Wireless
8782 Discussions
Intel Dual Band 7260 AC - Version 17.1.0.19 Code 10 Still !!
JSmyt1
There is not much improvement in these drivers but now i get a extra line in my event view and srill code 10 error ( suspect its a resource issue )
i now get this
The description for Event ID 5010 from source NETwNb64 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\NDMP8
Intel(R) Dual Band Wireless-AC 7260
The specified resource type cannot be found in the image file
I will bott into ubuntu V14 and see what resources it using ... maybe that can point to something , would be nice if someone from intel could tell me what resources the driver is trying to allocate.
Kevin_M_Intel
Hi
I am sorry you are still having this problem.
Let me give a link where we are working on this issue so we can continue there:
/thread/54326?sr=stream&ru=316091 https://communities.intel.com/thread/54326?sr=stream&ru=316091
Kevin M
