Wireless
8528 Discusiones
Intel AX201 WiFi 6 160MHz
HerrHofmann
Principiante
10.618 Vistas
Hello, I am using the Asus Tuf Gaming F15 FX506HC 2021 model. I have been experiencing frequent disconnections on both Linux and Windows on my laptop. The Wi-Fi card automatically shuts down when it is under heavy load, and if I'm using Windows, it disconnects(10 or 43 code) on its own after a while. Is there anyone who can help me? I am planning to take my laptop to a technical service, but before doing so, I wanted to try my luck. This is because about 90% of the technical services in my country tend to attribute the issue to software problems without actually resolving it.
Here are the things I've tried that didn't work:
I tried downloading and installing the latest drivers from the laptop's website.
I tried downloading and installing the latest drivers from the Intel website.
I performed a hard reset.
I tried resetting the BIOS settings.
I reinstalled the operating systems and tried installing the laptop's drivers first. When that didn't work, I tried the drivers from the Intel website.
0 kudos
12 Respuestas
Jocelyn_Intel
Empleados
10.580 Vistas
Hello, @HerrHofmann
Thank you for posting on the Intel® communities. I will gladly assist you here.
Please, answer these questions to have a better perspective of this issue:
  1. Is the Intel® Wi-Fi 6 AX201 the pre-installed wi-fi card in your laptop or is it an integration (upgrade/ not the original card)?
  2. Did you make sure that your laptop actually supports Linux with your System Manufacturer? There are no drivers for other OS than Windows 10 and Windows 11.
  3. Was it working fine before with Windows?
  4. What is the model of your router?
Jocelyn M.
HerrHofmann
Principiante
10.570 Vistas
1- The card that came with my computer when I bought it.
2- My laptop manufacturer does not provide support for linux, but until August 2021 - May 2023, there was no problem, it was working fine on both windows and linux, until then. (For Linux, nothing was used other than the packages that came installed in the distro, I apologize for not specifying it.)
3- yes, it was working fine from August 2021 to May 2023.
4- Zyxel VMG3313-B10A (This device was issued by the ISP. But before this problem developed my modem was and still is the same.)
On the Linux side, I tried different distros(Fedora, Manjaro, etc..) the result is still the same, the distro I'm using now openSUSE tumbleweed
thank you for giving a time.
Jocelyn_Intel
Empleados
10.545 Vistas
 Hello, @HerrHofmann
Thank you for the information provided.
  1. What is the model of your laptop?
  2. Did you make sure your router firmware is up to date?
  3. Does this issue happen with another network or router?
  4. Have you tried a Clean installation of wireless drivers process using the latest Intel wireless driver
Note: Make sure to check you have all the Windows updates before doing the driver installation. Also, make sure to do this step disconnected from the internet (wi-fi or wired connection) when you are uninstalling the driver software since Microsoft updates drivers automatically and prevents doing the clean installation successfully.
For Linux, please make sure of the following, however, the fact that System Manufacturer does not support it, affects importantly in the performance of the OS, we will do our best to help you with an unsupported OS but we cannot guarantee it will work due to the System Manufacturer limitations:
  1. Please provide a specific OS name and kernel version.
  2. Make sure that your wireless adapter is connected properly running # lspci command in the terminal and verifying if the wireless adapter is recognized.
  3. Make sure that the module is installed properly running # modinfo iwlwifi command.
  4. Type # lsmod | grep iwlwifi to make sure the driver is loaded.
  5. Type # dmesg | grep iwlwifi. If the result is empty, the driver wasn’t initialized.
  6. Type the # dmesg | grep “no suitable firmware found!” command and the result is not empty, that means that you don't have a suitable FW, you need to check here for supported FW or here for latest versions.
Jocelyn M.
HerrHofmann
Principiante
10.383 Vistas
Windows:
1- Asus Tuf Gaming F15 FX506HC
2- Yes
3- Yes
4- Yes
Linux:
1- Distro Name: OpenSUSE Tumbleweed | Kernel version: 6.3.9-1-default
I also uploaded it as a txt file just in case. There is no file because part 6 is empty.
