Wireless
8851 Discussions
Intel® Centrino® Advanced-N 6200 AGN
GeorgeKerstholt
Hi, I am running Windows 10 64bit no problems whatsoever except for the last week the wireless will not turn on.!
Intel® Centrino® Advanced-N 6200 AGN,
the Intell diagnostics says it is running full blast, Microsoft troubleshooter says it is turned off. I do note that in the driver details it ow says:
Driver Details
Provider Microsoft
Version 15.4.1.1
Date 1/23/2013
 Uninstalling and rebooting and reinstalling does not work!! Any other suggestion?? It works great on an ethernet cable but i desperately do not wireless!
Help is appreciated!!!
Full details:
Driver Details
Provider Microsoft
Version 15.4.1.1
Date 1/23/2013
Device Details
Manufacturer Intel Corporation
Availability Running at full power
Status This device is working properly.
Installed True
MAC Address 18:3D:A2:55:64:C8
Service Name NETwNs64
Device Id PCI\VEN_8086&DEV_4239&SUBSYS_13118086&REV_35\183DA2FFFF5564C800
Revision 35
GeorgeKerstholt
Thank you n_scott_pearson!
The problem was not solved immediately bit the proper drivers for windows 0 came in handy!
Eventually i found a detailed instruction on https://support.microsoft.com/en-us/topic/9424a1f7-6a3b-65a6-4d78-7f07eee84d2c#WindowsVersion=Windows_10
and
https://windowsreport.com/wifi-stopped-working-update-windows-10/
After disabling IPv6 on both adapters (Ethernet and WiFi) and completely removing the WiFi adapter I rebooted. Installed the new Windows 10 driver for the wi-fi and noted that not much was changed.
It still did NOT work (Wi-Fi that is).
But than... I ran the HP Hardware troubleshooting tool. (you can download it from the P support page for your HP computer).
That concluded that everything was fine Except for the WiFi and automatically turned it back on!!
Thankfully it works!!
n_scott_pearson
George,
It is unclear whether the Centrino Advanced-N 6200 actually has Windows 10 support available from Intel (as opposed to Microsoft's compatibility driver), but my records link it to the Centrino Advanced-N 6150 which does seem to have support. I have drivers you can try; they may or may not work...
The driver files are too large to email or attach here. I have placed copies in a OneDrive share and sent a link to you via Private Message (PM). To read this PM, click on your avatar picture in the top right corner of the page (in the Communities blue banner) and then select Messages from the resulting menu.
Hope this helps,
GeorgeKerstholt
and
