Wireless
8871 Discussions
Intel Dual Band Wireless AC 3160 Replacement
Horror484
Hello Intel,
I purchased a laptop 10 years ago, still working well, but my WiFi is not working well. Most of the time, I loose Internet connection while it is currently working on my phone for example. I detect the WiFi but it says "no Internet detected". Sometimes it works, but most of the time I loose the connection. I would like to replace the cheap (I understand that after 10years the chip is too old). My question is : With which product can be compatible for a replacement with a decent price ? I am meeting difficulties to find the same chip, because it has been replaced by more modern product. The laptop is a TERRA MOBILE 1529H.
Thank you,
n_scott_pearson
What card does your laptop have currently, 3160HMW or 3160NGW?
Horror484
n_scott_pearson
This is a little problematic as Intel is no longer producing its latest series of WLAN adapters in this formfactor. All is not lost; there are 3rd-parties that are taking the Intel Silicon and putting it onto cards with this formfactor. Here are some examples:
Note that these are examples. I chose them purely for being more-widely available (because available through Amazon). I have not tested these particular modules. The modules that I have tested are as follows:
I have tested these in both a 6th gen laptop (Core i5-6200U) and in a 4th gen desktop (Core i7-4770) using a PCIe x1 carrier card.
Hope this helps,
Sssc
What would be a suitable replacement for 3160NGW?
n_scott_pearson
Here are your options:
Product
Model No.
BT
STR
TP
Wireless-AC 3165
3165NGW
4.2
1x1
433
Wireless-AC 3168
3168NGW
4.2
1x1
433
Wireless-AC 7265
7265NGW
4.2
2x2
867
Wireless-AC 8265
8265NGW
4.2
2x2
867
Wireless-AC 9260
9260NGW
5.1
2x2
1733
Wi-Fi 6 AX200
AX200NGW
5.2
2x2
2400
Wi-Fi 6E AX210
AX210NGW
5.3
2x2
2400
  1.  BT – Bluetooth specification supported
  2. STR – Transmit/Receive Streams
  3. TP - Total throughput of channels supported (but you can really only use the one you are connected to).
Hope this helps,
MatheusAndrade
If I may reopen this thread, I have an old laptop which I would like to upgrade, below follows its specifications:
  • Product name: S14BW01;
  • Processor type: Intel(R) Celeron(R) CPU N3060 @ 1.60GHz;
  • Wireless card: Intel Dual Band Wireless AC 3160NGW.
The recommended options for the NGW are also valid for my model?
Thanks and regards.
n_scott_pearson
Yes, they certainly are. But, understand that the 3100 Series, 7200 Series and most of the 8000 Series modules and cards are discontinued and no longer supported by Intel.
  • If you want to stick with Wireless-AC support, the Wireless-AC 9260 (9260NGW) is your best bet (there are others, but their performance is lower).
  • The better tier (IMHO) is that of the Wireless-AX modules. The AX200 (AX200NGW) gives you support for WiFI 6 and Bluetooth 5.1, The AX210 (AX210NGW) gives you support for WiFi 6e (i.e. the 6.0 GHz band) and Bluetooth 5.3. Both are backwards compatible with WiFi 5 and Wireless-AC, so no concerns there.
  • While I haven't played with one to be comfortable recommending it as yet, there is also the BE200 (BE200NGW) module, which takes you into the realm of WiFi 7 and Bluetooth 5.4. [ASIDE: It is the ridiculous cost of the corresponding routers that is preventing me from making this transition.]
Hope this helps,
MatheusAndrade
Hello.
I just bought an AX210 and installed it in my laptop motherboard, however I am having some issues with it: the OS simply does not recognize it. Beforehand, I attach the description of my machine below.
- Product name: S14BW01;
- Processor type: Intel(R) Celeron(R) CPU N3060 @ 1.60GHz; And
- Previous wireless card: Intel Dual Band Wireless AC 3160NGW.
Below are the settings of my OS.
# uname-a
Linux myusername 6.8.0-31-generic #31-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 20 00:40:06 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
And below the lspci result.
# lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register (rev 35)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller (rev 35)
00:13.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SATA Controller (rev 35)
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 35)
00:1a.0 Encryption controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine (rev 35)
00:1b.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller (rev 35)
00:1c.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #1 (rev 35)
00:1c.1 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #2 (rev 35)
00:1c.2 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #3 (rev 35)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU (rev 35)
00:1f.3 SMBus: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx SMBus Controller (rev 35)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
02:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 12)
The command lshw, shows AX210 as a bluetooth device, which I think it is expected, however, not mention of the AX210 as a wireless device.
*-usb
description: Bluetooth wireless interface
    product: AX210 Bluetooth
vendor: Intel Corp.
    physical id: 2
bus info: usb@1:5.2
    version: 0.00
capabilities: bluetooth usb-2.01
    configuration: driver=btusb maxpower=100mA speed=12Mbit/s
The full lshw output is presented at the end of this post, I am postponing this for easening the reading.
The ifconfig returns the following output.
# ifconfig
ens1f1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.214  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::54da:ba7:9ccd:4102  prefixlen 64  scopeid 0x20<link>
        inet6 2a02:1811:d3a:c800:934f:84c1:c351:77ea  prefixlen 64  scopeid 0x0<global>
        inet6 2a02:1811:d3a:c800:d83:cbc1:1fb8:1bf8  prefixlen 64  scopeid 0x0<global>
        ether 80:ee:73:d0:41:8f  txqueuelen 1000  (Ethernet)
        RX packets 38470  bytes 39115681 (39.1 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 7418  bytes 1945697 (1.9 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 2293  bytes 179808 (179.8 KB)
        TX packets 2293  bytes 179808 (179.8 KB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 52:54:00:cb:d3:c9  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
The hwinfo returns the following.
# hwinfo --network --short
network interface:
  ens1f1               Ethernet network interface
  lo                   Loopback network interface
  virbr0               Ethernet network interface
Do I have to install the drivers? I mean, as far as I know, in order to install the drivers, the computer must at least be able to "see" the device, is my reasoning right?
Thanks and regards.
The full lshw output:
# lshw
myusername
    description: Notebook
    product: S14BW01 (3052122)
    vendor: Positivo Informatica SA
    version: 1.06.X
    serial: 4A413W48F
    width: 64 bits
    capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
    configuration: boot=normal chassis=notebook family=S14BW01 sku=3052122 uuid=38b1801d-c170-aadf-304b-80ee73d0418f
  *-core
       description: Motherboard
       product: S14BW01
       physical id: 0
       version: To be filled by O.E.M.
       serial: 4A413W48F
       slot: To be filled by O.E.M.
     *-firmware
          description: BIOS
          vendor: American Megatrends Inc.
          physical id: 0
          version: 1.06.X
          date: 08/18/2016
          capacity: 5MiB
          capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
     *-memory
          description: System Memory
          physical id: 28
          slot: System board or motherboard
        *-bank:0
             description: DIMM DDR3 1600 MHz (0.6 ns)
             product: M471B1G73BH0-YK0
             vendor: Samsung
             physical id: 0
             serial: 2301018F
             slot: A1_DIMM0
             width: 64 bits
             clock: 1600MHz (0.6ns)
        *-bank:1
             description: DIMM [empty]
             product: Array1_PartNumber1
             vendor: A1_Manufacturer1
             physical id: 1
             serial: A1_SerNum1
             slot: A1_DIMM1
     *-cache:0
          description: L1 cache
          physical id: 36
          slot: CPU Internal L1
          capacity: 112KiB
          capabilities: internal write-back
          configuration: level=1
     *-cache:1
          description: L2 cache
          physical id: 37
          slot: CPU Internal L2
          capacity: 2MiB
          capabilities: internal write-back unified
          configuration: level=2
     *-cpu
          description: CPU
          product: Intel(R) Celeron(R) CPU  N3060  @ 1.60GHz
          vendor: Intel Corp.
