systems,
As you mentioned, this issue seems to be exclusively related to a specific OS. However, let check this once more in order to provide you a complete answer.
In the meantime, please try to check with Fujitsu (motherboard manufacturer) and provide us the outcome.
Deivid A.
MSD-Systems
Dear David,
please can you provide me more details around the error otherwise it will be hard to discuss with fujitsu about this topic.
best regards
DeividA_Intel
Hello MSD-Systems,
I would like to inform you that the issue is under investigation and we'll provide you with updates within the next few days on your original post:
- https://community.intel.com/t5/Wireless/ubuntu-20-04-Intel-ax200-Failed-to-run-INIT-ucode-110/m-p/1266491#U1266491
I will proceed to close this thread since we are going to keep working on the original thread.
Deivid A.
MSD-Systems
Hi Deivid,
do have an update for me?
best regards
Michael
