Wireless
8963 Discussions
Intel Driver and Support Assistant: upgrade routine broken
bowlingblackberrycow
Intel Driver and Support Assistant regularly tries to upgrade a version that was already upgraded. This has happened at least 3 times, so I am posting about this bug here.
Affected drivers are:
  • Intel Wireless Bluetooth for Windows 10 and Windows 11
  • Windows 10 and Windows 11 WiFi Driver for Intel Wireless Adapter
Hardware: Lenovo T14s
I tried multiple times to restart my PC. No effect.
See screenshot below where Intel Driver and Support Assistant suggests to upgrade Bluetooth driver from version 22.190.0.2 to 22.190.0.2
LeonWaksman
Jean_Intel
Hello bowlingblackberrycow,
If I may jump into the conversation, I would like to first thank you for posting on the Intel️® communities.
Regarding the issue you described, I would like to recommend you reinstall the Intel Driver and Support Assistant following these steps:
  • Uninstall Intel® DSA via Control Panel.
  • Delete all old log files from C:\ProgramData\Intel\DSA.
  • Uninstall Intel® Computing Improvement Program or Intel® Product Improvement Program via Control Panel.
  • Restart the system.
  • Download the latest version of Intel® Driver & Support Assistant.
Jean O.
Steven_Intel
Steven G.
@Jean_Intel @Steven_Intel
It fixed itself after a few days, so I was not able to verify your suggestions. It seems after a few days Intel Driver and Support Assistant updates the version numbers and is able to perform the check for the installed versions correctly. Thanks for your feedback, I will try next time in case it occurs again.
Steven_Intel
Many thanks for your response.
I am glad to know the issue got solved. As for now, we will proceed to close this thread.
If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