2- lspci Output:
00:00.0 Host bridge: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:01.0 PCI bridge: Intel Corporation 11th Gen Core Processor PCIe Controller #1 (rev 05)
00:02.0 VGA compatible controller: Intel Corporation TigerLake-H GT1 [UHD Graphics] (rev 01)
00:04.0 Signal processing controller: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant (rev 05)
00:06.0 PCI bridge: Intel Corporation 11th Gen Core Processor PCIe Controller #0 (rev 05)
00:07.0 PCI bridge: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #0 (rev 05)
00:08.0 System peripheral: Intel Corporation GNA Scoring Accelerator module (rev 05)
00:0a.0 Signal processing controller: Intel Corporation Tigerlake Telemetry Aggregator Driver (rev 01)
00:0d.0 USB controller: Intel Corporation Tiger Lake-H Thunderbolt 4 USB Controller (rev 05)
00:0d.2 USB controller: Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #0 (rev 05)
00:14.0 USB controller: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Tiger Lake-H Shared SRAM (rev 11)
00:14.3 Network controller: Intel Corporation Tiger Lake PCH CNVi WiFi (rev 11)
00:15.0 Serial bus controller: Intel Corporation Tiger Lake-H Serial IO I2C Controller #0 (rev 11)
00:16.0 Communication controller: Intel Corporation Tiger Lake-H Management Engine Interface (rev 11)
00:1b.0 PCI bridge: Intel Corporation Device 43c0 (rev 11)
00:1d.0 PCI bridge: Intel Corporation Device 43b6 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Tiger Lake-H LPC/eSPI Controller (rev 11)
00:1f.3 Audio device: Intel Corporation Tiger Lake-H HD Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Tiger Lake-H SMBus Controller (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-H SPI Controller (rev 11)
01:00.0 VGA compatible controller: NVIDIA Corporation GA107M [GeForce RTX 3050 Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 2291 (rev a1)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980
2e:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980
2f:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
3- modinfo iwlwifi Output:
filename:       /usr/lib/modules/6.3.9-1-default/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.zst
license:        GPL
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-ty-a0-gf-a0.pnvm
firmware:       iwlwifi-so-a0-gf-a0.pnvm
firmware:       iwlwifi-so-a0-gf4-a0.pnvm
firmware:       iwlwifi-BzBnj-b0-fm-b0-74.ucode
firmware:       iwlwifi-gl-b0-fm-b0-74.ucode
firmware:       iwlwifi-bz-a0-fm4-a0-74.ucode
firmware:       iwlwifi-BzBnj-a0-hr-b0-74.ucode
firmware:       iwlwifi-BzBnj-a0-gf4-a0-74.ucode
firmware:       iwlwifi-BzBnj-a0-gf-a0-74.ucode
firmware:       iwlwifi-BzBnj-a0-fm4-a0-74.ucode
firmware:       iwlwifi-BzBnj-a0-fm-a0-74.ucode
firmware:       iwlwifi-gl-a0-fm-a0-74.ucode
firmware:       iwlwifi-bz-a0-fm-a0-74.ucode
firmware:       iwlwifi-bz-a0-mr-a0-74.ucode
firmware:       iwlwifi-bz-a0-gf4-a0-74.ucode
firmware:       iwlwifi-bz-a0-gf-a0-74.ucode
firmware:       iwlwifi-bz-a0-hr-b0-74.ucode
firmware:       iwlwifi-SoSnj-a0-mr-a0-74.ucode
firmware:       iwlwifi-ma-a0-fm-a0-74.ucode
firmware:       iwlwifi-ma-a0-mr-a0-74.ucode
firmware:       iwlwifi-ma-a0-gf4-a0-74.ucode
firmware:       iwlwifi-ma-a0-gf-a0-74.ucode
firmware:       iwlwifi-ma-a0-hr-b0-74.ucode
firmware:       iwlwifi-SoSnj-a0-jf-b0-74.ucode
firmware:       iwlwifi-SoSnj-a0-hr-b0-74.ucode
firmware:       iwlwifi-SoSnj-a0-gf-a0-74.ucode
firmware:       iwlwifi-SoSnj-a0-gf4-a0-74.ucode
firmware:       iwlwifi-ty-a0-gf-a0-74.ucode
firmware:       iwlwifi-so-a0-gf-a0-74.ucode
firmware:       iwlwifi-so-a0-hr-b0-74.ucode
firmware:       iwlwifi-so-a0-jf-b0-74.ucode
