Wireless
8664 Discussions
Intel PROSet Crashing PC
SDode1
I have an HP laptop with the Intel 7265 Wifi Adapter with the latest driver. I also had PROSet Wireless installed. For a while, my PC has been crashing often after the monitor automatically shuts down due to inactivity. I have tracked down the cause to the PROSet Wireless app. I uninstalled it and my PC works great now.
SDode1
Nevermind...it crashed again
AdrianM_Intel
Hello SDode1,
Thank you for posting on the Intel® communities
Please run the following tool and attach the report generated.
1. Intel® System Support Utility (Intel® SSU)
  • Intel® SSU Download link
  • Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
When did the behavior start? after updating the driver?
Adrian M.
AdrianM_Intel
Hello SDode1,
Were you able to check the previous post?
Adrian M.
SDode1
PROSet was not the problem. Thanks for the help, but it is no longer needed.
