Wireless
8875 Diskussionen
Intel(R) 6E AX211 160MHz - Very slow connection
hs123456
Anfänger
40.499Aufrufe
Good evening
I do have a problem with my new Laptop and the internet connection.
It has a Intel(R) 6E AX211 160MHz
The driver version is 22.160.0.4
If I do connect it directly to the router, it has a very slow download speed (see bild1).
However.. if I use my mobile phone as in-between, it works just fine (see bild2).
With my other Laptop, the direct connection is no problem.
What do I do wrong?
Thank you for your support.
19 Antworten
Jean_Intel
Mitarbeiter
40.472Aufrufe
Hello hs123456,
To have a better understanding of your issue, please provide me with the following:
  • Are you having issues with Wifi or Bluetooth or both?
  • What is the model of the laptop?
  • When did it start to happen?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Have you checked if this issue happens on different networks?
  • What do you mean by saying that you use a phone as an in-between?
Jean O.
hs123456
Anfänger
40.459Aufrufe
Thank you very much
I will try to answer your questions
Bluetooth works fine
ThinkPad P1 Gen 5
I got my laptop 3 days ago as a new product. The problem was there since the beginning.
It is the original one
I only have my home network -> so no I have not checked that
To see, if there was maybe a problem with the hardware, I tried to connect the laptop to my android phone (samsung galaxy s11) with the option "mobile hotspot".
Then I connected the laptop to the phone and the phone to the router. This works just fine.
But if I connect the laptop directly to the router, I do have a very slow download.
With my "old" Lenovo Laptop (same location in the flat), the direct connection to the router works fine.
Jean_Intel
Mitarbeiter
40.449Aufrufe
Hello hs123456,
Thanks for your response.
I want to confirm more information about the system, so please, provide me with the following:
  • Your Router model.
  • What are the expected network speed and the download speed you get when you use your new ThinkPad P1 Gen 5 laptop?
  • How are you using your phone as an in-between? Do you require to use an application to use both the hotspot and Wifi at the same time?
Please, make sure that you use the default and recommended settings for Intel® Wireless Adapters supporting 802.11n. To change these settings.
https://www.intel.sg/content/www/xa/en/support/articles/000005544/wireless.html
Also, I would like to request performing a clean installation of our Intel generic driver (22.160.0). Intel’s generic graphics drivers are intended for testing, and we recommend using drivers from your system manufacturer (OEM). If you want to try our driver, please follow these instructions:
• Download and save the driver https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html
• Disconnect the unit to the internet.
• Uninstall the Wi-Fi driver.
1. Go to Device Manager.
2. Expand the Network Adapters category.
3. Right-click your Intel Wireless Adapter and choose to uninstall it.
4. Make sure the option to Delete the driver software for this device is selected.
5. Repeat steps 1 through 4 until the option to Delete the driver software for this device is greyed out.
• Restart your computer.
• Install the driver downloaded before
Locate the driver you downloaded. Right-click the file you downloaded, and select the option to Run as administrator.
Jean O.
BillMann69
Einsteiger
39.621Aufrufe
I would love to hear an explanation as to the relevance of graphics driver to WiFi. From a hardware perspective, I can guarantee than within my Dell 9720, they are 2 very distinct components.
yet, despite multiple attempts, the 6E AX211 refuses to exceed 500 Mbps connecting to a default configured Xfinity (comcast) device.
Even my 5 y.o. Alienware (with Killer WiFi) manages almost twice that speed.
hs123456
Anfänger
40.434Aufrufe
Thank you for your answer and your time.
I would like to answer your questions:
Model: TWG870UG
Channel No 11
I tried a online speed test (on green.ch) with my old laptop (Lenovo, around 8 years old, Win 7, 8 GB Ram, Prozessor Intel (R) Core (TM) i7-4700MQ CPU 2.4GHz), Intel(R) Dual Band Wirlesss AC 7260
The speed test with my old laptop gave me:
- ping 12
- jitter 3
- Download 25 Mbps
- Upload 10 Mbps
With my Gen 5:
- ping 12
- jitter 24
- Download 1.9Mbps
- Upload 5 Mbps
No, I go directly by the Settings of the android phone
I will try to do the steps you mentioned above.
Also I will take the laptop Gen 5 to work with me next week and will try to run it over the general wi-fi net provided for the guest by my employer as well as over the internal net.
3Fees
Neuer Beitragender I
36.304Aufrufe
The TWG870 is a VoIP wireless cable router with four 10/100/1000Base-T LAN ports, one USB port and a two FXS ports for VoIP. It is DOCSIS / EuroDOCSIS 3.0 compliant and provides WAN throughput of up to 440Mbps.
