Wireless
公告
8845 討論
Intel Bluetooth driver 23.**bleep** – intermittent HID disconnects with Corsair Harpoon RGB Wireless
Xaratin
初學者
6,791 檢視
I currently running into two issues using my mouse over Bluetooth with Intel BE201/AX201. The mouse that I am using is Corsair Harpoon RGB Wireless (Bluetooth mode)
Problem:
  • Pairing often fails and only succeeds after multiple retries.
  • Runtime has intermittent disconnects; the mouse auto-reconnects a few seconds later.
The same mouse pairs and works normally with other device (phone, iPad, and a laptop that does not use an Intel Bluetooth adapter).
Also worth to mention that the problem only happed with driver version 23.xx. My AX201 when using older firmware version pre 23 will not have this problem
I have try:
  • Latest iCUE + mouse firmware.
  • Clean reinstall of Intel BT 23.160
  • Disabled Windows power management for BT radio.
  • Cleared BT pairing list; re-paired.
  • Tested it at close range (next to computer).
Device:
Intel AX201 (Wifi card in PC)
Intel BE201 (Lenovo T14 gen 6)
0 積分
17 回應
DeancR_Intel
主席
6,726 檢視
Hi Xatarin,
Thank you for reaching out about the intermittent Bluetooth connectivity issues you're experiencing with your Corsair Harpoon RGB Wireless mouse when using Intel Bluetooth driver version 23.xx.
I appreciate the detailed information you've provided, including the troubleshooting steps you've already attempted (latest iCUE firmware, clean driver reinstall, power management settings, pairing list clearing, and close-range testing). Your observation that the issue only occurs with driver version 23.xx and not with pre-23 versions is particularly valuable for our investigation.
I notice you've mentioned two different Intel wireless products in your report:
  • Intel AX201 (WiFi card in PC)
  • Intel BE201 (Lenovo T14 gen 6)
To avoid confusion and ensure you receive focused support, I'd recommend creating separate support threads for each device if you're experiencing issues with both. This will allow us to provide targeted assistance for each specific hardware configuration.
For this current thread, which Intel wireless adapter would you like to focus on? Please let me know whether you'd like to concentrate on the Intel AX201 or the Intel BE201, and I'll provide specific troubleshooting steps for that particular device.
Once you clarify which device to focus on, I can provide targeted assistance for the Bluetooth connectivity issues with your Corsair mouse on that specific Intel wireless adapter.
Dean R.
Xaratin
初學者
6,695 檢視
Hi DeancR.
Sorry for the late reply.
I think for this thread. I want to focused on the Intel BE201 as I cannot downgrade to 22.xx driver.
DeancR_Intel
主席
6,657 檢視
Hi Xaratin,
Thank you for clarifying that you'd like to focus on the Intel BE201 adapter in your Lenovo T14 gen 6. I understand the frustration with the pairing failures and intermittent disconnects you're experiencing with your Corsair Harpoon RGB Wireless mouse, especially since this issue only manifests with the 23.xx driver versions.
Your observation that the same mouse works perfectly with other devices and that pre-23 drivers didn't have this issue provides valuable insight into the nature of this problem.
To help me analyze your Intel BE201 configuration and current driver setup, could you please run the Intel System Support Utility (SSU) and provide the generated report?
You can download SSU from: https://www.intel.com/content/www/us/en/support/articles/000005511/processors.html
After installation:
  1. Run Intel SSU as administrator
  2. Click "Everything" to scan all components
  3. Save the report and attach it to your response
This will give me detailed information about your current Bluetooth driver version, system configuration, and any potential conflicts that might be causing the HID disconnection issues with your mouse.
Dean R.
Xaratin
初學者
6,648 檢視
Hi DeanR.
I have uploaded the log file. I also check event viewer and found this errors when the mouse disconnected briefly.
Log Name:      System
Source:        BTHUSB
Date:          10/28/2025 4:35:08 PM
Event ID:      5
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Nam-Nguyen-Quoc
Description:
The Bluetooth driver expected an HCI event with a certain size but did not receive it.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="BTHUSB" />
    <EventID Qualifiers="49157">5</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2025-10-28T09:35:08.2809893Z" />
    <EventRecordID>45050</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="22916" />
    <Channel>System</Channel>
    <Computer></Computer>
    <Security />
  </System>
  <EventData>
    <Data>
    </Data>
    <Binary>00000A000100000000000000050005C057000000000000000000000000000000000000000000000001000000020000005702</Binary>
  </EventData>
</Event>
DeancR_Intel
主席
6,605 檢視
Hi Xaratin,
Thank you for providing the SSU report and the Event Viewer logs. The BTHUSB Event ID 5 error you've identified is very helpful - it shows the Bluetooth driver is experiencing HCI (Host Controller Interface) event size mismatches, which explains the intermittent disconnections with your Corsair mouse.
