Wireless
8860 Discussions
Intel Connection Settings
I've a Lenovo T400 running Vista 64-bit with Intel 5350 wireless adapter and Cisco E4200v2 router. I'm facing a problem with the wireless connection where browsing stucks sometimes.
In the wireless connection properties, I do see an option to enable Intel connection setting. Is it a good idea to enable it because currently Lenovo access connection is managing it? One of the options is Cisco option to enable radio measurement. Does anyone know what it does and does it support the router I have?
If someone suggest proper and optimal settings for the adapter and router, that would be great.
Thanks in advance.
I suggest you to take a look at the following links, those are article numbers with different recommendations for better performance and connectivity issues:
What are the recommended settings for 802.11n connectivity?
http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=%28recommended+settings+n%29 http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=%28recommended+settings+n%29
Possible interference by other wireless devices may impact 802.11n performance
http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm
Data rate will not exceed 54 Mbps when WEP or TKIP encryption is configured
http://www.intel.com/support/wireless/wlan/4965agn/sb/cs-025643.htm http://www.intel.com/support/wireless/wlan/4965agn/sb/cs-025643.htm
Regarding the router, the recommendation will be to contact the router manufacturer for further assistance regarding the best configuration of the router.
Thanks I did go through those links but I still have issue with the wireless connection. It will just stuck for a couple of secs ~ 30-40secs and is happening frequently. I enabled wireless event log and I see following error once in a while ( not at the time when the connection stucks )
Roam trigger 161 RSSI=-40 MisBcn=8 RSSITh=-72 Roam other reason.
Any other idea what does it mean and how to fix the problem I've?
