Wireless
8635 Discussions
Intel WiFi6 AX201 160Mhz not working in Ubuntu 18.04
glazze
Good evening,
I have just installed Ubuntu 18.04 LTS on my new notebook MSI Katana gf66 but a lot of harware is not working including Wifi.
I am posting some outputs that I hope can be useful:
uname -r
5.4.0-135-generic
sudo lshw -c network
*-network UNCLAIMED
description: Network controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: iomemory:610-60f memory:6103144000-6103147fff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: 15
serial: d8:bb:c1:f4:dc:2c
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.78.82 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:17 ioport:3000(size=256) memory:82104000-82104fff memory:82100000-82103fff
lspci -knn |grep Net
00:14.3 Network controller [0280]: Intel Corporation Device [8086:51f0] (rev 01)
lspci -vv -s 00:14.3
00:14.3 Network controller: Intel Corporation Device 51f0 (rev 01)
Subsystem: Intel Corporation Device 0074
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 255
Region 0: Memory at 6103144000 (64-bit, non-prefetchable) [disabled] [size=16K]
Capabilities: <access denied>
Here should be seen the kernel drivers used (that should be iwlwifi) but instead the output shows Interrupt: pin A routed to IRQ 255
lsmod | grep iwlwifi
no output
I installed the module iwlwifi and iwlmvm with sudo modprobe iwlwifi and sudo modprobe iwlmvm and now lsmod | grep iwlwifi shows
iwlmvm 385024 0
mac80211 856064 1 iwlmvm
iwlwifi 339968 1 iwlmvm
cfg80211 712704 3 iwlmvm,iwlwifi,mac80211
dmesg | grep iwlwifi
no output neither before nor after installing the iwlwifi module
Still anything working, I don't know where to put hands.
Thank you in advance for the support,
Guido