firmware:       iwlwifi-cc-a0-74.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-74.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-74.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-74.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-74.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-74.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-74.ucode
firmware:       iwlwifi-Qu-b0-hr-b0-74.ucode
suserelease:    openSUSE Tumbleweed
srcversion:     CC063B6947BC209EC42F700
alias:          pci:v00008086d00007740sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A840sv*sd*bc*sc*i*
alias:          pci:v00008086d0000272Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00002727sv*sd*bc*sc*i*
alias:          pci:v00008086d00007E40sv*sd*bc*sc*i*
alias:          pci:v00008086d00002729sv*sd*bc*sc*i*
alias:          pci:v00008086d00007F70sv*sd*bc*sc*i*
alias:          pci:v00008086d000054F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F1sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd*bc*sc*i*
alias:          pci:v00008086d00002726sv*sd*bc*sc*i*
alias:          pci:v00008086d00002725sv*sd*bc*sc*i*
alias:          pci:v00008086d00002723sv*sd*bc*sc*i*
alias:          pci:v00008086d00002720sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd*bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd*bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00002526sv*sd*bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211
retpoline:      Y
intree:         Y
vermagic:       6.3.9-1-default SMP preempt mod_unload modversions
sig_id:         PKCS#7
signer:         openSUSE Secure Boot CA
sig_key:        FA:BE:D8:BF:40:9A:5E:65
sig_hashalgo:   sha256
signature:      41:7F:46:29:18:D1:93:A4:45:1B:8A:9E:E2:E3:A7:B2:B0:CD:02:8E:
                9C:81:9B:A2:96:0D:91:9C:6A:63:F8:C4:50:77:93:A2:D7:0B:CD:71:
                B2:FB:01:76:26:D6:C9:2F:D9:F3:8E:3A:BF:52:B0:DF:C4:12:9D:DD:
                76:27:41:C5:C9:4F:A5:4B:E3:33:39:73:41:B7:E0:B6:A0:7E:AB:2D:
                A2:2F:73:DA:E5:C6:66:47:61:5A:3F:15:3D:51:2B:39:BE:47:AE:5D:
                48:66:57:21:9C:A2:0B:C9:08:78:0B:0B:EC:64:46:84:DF:E8:5C:05:
                F4:B0:7D:CC:B6:FB:6D:A1:EC:8F:3D:0F:B9:21:49:EC:1F:00:B4:6D:
                FA:F4:83:3E:D6:F8:13:70:19:0C:97:FB:FE:9F:F3:94:A1:32:D9:B9:
                00:A0:AE:E0:58:C8:E0:5F:50:19:58:73:84:95:17:C7:DC:EF:F9:8E:
                16:66:B0:53:71:C2:3F:DF:8B:6F:62:C8:1D:4E:79:1F:7E:0A:54:16:
                C5:3F:35:3F:55:CB:3F:9A:FC:FD:19:D4:21:0C:60:6C:7C:AF:E9:09:
                81:1F:30:BB:53:39:41:A9:19:90:F9:0D:42:1C:A2:48:FE:64:2A:F1:
                90:2A:FB:DC:5B:FD:C3:CC:9E:3F:71:9D:72:C6:4A:5F
parm:           debug:debug output mask (uint)
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           nvm_file:NVM file name (charp)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
parm:           disable_11be:Disable EHT capabilities (default: false) (bool)
4-  "lsmod | grep iwlwifi" Output:
iwlwifi               462848  1 iwlmvm
cfg80211             1277952  3 iwlmvm,iwlwifi,mac80211
5- "dmesg | grep iwlwifi" Output:
[    5.637537] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    5.673147] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    5.673157] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[    5.673343] iwlwifi 0000:00:14.3: loaded firmware version 74.a5e9588b.0 QuZ-a0-hr-b0-74.ucode op_mode iwlmvm
[    5.893229] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
[    6.914614] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[    6.914664] iwlwifi 0000:00:14.3: WFPM_LMAC1_PD_NOTIFICATION: 0xf
[    6.914673] iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x42
[    6.914682] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[    6.914691] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x0