          physical id: 38
          bus info: cpu@0
          version: 6.76.4
          slot: SOCKET 0
          width: 64 bits
          clock: 80MHz
          capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl xtopology tsc_reliable nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes rdrand lahf_lm 3dnowprefetch epb pti ibrs ibpb stibp tpr_shadow flexpriority ept vpid tsc_adjust smep erms dtherm ida arat vnmi md_clear cpufreq
          configuration: cores=2 enabledcores=2 microcode=1041 threads=2
     *-pci
          description: Host bridge
          product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 35
          width: 32 bits
          clock: 33MHz
          configuration: driver=iosf_mbi_pci
          resources: irq:0
        *-display
             description: VGA compatible controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller
             physical id: 2
             bus info: pci@0000:00:02.0
             logical name: /dev/fb0
             version: 35
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi vga_controller bus_master cap_list rom fb
             configuration: depth=32 driver=i915 latency=0 resolution=1366,768
             resources: irq:124 memory:80000000-80ffffff memory:90000000-9fffffff ioport:f000(size=64) memory:c0000-dffff
        *-sata
             description: SATA controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SATA Controller
             physical id: 13
             bus info: pci@0000:00:13.0
             logical name: scsi0
             version: 35
             width: 32 bits
             clock: 66MHz
             capabilities: sata msi pm ahci_1.0 bus_master cap_list emulated
             configuration: driver=ahci latency=0
             resources: irq:120 ioport:f060(size=32) memory:81315000-813157ff
           *-disk
                description: ATA Disk
                product: KINGSTON SA400S3
                physical id: 0.0.0
                bus info: scsi@0:0.0.0
                logical name: /dev/sda
                version: Z1.3
                serial: 50026B728346B514
                capabilities: gpt-1.00 partitioned partitioned:gpt
                configuration: ansiversion=5 guid=41ad8919-c97e-429c-8605-0764bb24d5de logicalsectorsize=512 sectorsize=512
              *-volume:0 UNCLAIMED
                   description: Windows FAT volume
                   vendor: mkfs.fat
                   physical id: 1
                   bus info: scsi@0:0.0.0,1
                   version: FAT32
                   serial: b279-b01e
                   capacity: 299MiB
                   capabilities: boot fat initialized
                   configuration: FATs=2 filesystem=fat
              *-volume:1
                   description: EXT4 volume
                   vendor: Linux
                   physical id: 2
                   bus info: scsi@0:0.0.0,2
                   logical name: /dev/sda2
                   logical name: /
                   logical name: /var/snap/firefox/common/host-hunspell
                   version: 1.0
                   serial: 7bf8d763-281b-4a63-af34-9f97c66368e2
                   capacity: 893GiB
                   capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                   configuration: created=2024-05-11 13:49:02 filesystem=ext4 label=lubuntu_2404 lastmountpoint=/ modified=2024-05-30 17:55:06 mount.fstype=ext4 mount.options=ro,noexec,noatime,discard mounted=2024-05-30 17:55:08 name=lubuntu_2404 state=mounted
        *-usb
             description: USB controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 35
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:118 memory:81300000-8130ffff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 6.8.0-31-generic xhci-hcd
                physical id: 0
                bus info: usb@1
                logical name: usb1
                version: 6.08
                capabilities: usb-2.00
                configuration: driver=hub slots=7 speed=480Mbit/s
              *-usb:0
                   description: Mouse
                   product: USB Optical Mouse
                   vendor: Sunplus Innovation Technology Inc.
                   physical id: 1
                   bus info: usb@1:1
                   logical name: input11
                   logical name: /dev/input/event10
                   logical name: /dev/input/mouse1
                   logical name: input12
                   logical name: /dev/input/event11
                   version: 0.14
                   capabilities: usb-2.00 usb
                   configuration: driver=usbhid maxpower=98mA speed=2Mbit/s
              *-usb:1
                   description: Keyboard
                   product: Logitech USB Keyboard
                   vendor: Logitech
                   physical id: 2
                   bus info: usb@1:2
                   logical name: input13
                   logical name: /dev/input/event12
                   logical name: input13::capslock
                   logical name: input13::compose
                   logical name: input13::kana
                   logical name: input13::numlock
                   logical name: input13::scrolllock
                   logical name: input14
                   logical name: /dev/input/event13
                   version: 62.00
                   capabilities: usb-1.10 usb
                   configuration: driver=usbhid maxpower=90mA speed=2Mbit/s
              *-usb:2
                   description: Video
                   product: VGA WebCam
                   vendor: Chicony Electronics Co.,Ltd.
