Hi, I have an 8265 wifi adapter. I experience BSOD's randomly on system boot up, maybe every 2- 3 or so. I see this same topic in earlier posts where someone had the same issue then stated it was resolved,
Here is the debug of mini dump file. It is flagging the Netwtw06.sys file as the probable cause.
Microsoft (R) Windows Debugger Version 10.0.16299.91 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 16299 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 16299.15.amd64fre.rs3_release.170928-1534
Machine Name:
Kernel base = 0xfffff801`d2c9c000 PsLoadedModuleList = 0xfffff801`d3002fd0
Debug session time: Sun Jan 7 16:10:30.213 2018 (UTC + 3:00)
System Uptime: 0 days 4:36:23.158
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {ffff960631a00000, 2, fffff801d2e2566f, 2}
*** WARNING: Unable to verify timestamp for Netwtw06.sys
*** ERROR: Module load completed but symbols could not be loaded for Netwtw06.sys
Could not read faulting driver name
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : Netwtw06.sys ( Netwtw06+531eb9 )
Followup: MachineOwner
4: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffff960631a00000, memory referenced.
Arg2: 0000000000000002, value 0 = read operation, 1 = write operation.
Arg3: fffff801d2e2566f, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.16299.192 (WinBuild.160101.0800)
SYSTEM_MANUFACTURER: Timi
SYSTEM_PRODUCT_NAME: TM1701
BIOS_VENDOR: INSYDE Corp.
BIOS_VERSION: XMAKB5R0P0200
BIOS_DATE: 09/07/2017
BASEBOARD_MANUFACTURER: Timi
BASEBOARD_PRODUCT: TM1701
BASEBOARD_VERSION: MP
DUMP_TYPE: 2
BUGCHECK_P1: ffff960631a00000
BUGCHECK_P2: 2
BUGCHECK_P3: fffff801d2e2566f
BUGCHECK_P4: 2
READ_ADDRESS: fffff801d3098380: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
ffff960631a00000
FAULTING_IP:
nt!memcpy+af
fffff801`d2e2566f 660f7f41e0 movdqa xmmword ptr [rcx-20h],xmm0
MM_INTERNAL_CODE: 2
CPU_COUNT: 8
CPU_MHZ: 708
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 8e
CPU_STEPPING: a
CPU_MICROCODE: 6,8e,a,0 (F,M,S,R) SIG: 70'00000000 (cache) 70'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: System
CURRENT_IRQL: 0
ANALYSIS_SESSION_HOST: DESKTOP-9J1D3C6
ANALYSIS_SESSION_TIME: 01-07-2018 16:36:07.0613
ANALYSIS_VERSION: 10.0.16299.91 amd64fre
TRAP_FRAME: ffffb008f7dced90 -- (.trap 0xffffb008f7dced90)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000040000 rbx=0000000000000000 rcx=ffff960631a00020
rdx=00001dfb99dc0000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801d2e2566f rsp=ffffb008f7dcef28 rbp=0000000000000000
r8=0000000000000000 r9=0000000000000800 r10=00000000ffffffff
r11=ffff960631a00000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
nt!memcpy+0xaf:
fffff801`d2e2566f 660f7f41e0 movdqa xmmword ptr [rcx-20h],xmm0 ds:ffff9606`31a00000=????????????????????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff801d2e3b71d to fffff801d2e116e0
STACK_TEXT:
ffffb008`f7dceb18 fffff801`d2e3b71d : 00000000`00000050 ffff9606`31a00000 00000000`00000002 ffffb008`f7dced90 : nt!KeBugCheckEx
ffffb008`f7dceb20 fffff801`d2cebbbd : 00000000`00000002 ffff9606`31a00000 ffffb008`f7dced90 ffffb008`f7dcecc0 : nt!MiSystemFault+0x15151d
ffffb008`f7dcebc0 fffff801`d2e2074e : 00000000`00000000 ffffac80`03f95850 00000000`00000000 00000000`00000000 : nt!MmAccessFault+0x23d
ffffb008`f7dced90 fffff801`d2e2566f : fffff801`d313a48a 00000000`00000000 ffff9606`2a230830 ffff9606`31a00000 : nt!KiPageFault+0x40e
ffffb008`f7dcef28 fffff801`d313a48a : 00000000`00000000 ffff9606`2a230830 ffff9606`31a00000 ffff9606`2c6e34e0 : nt!memcpy+0xaf
ffffb008`f7dcef30 fffff801`d313a214 : 00000000`00040000 00000000`00040000 00000000`00c89848 ffffb008`f7dcf030 : nt!CcCopyBytesToUserBuffer+0x4a
ffffb008`f7dcef80 fffff801`d2cd2cbc : ffff9606`275c8260 00000000`00000000 00000000`00040000 ffff9606`29e58701 : nt!CcMapA...
- « Previous
- 1
- 2
- Next »
Hello Alex,
Thanks for confirming the solution.
It is good to know the blue screen crashes have stopped after updating the wireless drivers.
Let us know if there's anything else we can do for you.
Eugenio F.
Hello Alex,
Thanks for confirming the solution. It is good to know the blue screen crashes stopped after the driver update.
Eugenio F.
Just wanted to chime in and report the same kind of issue, with referenced memory BSODs and blame put on the intel wireless link drivers.
This has started happening about 3-5 weeks ago. Current version installed is 20.10.2.2, however, I'll try 20.2.2 and see if it helps.
Hello tohaklim,
Thanks for notifying us. Do you have an Intel® Dual Band Wireless-AC 8265 as well?
Also, have you test a https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html clean driver installation? We recommend testing this with both the latest Intel generic driver and the OEM (Original Equipment Manufacturer) driver.
Eugenio F.
Hi Eugenio. thanks for replying.
Yep, also an 8265. My OEM doesn't do much in terms of driver update/modification, hence it is close to stock Intel, if not stock.
The issue appears to be fixed on 22, no BSODs so far
Hello tohaklim,
Thanks for the update. It is good to know the blue screen crashes have stopped after the driver update.
Please notify us if the issue persists.
Eugenio F.
- « Previous
- 1
- 2
- Next »
