Wireless
8578 Discussions
Intel AX210 "failed to evaluate _DSM" messages
NeilLee
Hi
I am trying to evaluate Intel AX210 on Nvidia's Jetson AGX Xavier platform.
My OS is Ubuntu 20.04 (Linux kernel version  5.10.104).
When I change the WIFI status from off to on, I always get following failed messages:
[ 117.271272] iwlwifi 0003:01:00.0: iwl_mvm_power_update_device Sending device power command with flags = 0x1
[ 117.271282] iwlwifi 0003:01:00.0: iwl_pcie_gen2_send_hcmd_sync Attempting to send sync command POWER_TABLE_CMD
[ 117.271289] iwlwifi 0003:01:00.0: iwl_pcie_gen2_send_hcmd_sync Setting HCMD_ACTIVE for command POWER_TABLE_CMD
[ 117.271299] iwlwifi 0003:01:00.0: iwl_pcie_gen2_enqueue_hcmd Sending command POWER_TABLE_CMD (01.77), seq: 0x000C, 12 bytes at 12[12]:0
[ 117.271462] iwlwifi 0003:01:00.0: iwl_pcie_hcmd_complete Clearing HCMD_ACTIVE for command POWER_TABLE_CMD
[ 117.271516] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 117.271725] iwlwifi 0003:01:00.0: iwl_acpi_get_dsm_object ACPI: DSM method invocation failed (rev: 0, func:2)
[ 117.271736] iwlwifi 0003:01:00.0: iwl_mvm_eval_dsm_indonesia_5g2 Failed to evaluate DSM function ENABLE_INDONESIA_5G2, ret=-2
[ 117.271756] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 117.271957] iwlwifi 0003:01:00.0: iwl_acpi_get_dsm_object ACPI: DSM method invocation failed (rev: 0, func:1)
[ 117.271965] iwlwifi 0003:01:00.0: iwl_mvm_eval_dsm_disable_srd Failed to evaluate DSM function DISABLE_SRD, ret=-2
[ 117.271982] iwlwifi 0003:01:00.0: iwl_pcie_gen2_send_hcmd_sync Attempting to send sync command MCC_UPDATE_CMD
[ 117.271987] iwlwifi 0003:01:00.0: iwl_pcie_gen2_send_hcmd_sync Setting HCMD_ACTIVE for command MCC_UPDATE_CMD
[ 117.271997] iwlwifi 0003:01:00.0: iwl_pcie_gen2_enqueue_hcmd Sending command MCC_UPDATE_CMD (01.c8), seq: 0x000D, 36 bytes at 13[13]:0
[ 117.272378] iwlwifi 0003:01:00.0: iwl_pcie_hcmd_complete Clearing HCMD_ACTIVE for command MCC_UPDATE_CMD
Although the WIFI  can work there, I still want to know what these failed messages means?
Is there any side effect there? How can I avoid failed messages?
n_scott_pearson
These are the result of bugs in the BIOS' ACPI tables. I would ask NVIDIA about them. AFAIK, they do not have anything to do with the AX210.
Hope this helps,
NeilLee
Seems NVidia enable CONFIG_ACPI option but doesn’t implement the APCI table in UEFI.
When CONFIG_ACPI is enabled, Intel AX210' driver will try to call the DSM function in ACPI table.
Thus the error message appears because of no ACPI table in UEFI.
I undef CONFIG_ACPI in the Intel AX210 driver source as a workaround.
So the message is gone.Provide the link as  same topic's discussion in Nvidia forum.
Intel AX210 “failed to evaluate _DSM” messages