                   physical id: 3
                   bus info: usb@1:3
                   version: 14.01
                   serial: 0x0001
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
              *-usb:3
                   description: USB hub
                   product: USB2.0 Hub
                   vendor: Genesys Logic, Inc.
                   physical id: 5
                   bus info: usb@1:5
                   version: 85.37
                   configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
                 *-usb
                      vendor: Intel Corp.
                      physical id: 2
                      bus info: usb@1:5.2
                      version: 0.00
           *-usbhost:1
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 6.08
                capabilities: usb-3.00
                configuration: driver=hub slots=6 speed=5000Mbit/s
        *-generic
             description: Encryption controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine
             physical id: 1a
             bus info: pci@0000:00:1a.0
             version: 35
             width: 32 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_txe latency=0
             resources: irq:123 memory:81100000-811fffff memory:81000000-810fffff
        *-multimedia
             description: Audio device
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             logical name: card0
             logical name: /dev/snd/controlC0
             logical name: /dev/snd/hwC0D0
             logical name: /dev/snd/hwC0D2
             logical name: /dev/snd/pcmC0D0c
             logical name: /dev/snd/pcmC0D0p
             logical name: /dev/snd/pcmC0D3p
             version: 35
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=0
             resources: irq:125 memory:81310000-81313fff
           *-input:0
                product: HDA Intel PCH HDMI/DP,pcm=3
                physical id: 0
                logical name: input10
                logical name: /dev/input/event9
           *-input:1
                product: HDA Intel PCH Mic
                physical id: 1
                logical name: input8
                logical name: /dev/input/event7
           *-input:2
                product: HDA Intel PCH Headphone
                physical id: 2
                logical name: input9
                logical name: /dev/input/event8
        *-pci:0
             description: PCI bridge
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: 35
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:115 ioport:1000(size=4096) memory:81400000-815fffff ioport:81600000(size=2097152)
        *-pci:1
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #2
             physical id: 1c.1
             bus info: pci@0000:00:1c.1
             version: 35
             width: 32 bits
             clock: 33MHz
             resources: irq:116 ioport:e000(size=4096) memory:81200000-812fffff ioport:81800000(size=2097152)
           *-generic
                description: MMC Host
                product: RTL8411B PCI Express Card Reader
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: mmc0
                version: 01
                width: 32 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list rom
                configuration: driver=rtsx_pci latency=0
                resources: irq:119 memory:81215000-81215fff memory:81200000-8120ffff
           *-network
                description: Ethernet interface
                product: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
                physical id: 0.1
                bus info: pci@0000:02:00.1
                logical name: ens1f1
                version: 12
                serial: 80:ee:73:d0:41:8f
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.8.0-31-generic duplex=full firmware=rtl8411-2_0.0.1 07/08/13 ip=192.168.0.214 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
                resources: irq:17 ioport:e000(size=256) memory:81214000-81214fff memory:81210000-81213fff
        *-pci:2
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #3
             physical id: 1c.2
             bus info: pci@0000:00:1c.2
             version: 35
             width: 32 bits
             clock: 33MHz
             resources: irq:117
        *-isa
             description: ISA bridge
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 35
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             resources: irq:0
           *-pnp00:00
                product: PnP device PNP0b00
                physical id: 0
                capabilities: pnp
                configuration: driver=rtc_cmos
           *-pnp00:01
                product: PnP device PNP0c02
                physical id: 1
                capabilities: pnp
                configuration: driver=system