[    6.914700] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[    6.914708] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[    6.914711] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    6.914819] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    6.914821] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 927640230
[    6.914822] iwlwifi 0000:00:14.3: Loaded firmware version: 74.a5e9588b.0 QuZ-a0-hr-b0-74.ucode
[    6.914824] iwlwifi 0000:00:14.3: 0x81C53B30 | ADVANCED_SYSASSERT
[    6.914825] iwlwifi 0000:00:14.3: 0x5B80615E | trm_hw_status0
[    6.914826] iwlwifi 0000:00:14.3: 0x607FD206 | trm_hw_status1
[    6.914827] iwlwifi 0000:00:14.3: 0xC23D63A9 | branchlink2
[    6.914828] iwlwifi 0000:00:14.3: 0x6945B4A7 | interruptlink1
[    6.914829] iwlwifi 0000:00:14.3: 0xD51E9340 | interruptlink2
[    6.914830] iwlwifi 0000:00:14.3: 0x105A78DF | data1
[    6.914831] iwlwifi 0000:00:14.3: 0x459A1874 | data2
[    6.914833] iwlwifi 0000:00:14.3: 0x7C84EE3F | data3
[    6.914834] iwlwifi 0000:00:14.3: 0xD0F4A30C | beacon time
[    6.914835] iwlwifi 0000:00:14.3: 0x0E886B95 | tsf low
[    6.914837] iwlwifi 0000:00:14.3: 0x2AD66915 | tsf hi
[    6.914838] iwlwifi 0000:00:14.3: 0x81DAD90E | time gp1
[    6.914840] iwlwifi 0000:00:14.3: 0xE0C94B09 | time gp2
[    6.914841] iwlwifi 0000:00:14.3: 0x58C79563 | uCode revision type
[    6.914842] iwlwifi 0000:00:14.3: 0x94A2849E | uCode version major
[    6.914844] iwlwifi 0000:00:14.3: 0x3829F904 | uCode version minor
[    6.914845] iwlwifi 0000:00:14.3: 0xD11A7089 | hw version
[    6.914847] iwlwifi 0000:00:14.3: 0x031F821E | board version
[    6.914848] iwlwifi 0000:00:14.3: 0x888852F4 | hcmd
[    6.914849] iwlwifi 0000:00:14.3: 0x5458FDEC | isr0
[    6.914851] iwlwifi 0000:00:14.3: 0x0507C2E8 | isr1
[    6.914852] iwlwifi 0000:00:14.3: 0x4870497E | isr2
[    6.914853] iwlwifi 0000:00:14.3: 0x9C35306B | isr3
[    6.914855] iwlwifi 0000:00:14.3: 0x863BBA2D | isr4
[    6.914856] iwlwifi 0000:00:14.3: 0x6D680767 | last cmd Id
[    6.914856] iwlwifi 0000:00:14.3: 0x8E0D3588 | wait_event
[    6.914857] iwlwifi 0000:00:14.3: 0x29C02AB8 | l2p_control
[    6.914858] iwlwifi 0000:00:14.3: 0x0D25ACC6 | l2p_duration
[    6.914859] iwlwifi 0000:00:14.3: 0x9236F036 | l2p_mhvalid
[    6.914860] iwlwifi 0000:00:14.3: 0xB6CDE5E0 | l2p_addr_match
[    6.914862] iwlwifi 0000:00:14.3: 0x3F641F40 | lmpm_pmg_sel
[    6.914863] iwlwifi 0000:00:14.3: 0xDBE9393A | timestamp
[    6.914864] iwlwifi 0000:00:14.3: 0x6E5019AD | flow_handler
[    6.914901] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    6.914901] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1941856124
[    6.914903] iwlwifi 0000:00:14.3: 0xAE4650BA | ADVANCED_SYSASSERT
[    6.914903] iwlwifi 0000:00:14.3: 0x636B4D91 | umac branchlink1
[    6.914904] iwlwifi 0000:00:14.3: 0xF91A29F5 | umac branchlink2
[    6.914905] iwlwifi 0000:00:14.3: 0x6A49CDFD | umac interruptlink1
[    6.914906] iwlwifi 0000:00:14.3: 0x03ED4367 | umac interruptlink2
[    6.914906] iwlwifi 0000:00:14.3: 0xCB75BFFF | umac data1
[    6.914907] iwlwifi 0000:00:14.3: 0xD05D6D66 | umac data2
[    6.914908] iwlwifi 0000:00:14.3: 0xF5F3CEB6 | umac data3
[    6.914909] iwlwifi 0000:00:14.3: 0x46044221 | umac major
[    6.914909] iwlwifi 0000:00:14.3: 0xD57168B9 | umac minor
[    6.914910] iwlwifi 0000:00:14.3: 0x0D394C22 | frame pointer
[    6.914911] iwlwifi 0000:00:14.3: 0x39DFAE6F | stack pointer
[    6.914912] iwlwifi 0000:00:14.3: 0x5ECEC180 | last host cmd
[    6.914912] iwlwifi 0000:00:14.3: 0xD778BD22 | isr status reg
[    6.914930] iwlwifi 0000:00:14.3: IML/ROM dump:
[    6.914931] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[    6.914932] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[    6.914940] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[    6.914948] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[    6.914953] iwlwifi 0000:00:14.3: Fseq Registers:
[    6.914955] iwlwifi 0000:00:14.3: 0xA32F83B6 | FSEQ_ERROR_CODE
[    6.914958] iwlwifi 0000:00:14.3: 0x8AD96FFD | FSEQ_TOP_INIT_VERSION
[    6.914961] iwlwifi 0000:00:14.3: 0x9E33BE4E | FSEQ_CNVIO_INIT_VERSION
[    6.914963] iwlwifi 0000:00:14.3: 0x34C62655 | FSEQ_OTP_VERSION
[    6.914966] iwlwifi 0000:00:14.3: 0xBBFFFDFF | FSEQ_TOP_CONTENT_VERSION
[    6.914987] iwlwifi 0000:00:14.3: 0xA9EFFAE2 | FSEQ_ALIVE_TOKEN
[    6.914991] iwlwifi 0000:00:14.3: 0x1026C470 | FSEQ_CNVI_ID
[    6.915012] iwlwifi 0000:00:14.3: 0xFF25FCFD | FSEQ_CNVR_ID
[    6.915015] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[    6.915067] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[    6.915151] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[    6.915235] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[    6.915256] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[    6.915257] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    7.171793] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=1, type=10
[    7.504922] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=1, type=10
[    7.838457] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[    7.850622] iwlwifi 0000:00:14.3: retry init count 0
[    7.855332] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
[    8.894699] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[    8.894726] iwlwifi 0000:00:14.3: WFPM_LMAC1_PD_NOTIFICATION: 0xf
[    8.894734] iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x42
[    8.894742] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[    8.894751] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x0
[    8.894759] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[    8.894767] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[    8.894768] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    8.894857] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    8.894858] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 894085806
[    8.894860] iwlwifi 0000:00:14.3: Loaded firmware version: 74.a5e9588b.0 QuZ-a0-hr-b0-74.ucode
[    8.894861] iwlwifi 0000:00:14.3: 0x81D13B30 | ADVANCED_SYSASSERT
[    8.894862] iwlwifi 0000:00:14.3: 0x7380615A | trm_hw_status0
[    8.894863] iwlwifi 0000:00:14.3: 0x607FD306 | trm_hw_status1
[    8.894863] iwlwifi 0000:00:14.3: 0xC2BD72A9 | branchlink2
[    8.894864] iwlwifi 0000:00:14.3: 0xED5DB5A6 | interruptlink1
[    8.894865] iwlwifi 0000:00:14.3: 0xD59E9550 | interruptlink2
[    8.894865] iwlwifi 0000:00:14.3: 0x104A505F | data1
[    8.894866] iwlwifi 0000:00:14.3: 0x45921A74 | data2
[    8.894867] iwlwifi 0000:00:14.3: 0x58C6CA2F | data3
[    8.894867] iwlwifi 0000:00:14.3: 0xD0D5232C | beacon time
[    8.894868] iwlwifi 0000:00:14.3: 0x0E886BD5 | tsf low
[    8.894869] iwlwifi 0000:00:14.3: 0x2ED62915 | tsf hi
[    8.894869] iwlwifi 0000:00:14.3: 0x819AD92E | time gp1
[    8.894870] iwlwifi 0000:00:14.3: 0xF2496A01 | time gp2
[    8.894871] iwlwifi 0000:00:14.3: 0x5847B523 | uCode revision type
[    8.894871] iwlwifi 0000:00:14.3: 0x90A2149E | uCode version major
[    8.894872] iwlwifi 0000:00:14.3: 0x2C28D804 | uCode version minor
[    8.894873] iwlwifi 0000:00:14.3: 0xD1185089 | hw version
[    8.894874] iwlwifi 0000:00:14.3: 0x231D861E | board version
[    8.894874] iwlwifi 0000:00:14.3: 0x889C5274 | hcmd
[    8.894875] iwlwifi 0000:00:14.3: 0x5750BDEC | isr0
[    8.894876] iwlwifi 0000:00:14.3: 0x0505C3E0 | isr1
[    8.894876] iwlwifi 0000:00:14.3: 0x4CF04B7A | isr2
[    8.894877] iwlwifi 0000:00:14.3: 0x9A11206A | isr3
[    8.894877] iwlwifi 0000:00:14.3: 0x0733BA2D | isr4
[    8.894878] iwlwifi 0000:00:14.3: 0x2D680767 | last cmd Id
