Wireless
8661 Discussions
Intel AX210 preferred band setting for Debian OS
AlexWu2504
Is there any way to config preferred band of Intel AX210 for Debian OS? I would like to config preferred band to 6 GHz. Thanks.
Steven_Intel
Hello AlexWu2504,
I am going to research about this. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello AlexWu2504,
After working on this, please be aware that there is no way to set up a preferred band for the connection. Network Manager does not have such a setup. The only way is to hard-code preferred BSSID in wpa_supplicant.conf for wpa_supplicant to select once it detects the SSID (at 2.4GHz/5GHz/6GHz).
You may try the function 'wpa_scan_result_compar' in wpa_supplicant/scan.c or work with the wpa_supplicant team or disti.
If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
