Hi.
When Using Wii Remotes connected by Bluetooth on apps like dolphin, there is no sound coming from the wii remote speaker.
I thought it was Windows 11. But it´s not. It doesnt work on any Windows.
Wii remote functionality works, but wii remote audio speaker doesnt.
Tried another BT adapter (CSR USB\VID_0A12&PID_0001) and wii remote audio speaker works fine.
Hello will6,
In order to better assist you, please provide the following information:
- Was the audio working before? If so, was there any change in your system before the issue started?
- Do you see any error code in Device Manager under Bluetooth?
As well, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven G.