           *-pnp00:02
                product: PnP device PNP0303
                physical id: 2
                capabilities: pnp
                configuration: driver=i8042 kbd
           *-pnp00:03
                product: PnP device SYN2901
                vendor: Synaptics Inc
                physical id: 3
                capabilities: pnp
                configuration: driver=i8042 aux
           *-pnp00:04
                physical id: 4
                capabilities: pnp
           *-pnp00:05
                physical id: 5
                capabilities: pnp
           *-pnp00:06
                physical id: 6
                capabilities: pnp
           *-pnp00:07
                physical id: 7
                capabilities: pnp
           *-pnp00:08
                physical id: 8
                capabilities: pnp
           *-pnp00:09
                physical id: 9
                capabilities: pnp
           *-pnp00:0a
                physical id: a
                capabilities: pnp
           *-pnp00:0b
                physical id: b
                capabilities: pnp
           *-pnp00:0c
                physical id: c
                capabilities: pnp
           *-pnp00:0d
                physical id: d
                capabilities: pnp
           *-pnp00:0e
                physical id: e
                capabilities: pnp
           *-pnp00:0f
                physical id: f
                capabilities: pnp
           *-pnp00:10
                physical id: 10
                capabilities: pnp
           *-pnp00:11
                physical id: 11
                capabilities: pnp
           *-pnp00:12
                physical id: 12
                capabilities: pnp
           *-pnp00:13
                physical id: 13
                capabilities: pnp
           *-pnp00:14
                physical id: 14
                capabilities: pnp
           *-pnp00:15
                physical id: 15
                capabilities: pnp
           *-pnp00:16
                physical id: 16
                capabilities: pnp
           *-pnp00:17
                physical id: 17
                capabilities: pnp
        *-serial
             description: SMBus
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 35
             width: 32 bits
             clock: 33MHz
             capabilities: pm cap_list
             configuration: driver=i801_smbus latency=0
             resources: irq:18 memory:81314000-8131401f ioport:f040(size=32)
  *-battery:0
       description: Nickel Cadmium Battery
       product: Battery Name
       vendor: Battery Manufacturer
       physical id: 1
       version: 01/01/2012
       serial: Serial Number
       slot: Location of the battery
  *-battery:1
       physical id: 2
       version: 01/01/2012
  *-battery:2
       physical id: 3
       version: 01/01/2012
  *-battery:3
       physical id: 4
       version: 01/01/2012
  *-input:0
       product: Power Button
       physical id: 5
       logical name: input0
       logical name: /dev/input/event0
       capabilities: platform
  *-input:1
       product: Sleep Button
       physical id: 6
  *-input:2
       product: Lid Switch
       physical id: 7
       logical name: input2
       logical name: /dev/input/event2
  *-input:3
       physical id: 8
       logical name: input3
       logical name: /dev/input/event3
  *-input:4
       product: AT Translated Set 2 keyboard
       physical id: 9
       logical name: input4
       logical name: /dev/input/event4
       logical name: input4::capslock
       logical name: input4::numlock
       logical name: input4::scrolllock
       capabilities: i8042
  *-input:5
       product: SynPS/2 Synaptics TouchPad
       physical id: a
       logical name: input6
       logical name: /dev/input/event5
       logical name: /dev/input/mouse0
       capabilities: i8042
  *-input:6
       product: Video Bus
       physical id: b
       logical name: input7
       logical name: /dev/input/event6
The dmdidecode result.
# dmidecode
# dmidecode 3.5
Getting SMBIOS data from sysfs.
SMBIOS 2.8 present.
55 structures occupying 2529 bytes.
Table at 0x7787F000.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 1.06.X
Release Date: 08/18/2016
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 5 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 1.6
Firmware Revision: 1.5
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Positivo Informatica SA
Product Name: S14BW01
Version: 1.06.X
Serial Number: 4A413W48F
UUID: 38b1801d-c170-aadf-304b-80ee73d0418f
Wake-up Type: Power Switch
SKU Number: 3052122
Family: S14BW01
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Version: To be filled by O.E.M.
Asset Tag: To be filled by O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To be filled by O.E.M.
