Wireless
8606 Discussions
Intel Centrino Wireless-N 2230 802.11b / g / n 2 × 2 WiFi and Bluetooth Combo Adapter" windows 7 - 64bit
Boa tarde
necessito dos driveres direitos para o wireless e para o bluetooth, pois está-me a dar o erro da imagem. A questão é que com este erro não estou a conseguir utilizar o intel widi Intel Centrino Wireless-N 2230 802.11b / g / n 2 × 2 WiFi and Bluetooth Combo Adapter" windows 7 - 64bit
Kevin_M_Intel
Hi rmfsousa,
I am afraid to say I am having troubles to understand your question so would it be possible to translate this to English or Spanish?
Kevin M
good afternoon
I apologize, nor remembered this great point.
rights need drivers for the wireless and bluetooth, it is giving me the error image. The point is that with this error I am not able to use the intel widi
Intel Centrino Wireless-N 2230 802.11b / g / n 2 × 2 WiFi and Bluetooth Combo Adapter "windows 7 - 64bit
Ricardo
Kevin_M_Intel
Thank you for sharing this information. Code 10 on device manager most of times mean either the driver is corrupted or the device cannot start.
Before providing more troubleshooting steps, I would like to get information from your system so can you please provide your system information report? How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Attach using Advanced Editor Options.
System Information: Click Start> Type System Information> Click File> Export> Save File> Attach using Advanced Editor Options.
Kevin M
Hello
is attached files.
This problem arose in exchange for my original wireless card for this, you can use the intel widi with my TV from LG
Ricardo
Hello
always help me?
I have already put the attachments in another post.
Ricardo
Kevin_M_Intel
Based on the report your system has hybrid graphics. Please disable your HD 7670M graphics card since this can be causing the issue on the Intel® WiDi setup.
I noticed you have a very old graphics driver installed on the system so, please try installing the latest at this link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24593&lang=eng&ProdId=3712 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24593&lang=eng&ProdId=3712
If you find problems during the installation of the driver, try the steps mentioned here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Make sure the antivirus or firewalls are off so won't affect the connection.
Kevin M
Hello Kelvin_Intel
I need the link to the original drivers of the board.
Please can I get? to see if I can for this to work?
Thank U
Ricardo
ASouz7
Hello rmfsousa,
Please check your private messages.
Hello Aleki Intel
sorry have written Forums new in Portuguese, but addiction to speak in Portuguese.
The like to have the drivers for the bluetooth of my network card.
I leave attached the missing driver for the card (Intel Centrino Wireless-N 2230 802.11b / g / n 2 × 2 WiFi and Bluetooth Combo Adapter) for windows 7 - 64bit
I installed this card later, so it's not home and I'm having trouble putting the correct drivers.
I installed it so that my pc can be compatible with Intel Widi technology, which currently does not work and how missing drivers can not leave for other solutions.
And thank you for the help and sorry to have written in Portuguese.
Best Regards
Ricardo Sousa
Note:
ID Hardware
BTHENUM\{8e780202-0000-1000-8000-00805f9b34fb}_VID&00020fce_PID&01b8
BTHENUM\{8e780202-0000-1000-8000-00805f9b34fb}_LOCALMFG&000a
ASouz7
Hello rmfsousa,
This link below may help you with the installation of the correct Bluetooth* drivers for your Intel® Centrino® Advanced-N 2230. Now, try in this sequence.
First, please make sure you have your computer hard wired, that would connected to the router/modem via Ethernet cable, then clean uninstall all drivers from device manager. Once they completely uninstalled, reinstall them back as indicated below.
NOTE: You need to obey installation according to your operating system.
1 - Begin the installation by the Bluetooth drivers first.
2 - Then the install the other respective drivers
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3507 Intel® Download Center
Let us know if this information helped you.
Another very important thing we would like to tell you is that Intel does not support integrations and when the original wireless card installed by the manufacturer of your computer is changed this is an integration and for this you must consider that your computer manufacturer adapts the card to fit their system. We also highly recommend that you contact them as they are the only ones entitled to provide the list of certified and approved adapters that would fit their system. Check the link below for further information on integrations.
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm
Let us know if you if this information helped you.
Hello
I have visited the site of intel to download the driver, but did not work.
However, not started the installation ask bluetooth.
Can you send me the direct links of the respective downloads bluetooth and wireless.
For windows seven, 64bit.
How has a number of versions, it becomes a little confusing.
Just a note. When you say delete the drivers also speaks of bluetooth drivers, correct?
Ricardo
ASouz7
Hello rmfsouza,
Your Bluetooth drivers seem to be installed correctly, however, the unknown device could be from another Bluetooth adapter which is still installed in this computer apart from the previous wireless card. So probably, when the drivers were uninstalled, that piece of hardware became unrecognized by this computer. What was the model of the previous card installed? Was there any other Bluetooth device installed in this computer?
Hello
but one had installed bcm94313HMG8 Broadcom, however, since all referring to the same uninstalled.
Yesterday also installed another intel driver for my intel centrino.
Driver: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23996 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23996
The point is that when installing your computer does not recognize the certificates and then gives an error (example attached image)
How can I fix?
Best Regards
ASouz7
Hello rmfsousa,
It seems like your computer system was not designed to work properly with this adapter. In this case, please contact your computer manufacturer for a list of compatible adapters or if they have any specific drivers to help you resolve this issue.
Hello
as you can see through the HP Forums new link them said that this card was compatible with my model.
The forum is in Portuguese and I would ask that you use some means of translation if not understand.
http://h30487.www3.hp.com/t5/Hardware-para-notebooks/Tecnologia-Intel-Widi/mp/531220# M42664 http://h30487.www3.hp.com/t5/Hardware-para-notebooks/Tecnologia-Intel-Widi/mp/531220# M42664
The point is that now the drivers are all installed only the pc can not verify the digital signature of the drivers, and the driver was removed from the intel page.
Ricardo
ASouz7
Hello rmfsousa,
Thank you for the detailed information. Now regarding to your question sent on Feb 3, 2015 at 8:40 AM where you highlighted the " Dispositivos Periféricos" Bluetooth BTHENUM\{8e780202-0000-1000-8000-00805f9b34fb}_VID&00020fce_PID&01b8, this seems to be related to a Sony* device. Please take a look at the following links for reference.
Sony Forum:
http://talk.sonymobile.com/t5/Xperia-S-SL-acro-S/Xperia-S-Bluetooth-file-sharing-with-Windows-7-x64-Problem/td-p/338432 http://talk.sonymobile.com/t5/Xperia-S-SL-acro-S/Xperia-S-Bluetooth-file-sharing-with-Windows-7-x64-Problem/td-p/338432
Microsoft forum:
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/bluetooth-peripheral-device/10670136-ea6b-4de0-bb6f-a5f4c37a073a http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/bluetooth-peripheral-device/10670136-ea6b-4de0-bb6f-a5f4c37a073a
*NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Now, addressing your Bluetooth inquiries, Intel just uploaded new driver version 17.1.1411.01 at our download center. Please click on this link: https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3507 Intel® Download Center for the new drivers. We advise you to uninstall the current Bluetooth drivers first and then, install the new drivers.