I can see you're currently running driver version 23.160.0.4. I'd like you to try the newer Lenovo OEM driver version 23.160.0.9, which may resolve these HCI communication issues.
Please follow these steps:
  1. Download the updated driver: https://pcsupport.lenovo.com/us/en/products/laptops-and-netbooks/thinkpad-t-series-laptops/thinkpad-t14-gen-6-type-21qc-21qd/21qd/downloads/driver-list/component?name=Bluetooth%20and%20Modem&id=631A1C55-4962-4A5C-B7FD-CB19B42CDF9F
  2. Perform a clean wireless installation following Intel's procedure: https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html
The clean installation process will ensure no remnants from the previous driver version interfere with the new installation, which is particularly important given the HCI event issues you're experiencing.
After installation, please test your Corsair mouse pairing and monitor for any disconnection events. The newer driver version should address the HCI event size mismatches shown in your Event Viewer logs.
Let me know how the testing goes with the updated driver.
Dean R.
Xaratin
初學者
6,505 檢視
Hi DeancR
I have doubled check that the newest driver WIFI and Bluetooth driver is installed
On Lenovo website, the newest driver for the WIFI is 23.160.0.4 and Bluetooth is 23.160.0.6 which is currently installed in my computer. I also double check with the update tool in Lenovo Vantage app which showed the same result.
Xaratin
初學者
6,384 檢視
Hi @DeancR_Intel . Are there any update on this ?
VonM_Intel
主席
6,310 檢視
Hello Xaratin,
Thank you for confirming that you’ve already installed the latest Wi-Fi and Bluetooth drivers from Lenovo’s website and verified them through the Lenovo Vantage app. Since your system is already using the most recent versions, we can safely rule out outdated software as the root cause.  As recommended by Dean, could you please try performing a clean wireless driver installation following Intel’s official procedure? This process helps ensure that no remnants of previous driver versions interfere with the new installation, which can be particularly important given the HCI event issues you’ve been encountering.
Once the clean installation is complete, please test your Corsair mouse pairing and observe whether any disconnection events still occur. The updated drivers should help resolve the HCI event size mismatch errors noted in your Event Viewer logs.
Von M.
DeancR_Intel
主席
6,142 檢視
Hello Xaratin,
Dean R.
Xaratin
初學者
6,114 檢視
Hi DeanR
I removed all of the driver in device manager (using view by driver option in windows 11) and install the driver again with no luck. The pairing issue. I also try to test it with my Beats Studio Buds that also have compatibility problem where the audio is working but the microphone will not work for some reason.
DeancR_Intel
主席
5,958 檢視
Hi Xaratin,
Thank you for the update on your troubleshooting progress. I can see you've performed a clean driver reinstallation by removing all drivers through Device Manager, but you're still experiencing the pairing issues with your Corsair mouse and now also encountering problems with your Beats Studio Buds.
Regarding your Beats Studio Buds microphone issue, have you checked the Windows audio settings to ensure the microphone is properly configured?
Please check if the Beats appear in both "Playback" and "Recording" devices in Sound Control Panel (right-click speaker icon > Sounds)
The combination of HID disconnection issues with your mouse and audio device problems with the Beats suggests we may need to explore additional troubleshooting options beyond driver reinstallation.
Please let me know the results of the microphone configuration check, and I'll provide further guidance based on your findings.
Dean R.
DeancR_Intel
主席
5,830 檢視
Hi Xaratin,
Dean R.
Xaratin
初學者
5,811 檢視
Hi DeanR.
Sorry for the slow response. I was quite busy last couple days.
For the mic it appear in both "Playback" and "Recording" devices in Sound Control Panel but no sound coming thought the device. Strangely, I try it with my AirPod Pro 2 and it still working normally.
DeancR_Intel
主席
5,695 檢視
Hi Xaratin,
Thank you for the detailed testing information regarding your Bluetooth connectivity issues.
Based on the selective compatibility problems you're experiencing with the Intel BE201. I need to check this internally and will get back to you once I have more information available.
Dean R.
DeancR_Intel
主席
5,563 檢視
Hi Xaratin,
Thank you for your patience, please try to unpair all the Bluetooth devices connected to the system. Let me know if you still encounter the issue once you have connected the devices via Bluetooth.
Dean R.
DeancR_Intel
主席
5,468 檢視
Hi Xaratin,
Dean R.
DeancR_Intel
主席
4,978 檢視
Hi Xaratin,
As you have been unresponsive, I will proceed to close this thread. If you wish to continue the discussion or need further assistance, please feel free to create a new thread. This will help us provide focused support and ensure your concerns are addressed effectively.
Dean R.
回覆
