Wireless
8721 Discussions
Intel AX200 supports FTM-802.1AS Integration?
mtthi
Dear,
Following another thread, where Intel team suggests us to use Intel Wireless Adapter AX200,
Would any of you know about this on AX200...
- What we are doing: integrate FTM (fine time measurement) into 802.1AS (use FTM to improve the precision of 802.1AS), as described in standard 802.1AS-rev D8.3
- Question: given that AX200 supports FTM, does it also support FTM-802.1AS integration? I mean...
- What we need:
+ At AX200 driver, we need the FTM-related information "VendorSpecific", which can be taken from FTM frame. We assume this info should be provided by hardware/firmware?
+ We need to read/write FTM's timestamp, is it possible?
Thanks in advance for your response!
David_G_Intel
Hello mtthi
Thank you for posting on the Intel️® communities. We are working on this request, we will post the updates on the thread.
David G
Intel Customer Support Technician
David_G_Intel
Hello @mtthi
We got information from the engineering team and the FTM-802.1AS integration is still working in progress internally. We can't share related designing information, and currently there is no ETA when we will release the feature.
David G