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
SKU Number: 3052122
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: PS2Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0009, DMI type 8, 9 bytes
External Reference Designator: Keyboard
Port Type: Keyboard Port
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: J2A1
External Reference Designator: TV Out
External Connector Type: Mini Centronics Type-14
Port Type: Other
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: J2A2A
External Reference Designator: COM A
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: J2A2B
External Reference Designator: Video
External Connector Type: DB-15 female
Port Type: Video Port
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: J3A1
External Reference Designator: USB1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: USB2
Port Type: USB
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: USB3
Port Type: USB
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: J9A1 - TPM HDR
Internal Connector Type: Other
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: J9C1 - PCIE DOCKING CONN
Port Type: Other
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: J2B3 - CPU FAN
Port Type: Other
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: J6C2 - EXT HDMI
Port Type: Other
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: J3C1 - GMCH FAN
Port Type: Other
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: J1D1 - ITP
Port Type: Other
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: J9E2 - MDC INTPSR
Port Type: Other
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: J9E4 - MDC INTPSR
Port Type: Other
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: J9E3 - LPC HOT DOCKING
Port Type: Other
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: J9E1 - SCAN MATRIX
Port Type: Other
Handle 0x001A, DMI type 8, 9 bytes
Internal Reference Designator: J9G1 - LPC SIDE BAND
Port Type: Other
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: J8F1 - UNIFIED
Port Type: Other
Handle 0x001C, DMI type 8, 9 bytes
Internal Reference Designator: J6F1 - LVDS
Port Type: Other
Handle 0x001D, DMI type 8, 9 bytes
Internal Reference Designator: J2F1 - LAI FAN
Port Type: Other
Handle 0x001E, DMI type 8, 9 bytes
Internal Reference Designator: J2G1 - GFX VID
Port Type: Other
Handle 0x001F, DMI type 8, 9 bytes
Internal Reference Designator: J1G6 - AC JACK
Port Type: Other
Handle 0x0020, DMI type 9, 17 bytes
System Slot Information
Designation: J6B2
Type: x16 PCI Express
Current Usage: In Use
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Bus Address: 0000:00:01.0
Handle 0x0021, DMI type 9, 17 bytes
Designation: J6B1
Type: x1 PCI Express
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:00:1c.3
Handle 0x0022, DMI type 9, 17 bytes
Designation: J6D1
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:00:1c.4
Handle 0x0023, DMI type 9, 17 bytes
Designation: J7B1
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:00:1c.5
Handle 0x0024, DMI type 9, 17 bytes
Designation: J8B4
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:00:1c.6
Handle 0x0025, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description:    To Be Filled By O.E.M.
Handle 0x0026, DMI type 11, 5 bytes
OEM Strings
String 1: To Be Filled By O.E.M.
Handle 0x0027, DMI type 12, 5 bytes
System Configuration Options
Option 1: To Be Filled By O.E.M.