[    8.894879] iwlwifi 0000:00:14.3: 0x9B052508 | wait_event
[    8.894879] iwlwifi 0000:00:14.3: 0x01C22AB1 | l2p_control
[    8.894880] iwlwifi 0000:00:14.3: 0x8925ACCC | l2p_duration
[    8.894881] iwlwifi 0000:00:14.3: 0x9236F07A | l2p_mhvalid
[    8.894881] iwlwifi 0000:00:14.3: 0xB4DD6760 | l2p_addr_match
[    8.894882] iwlwifi 0000:00:14.3: 0x5F7C1B50 | lmpm_pmg_sel
[    8.894883] iwlwifi 0000:00:14.3: 0xD2E97D22 | timestamp
[    8.894883] iwlwifi 0000:00:14.3: 0x6E5419AF | flow_handler
[    8.894928] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    8.894928] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 851336828
[    8.894929] iwlwifi 0000:00:14.3: 0x6E4650FE | ADVANCED_SYSASSERT
[    8.894930] iwlwifi 0000:00:14.3: 0x637BCD91 | umac branchlink1
[    8.894931] iwlwifi 0000:00:14.3: 0xF65E69F5 | umac branchlink2
[    8.894931] iwlwifi 0000:00:14.3: 0xA869CDFD | umac interruptlink1
[    8.894932] iwlwifi 0000:00:14.3: 0xA1E54367 | umac interruptlink2
[    8.894933] iwlwifi 0000:00:14.3: 0xCBF5BDFF | umac data1
[    8.894933] iwlwifi 0000:00:14.3: 0xD0DBFDC8 | umac data2
[    8.894934] iwlwifi 0000:00:14.3: 0xF7F1D7A2 | umac data3
[    8.894935] iwlwifi 0000:00:14.3: 0x068C4321 | umac major
[    8.894935] iwlwifi 0000:00:14.3: 0xDD5B49B9 | umac minor
[    8.894936] iwlwifi 0000:00:14.3: 0x8D090422 | frame pointer
[    8.894937] iwlwifi 0000:00:14.3: 0x61DFACEF | stack pointer
[    8.894937] iwlwifi 0000:00:14.3: 0x5E6CC880 | last host cmd
[    8.894938] iwlwifi 0000:00:14.3: 0xD7F9A563 | isr status reg
[    8.894968] iwlwifi 0000:00:14.3: IML/ROM dump:
[    8.894969] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[    8.894970] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[    8.894978] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[    8.894986] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[    8.894991] iwlwifi 0000:00:14.3: Fseq Registers:
[    8.894993] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_ERROR_CODE
[    8.894996] iwlwifi 0000:00:14.3: 0x8AD96FFD | FSEQ_TOP_INIT_VERSION
[    8.894998] iwlwifi 0000:00:14.3: 0x9E33BE4E | FSEQ_CNVIO_INIT_VERSION
[    8.895001] iwlwifi 0000:00:14.3: 0x34C62655 | FSEQ_OTP_VERSION
[    8.895003] iwlwifi 0000:00:14.3: 0xBBFFFDFF | FSEQ_TOP_CONTENT_VERSION
[    8.895006] iwlwifi 0000:00:14.3: 0xA9EFFAE2 | FSEQ_ALIVE_TOKEN
[    8.895008] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[    8.895011] iwlwifi 0000:00:14.3: 0xFF25FCFD | FSEQ_CNVR_ID
[    8.895013] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[    8.895047] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[    8.895111] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[    8.895176] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[    8.895178] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[    8.895179] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    9.151442] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=1, type=10
[    9.479684] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=1, type=10
[    9.811190] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[    9.823625] iwlwifi 0000:00:14.3: retry init count 1
[    9.830693] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
[   11.070749] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[   11.070796] iwlwifi 0000:00:14.3: WFPM_LMAC1_PD_NOTIFICATION: 0xf
[   11.070825] iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x42
[   11.070854] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[   11.070883] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x0
[   11.070912] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[   11.070941] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[   11.070946] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   11.071053] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[   11.071056] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 894086062
