Wireless
8697 Discussions
Intel Dual Band Wireless-AC 8260 doesn't go to monitor mode
mrmojo
i need to use Wireshark to look at traffic in monitor mode but my wireless adapter doesn't seem to work in monitor mode. I use Ubuntu 20.04 and the kernel version is 5.11 and the wireless drive is iwlwifi. When i manually turn the monitor mode by
sudo iwconfig wlp2s0 mode monitor
 it automatically goes back to managed mode after few seconds
i have also set the module with amsdu_size=3 value as suggested by this page but it still doesn't work
JosueO_Intel
Hello mrmojo,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Was it working before? If so, when did the issue start happening?
  2. Is this a desktop or a laptop?
  3. Have tried using drivers by the OEM?
  4. Does the issue also occur on Windows*?
  5. Is this the original adapter of the system?
Josue O.
mrmojo
No it wasn't working before
It's a ThinkPad L380 laptop
No i haven't tried other drivers except iwlwifi which according to Linux Wireless Wiki is the driver for Intel Dual Band Wireless-AC 8265
I don't have windows so i have no idea
Yes it is the original adapter of the system
JosueO_Intel
Hello mrmojo,
Thank you for the information provided, it is important for you to know that the monitor mode support depends on the Linux driver. The command line '# iw list' will return what is and is not supported for his wireless card.
And check the following in the output:
Software interface modes (can always be added):
*AP/VLAN
*monitor
Also, our recommendation is to check directly with the Wi-Fi Linux community about setting up monitor mode.
Josue O.
mrmojo
the output of iw list does contain
*AP/VLAN
*monitor
JosueO_Intel
Hello mrmojo,
Thank you for the information provided, have you checked with the Wi-Fi Linux community for assistance setting up the monitor mode? Please let me know if their recommendations help you with the issue.
Josue O.
JosueO_Intel
Hello mrmojo,
Josue O.
JosueO_Intel
Hello mrmojo,
Josue O.