Handle 0x0028, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 8 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0029, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x001FFFFFFFF
Range Size: 8 GB
Physical Array Handle: 0x0028
Partition Width: 2
Handle 0x002A, DMI type 17, 40 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A1_DIMM0
Bank Locator: A1_BANK0
Type: DDR3
Type Detail: Unknown
Speed: 1600 MT/s
Manufacturer: Samsung
Serial Number: 2301018F
Asset Tag: A1_AssetTagNum0
Part Number: M471B1G73BH0-YK0
Rank: 2
Configured Memory Speed: 1600 MT/s
Minimum Voltage: 1.35 V
Maximum Voltage: 1.5 V
Configured Voltage: 1.35 V
Handle 0x002B, DMI type 20, 35 bytes
Memory Device Mapped Address
Range Size: 8 GB
Physical Device Handle: 0x002A
Memory Array Mapped Address Handle: 0x0029
Partition Row Position: Unknown
Interleave Position: 1
Interleaved Data Depth: 2
Handle 0x002C, DMI type 17, 40 bytes
Memory Device
Total Width: Unknown
Data Width: 64 bits
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: A1_DIMM1
Bank Locator: A1_BANK1
Type: Unknown
Handle 0x002D, DMI type 126, 35 bytes
Inactive
Handle 0x002E, DMI type 22, 26 bytes
Portable Battery
Manufacturer: Battery Manufacturer
Manufacture Date: 01/01/2012
Serial Number: Serial Number
Chemistry: Nickel Cadmium
Design Capacity: Unknown
Design Voltage: Unknown
SBDS Version: SBDS Version Number
Maximum Error: Unknown
OEM-specific Information: 0x12345678
Handle 0x002F, DMI type 22, 26 bytes
Portable Battery
Handle 0x0030, DMI type 22, 26 bytes
Portable Battery
Handle 0x0031, DMI type 22, 26 bytes
Portable Battery
Handle 0x0032, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0033, DMI type 41, 11 bytes
Onboard Device
Reference Designation:  Onboard IGD
Type: Video
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:02.0
Handle 0x0034, DMI type 41, 11 bytes
Onboard Device
Reference Designation:  Onboard LAN
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:19.0
Handle 0x0035, DMI type 41, 11 bytes
Onboard Device
Reference Designation:  Onboard 1394
Type: Other
Status: Enabled
Type Instance: 1
Bus Address: 0000:03:1c.2
Handle 0x0036, DMI type 7, 19 bytes
Cache Information
Socket Designation: CPU Internal L1
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 112 kB
Maximum Size: 112 kB
Supported SRAM Types:
Unknown
Installed SRAM Type: Unknown
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Other
Associativity: Other
Handle 0x0037, DMI type 7, 19 bytes
Cache Information
Socket Designation: CPU Internal L2
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 2 MB
Maximum Size: 2 MB
Unknown
Speed: Unknown
System Type: Unified
Associativity: 16-way Set-associative
Handle 0x0038, DMI type 4, 42 bytes
Processor Information
Socket Designation: SOCKET 0
Type: Central Processor
Family: Celeron
Manufacturer: Intel
ID: C4 06 04 00 FF FB EB BF
Signature: Type 0, Family 6, Model 76, Stepping 4
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Celeron(R) CPU N3060 @ 1.60GHz
Voltage: 1.2 V
External Clock: 80 MHz
Max Speed: 2400 MHz
Current Speed: 1600 MHz
Status: Populated, Enabled
Upgrade: Socket BGA1155
L1 Cache Handle: 0x0036
L2 Cache Handle: 0x0037
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Fill By OEM
Part Number: Fill By OEM
Core Count: 2
Core Enabled: 2
Thread Count: 2
Characteristics:
64-bit capable
Handle 0x0039, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 1
en|US|iso8859-1
Currently Installed Language: en|US|iso8859-1
Handle 0x003B, DMI type 127, 4 bytes
End Of Table
MatheusAndrade
Thank you so much.
Concerning the BE200NGW, does it also hold the backwards compatibility, as the AX210NGW does?
Regards.
n_scott_pearson
It should, but I cannot attest to that at present. I have a module on order and should be able to update you later this week (I will be testing its backward compatibility with WiFi 5 and WiFi 6 routers).
MatheusAndrade
Thank you so much.
Vv10
Hello @n_scott_pearson
Have your tests been done successfully?
Can you please share the results?
n_scott_pearson
Sorry about that; been busy offline.
Anyway, I have the card mounted on card carrier and plugged into system with a 4th Gen./8 Series motherboard. It worked just fine with my WiFi6 routers. I still need to verify with an older WiFi5 router; will have to update about this (though I don't foresee any issues occurring).
I did have some problems with Bluetooth. I could not get my headphones to attach. I uninstalled the Bluetooth package (again), went into Device Manager and manually deleted all of the hidden entries for my headphones, rebooted, reinstalled the Bluetooth package and it connected fine after that.
n_scott_pearson
Ok, I tested with a AC750 WiFi5 Travel Router (5GHz band). Worked just fine.
n_scott_pearson
Ok, I tested with a AC750 WiFi5 Travel Router. Worked just fine.