[   11.071061] iwlwifi 0000:00:14.3: Loaded firmware version: 74.a5e9588b.0 QuZ-a0-hr-b0-74.ucode
[   11.071065] iwlwifi 0000:00:14.3: 0x81CD7B34 | ADVANCED_SYSASSERT
[   11.071069] iwlwifi 0000:00:14.3: 0x598861DA | trm_hw_status0
[   11.071072] iwlwifi 0000:00:14.3: 0x607F5A06 | trm_hw_status1
[   11.071075] iwlwifi 0000:00:14.3: 0xC2BD73A9 | branchlink2
[   11.071078] iwlwifi 0000:00:14.3: 0x6947B586 | interruptlink1
[   11.071080] iwlwifi 0000:00:14.3: 0xD51E8740 | interruptlink2
[   11.071083] iwlwifi 0000:00:14.3: 0x115A58DF | data1
[   11.071086] iwlwifi 0000:00:14.3: 0x059A1A76 | data2
[   11.071089] iwlwifi 0000:00:14.3: 0x7C86EF7F | data3
[   11.071092] iwlwifi 0000:00:14.3: 0xC0F5238C | beacon time
[   11.071094] iwlwifi 0000:00:14.3: 0x4F086B85 | tsf low
[   11.071097] iwlwifi 0000:00:14.3: 0x2AF66915 | tsf hi
[   11.071100] iwlwifi 0000:00:14.3: 0x81CAD92A | time gp1
[   11.071102] iwlwifi 0000:00:14.3: 0xF1C94B09 | time gp2
[   11.071105] iwlwifi 0000:00:14.3: 0x58C7B501 | uCode revision type
[   11.071108] iwlwifi 0000:00:14.3: 0x94AA849E | uCode version major
[   11.071111] iwlwifi 0000:00:14.3: 0x3829F804 | uCode version minor
[   11.071114] iwlwifi 0000:00:14.3: 0xD1187089 | hw version
[   11.071117] iwlwifi 0000:00:14.3: 0x221F061E | board version
[   11.071120] iwlwifi 0000:00:14.3: 0x88885274 | hcmd
[   11.071123] iwlwifi 0000:00:14.3: 0x5670BDEC | isr0
[   11.071125] iwlwifi 0000:00:14.3: 0x050743E0 | isr1
[   11.071128] iwlwifi 0000:00:14.3: 0x48F0413E | isr2
[   11.071131] iwlwifi 0000:00:14.3: 0x9831006A | isr3
[   11.071134] iwlwifi 0000:00:14.3: 0xA6B3BA25 | isr4
[   11.071136] iwlwifi 0000:00:14.3: 0x2D690767 | last cmd Id
[   11.071139] iwlwifi 0000:00:14.3: 0x9F093709 | wait_event
[   11.071142] iwlwifi 0000:00:14.3: 0x01C13038 | l2p_control
[   11.071145] iwlwifi 0000:00:14.3: 0x0935ACC6 | l2p_duration
[   11.071148] iwlwifi 0000:00:14.3: 0x8236F073 | l2p_mhvalid
[   11.071151] iwlwifi 0000:00:14.3: 0xB6C86760 | l2p_addr_match
[   11.071154] iwlwifi 0000:00:14.3: 0x2F341F51 | lmpm_pmg_sel
[   11.071157] iwlwifi 0000:00:14.3: 0xDAE9773A | timestamp
[   11.071160] iwlwifi 0000:00:14.3: 0x6C5011AF | flow_handler
[   11.071202] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[   11.071204] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 851365500
[   11.071208] iwlwifi 0000:00:14.3: 0x6E46509E | ADVANCED_SYSASSERT
[   11.071211] iwlwifi 0000:00:14.3: 0x637BCD87 | umac branchlink1
[   11.071214] iwlwifi 0000:00:14.3: 0xE01A29F5 | umac branchlink2
[   11.071218] iwlwifi 0000:00:14.3: 0xA84185FD | umac interruptlink1
[   11.071220] iwlwifi 0000:00:14.3: 0x017B4123 | umac interruptlink2
[   11.071223] iwlwifi 0000:00:14.3: 0xCB75BFFF | umac data1
[   11.071226] iwlwifi 0000:00:14.3: 0xD0DD6D6C | umac data2
[   11.071229] iwlwifi 0000:00:14.3: 0xE5F3CE93 | umac data3
[   11.071232] iwlwifi 0000:00:14.3: 0x8E8542E3 | umac major
[   11.071235] iwlwifi 0000:00:14.3: 0xCC5B69B9 | umac minor
[   11.071237] iwlwifi 0000:00:14.3: 0x87390467 | frame pointer
[   11.071240] iwlwifi 0000:00:14.3: 0x69DFAE2F | stack pointer
[   11.071243] iwlwifi 0000:00:14.3: 0x146CC880 | last host cmd
[   11.071246] iwlwifi 0000:00:14.3: 0xD73B3522 | isr status reg
[   11.071278] iwlwifi 0000:00:14.3: IML/ROM dump:
[   11.071280] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[   11.071284] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[   11.071307] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[   11.071337] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[   11.071362] iwlwifi 0000:00:14.3: Fseq Registers:
[   11.071383] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_ERROR_CODE
