Wireless
9031 Discussions
Intel AX210
DARIELGG10
compré una tarjeta intel ax210 para mi laptop hp y no funciona el bluetooth y la wifi la enciendo y se apaga sola además no reconoce las redes que hago
timo42heren
Debes tapar el pin 56 (en algunos casos también el pin 54) de la tarjeta AX210 con un trozo microscópico de cinta aislante o cinta Kapton antes de conectarla. El pin 56 controla el deshabilitado por software de la WiFi (W_DISABLE1#). Al bloquearlo, la laptop no puede forzar el apagado de la tarjeta
LohithG
Hi DARIELGG10 ,
Welcome to the Intel Support Community!
I am sorry to hear you are experiencing Wi-Fi and Bluetooth issues with your new Intel AX210 card on your HP laptop. To better understand the situation and guide you in the right direction, could you please help me with the following information?
  1. You mentioned you bought the card. Could you confirm if this was an aftermarket upgrade you installed yourself (replacing the original card), or if the laptop came with this card pre-installed from the factory? If it was a replacement, what was the original card model?
  2. Could you please open "Device Manager" in Windows, expand the "Network adapters" and "Bluetooth" sections, and let me know if you see any yellow warning symbols or any specific error messages/codes (like Code 10 or Code 43) when you double-click the Intel AX210 adapter?
  3. What is the exact model of your HP laptop?
I look forward to your answers so we can investigate the compatibility further and determine the next steps.
LohithG.
LohithG
Hi @DARIELGG10
I wanted to follow up regarding your Intel® AX210 wireless adapter issue.
Could you please provide the details requested in my previous post, specifically:
  • Whether the Intel AX210 was purchased separately and installed as an upgrade, or if it came pre-installed with the laptop.
  • Any error codes or warning symbols shown in Device Manager for the Intel® AX210 Wi-Fi or Bluetooth devices.
  • The exact HP laptop model.
Additionally, based on your earlier comment that you "bought an Intel AX210 card for my HP laptop", it appears the adapter may have been installed as an aftermarket upgrade. In that case, please note that wireless adapter compatibility is determined by the system manufacturer. Some OEM systems implement hardware, BIOS, or regulatory restrictions that may prevent certain wireless adapters from functioning properly, even if they are physically compatible.
For more information, please refer to the following Intel article:⁠Regulatory Information Regarding Wireless Hardware Installation or Upgrade
If the adapter was purchased separately and installed as an upgrade, I also recommend contacting HP to verify whether the Intel® AX210 is supported on your specific laptop model.
Once I receive the requested information, I will be happy to continue investigating the issue.
Lohith G.
LohithG
Hi DARIELGG10,
Since I have recommended reaching out to the system manufacturer (OEM) to confirm wireless adapter compatibility, I will be going ahead and closing this thread. Please note that this thread will no longer be monitored.
Should you need further assistance in the future, please feel free to create a new thread, and I will be happy to assist you.
Lohith G.