[   11.071388] iwlwifi 0000:00:14.3: 0x8AD96FFD | FSEQ_TOP_INIT_VERSION
[   11.071410] iwlwifi 0000:00:14.3: 0x9E33BE4E | FSEQ_CNVIO_INIT_VERSION
[   11.071415] iwlwifi 0000:00:14.3: 0x34C62655 | FSEQ_OTP_VERSION
[   11.071437] iwlwifi 0000:00:14.3: 0xBBFFFDFF | FSEQ_TOP_CONTENT_VERSION
[   11.071442] iwlwifi 0000:00:14.3: 0xA9EFFAE2 | FSEQ_ALIVE_TOKEN
[   11.071464] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[   11.071468] iwlwifi 0000:00:14.3: 0xFF25FCFD | FSEQ_CNVR_ID
[   11.071490] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[   11.071526] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[   11.071610] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   11.071694] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   11.071714] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[   11.071718] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   11.328008] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=1, type=10
[   11.655982] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=1, type=10
[   11.987635] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[   12.000015] iwlwifi 0000:00:14.3: retry init count 2
6-  dmesg | grep “no suitable firmware found!”
nothing came up. No output.
Sorry for not getting back early.
Jocelyn_Intel
Empleados
10.508 Vistas
Hello, @HerrHofmann
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
HerrHofmann
Principiante
10.479 Vistas
Windows:
2- yes
3- yes
4- yes
Linux:
1- OpenSUSE Tumbleweed
Answers for 2,3,4,5 are available in the Appendix. There was no output for 6.
HerrHofmann
Principiante
10.478 Vistas
Jocelyn_Intel
Empleados
10.393 Vistas
Hello, @HerrHofmann
Have you tried a Clean installation of wireless drivers process using the System Manufacturer's driver? Make sure to choose the OS correctly.
Note: we recommend checking with your System Manufacturer and use the driver software provided by them to avoid potential installation incompatibilities. Intel supplies generic versions of Wireless Drivers for general purposes. Computer manufacturers might have changed the features, incorporated customizations, or made other changes to the Wireless driver software or software packaging.
If the issue persists, please provide us with an Intel® SSU report for Windows issue:
Note: Make sure to mark the box that says "everything" before pressing the Scan button. After that, click on "Next>" and select "Save" and then, attach the .txt file.
Also, please provide us with the debug data and dmesg logs:
  1. Please type: # dmesg | grep ASSERT . If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging  to extract dmesg and trace-cmd. If the output has value, please collect from the wiki FW dump too.
  2. Please type # dmesg > dmesg.log to get the dmesg logs.
  3. Replication steps to reproduce this issue.
Jocelyn M.
Jocelyn_Intel
Empleados
10.298 Vistas
Hello, @HerrHofmann
We are checking this thread and we would like to know if you were able to try the steps recommended. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Jocelyn_Intel
Empleados
10.214 Vistas
Hello, @HerrHofmann
We have not heard back from you, so we will proceed to close this thread now. If you need any additional assistance, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
chrisnagib
Principiante
6.859 Vistas
I need your help finding centos driver for wifi
Y_sh
Principiante
2.881 Vistas
I have the same laptop, the same module, and the same issue - reinstalling drivers and kernels did not work.
The issue was in the screw that holds the WiFi module. I think when the laptop is overheating, the screw expands due to temperature and affects the module. I simply removed the screw, which helped me. You can also isolate it with tape or something similar.
Responder