Wireless
 Maximum Wireless Speed: 108 Mbps
 WiFi standards supported: 802.11b (Wi-Fi 1)
802.11g (Wi-Fi 3)
802.11n (draft)
 Wifi security/authentication: WEP
WPA (TKIP)
WPA2 (AES)
802.1X (EAP-MD5/TLS/TTLS/PEAP)
 WiFi modes: Access point
 internal antenna(s): 2
 WPS (Wi-Fi Protected Setup):
Get a better router.
Cheers
3Fees
Jean_Intel
Mitarbeiter
40.389Aufrufe
Hello hs123456,
I appreciate the information provided.
I want to wait to confirm the outcome of trying the clean installation of the wireless driver to check if the issue persists. Also, let me know if you face any problems when you try other networks.
Jean O.
Jean_Intel
Mitarbeiter
40.354Aufrufe
Hello hs123456,
I hope you are doing fine.
Jean O.
Jean_Intel
Mitarbeiter
40.315Aufrufe
Hello hs123456,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
Jean_Intel
Mitarbeiter
40.308Aufrufe
Hello hs123456
Based on the symptoms I would say that the issue is something at the Acess Point (AP) side and not the wireless card or driver, therefore, as our last recommendation, I advise checking with your AP Original Equipment Manufacturer (OEM) for firmware update and or further configuration.
Remember that the thread will be closed. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
3Fees
39.600Aufrufe
WPA-2 should be WPA-3 can change it * ,, on N band should be on AX band, N band is merely an enhancement of A band, AX band is enhancement of AC band, your router should have AX band checked marked in the router GUI on line, from there can adjust the bandwidth for the fastest download/upload speed- most wifi routers on line have a speed test in GUI so you can check your speed after the settings have been adjusted, the wifi router should have the latest firmware also. Windows 11 is optimized for wifi 6.
*The router is on wpa-2, change it to wpa 3 online 5 GHZ band, on the 2.4GHZ band change it wpa3 + wpa 2.
Cheers
3Fees
robinwilson16
Anfänger
36.323Aufrufe
I have experienced extremely slow speed with this specific wireless adaptor where other laptops in the same room are able to achieve reliable download speeds of 50MBits+ and upload of 8MBits this wireless adaptor achieves only about 20 down but then network activity can stop altogether and upload drops to 0.19MBits. The area is covered by various AX access points each on their own channel.
It doesn't matter if it is transfers from the local network or downloads from the internet.
Newer drivers made no difference and the only thing that worked was to disable the network adaptor and plug in a USB adaptor which gives comparable speeds to other devices. Even a TP-Link device for £12 resolves the issue but then uses up a USB port and sticks out.
Two devices from different manufacturers with the same network hardware as well as other devices I have tested exhibit exactly the same issue so I am now avoiding devices with this specific chipset as it makes the network barely usable. I have tested on other networks and it is the same.
The earlier AX201 does not have this issue but there appears to be something badly wrong with the AX211 and I would avoid it at all costs.
Does not work properly:
Intel(r) Wi-Fi 6E AX211 160MHz
Works properly:
Intel(R) Wi-Fi 6 AX201 160MHz
3Fees
36.304Aufrufe
What is the model of your router ?
Is it a Wifi-5, Wifi-6 or Wifi-6E router ?
AX211 is WiFi 6E card.
What speed is your cable connection ?
Cheers
3Fees
FabrizioFio
Einsteiger
30.712Aufrufe
3Fees
30.695Aufrufe
The Intel AX211 requires an Intel 600 Series Chipset or no go. The AX211 works with some laptops that have customized drivers and 13th Generation Processor, your mileage may vary.
Cheers
3Fees
Lenovo9iBookUser
Einsteiger
27.736Aufrufe
Has this issue been resolved because I am having the same issue. I'm using a Lenovo Yoga 9i Book with the Intel 6E AX211 Wi-Fi card. Immediately after startup the card works very fast, but within a minute it starts to get progressively slower to the point where it becomes almost unusable. The slow issue is the same whether using the Wi-Fi card for internet activities or just WLAN activities.
Cdarche
Anfänger
22.472Aufrufe
I just got a new Dell Inc. XPS 17 9730, 13th Gen Intel® Core™ i9-13900H, BIOS 1.11, running with Microsoft Windows 11 Pro (64-bit) vers: 23H2 (10.0.22631). The Intel® Wi-Fi 6E AX211 160MHz has also the latest pilot: 23.40.0.4.
The slowness of the link speed is noticed when moving few step away from the internet box. It drops from 866Mbps to 200Mbs to 0.
My other devices:  an notebook and a Samusung laptop have no such issue and they are not using Intel® Wi-Fi 6E AX211 160MHz. The Intel® Wi-Fi 6E AX211 160MHz is not working properly.
gabrielehpcw
Einsteiger
21.343Aufrufe
Same problem here, with a Intel(R) 6E AX211 160MHz on a laptop HP 17 cw0003nl, with i7 (13 generation) the quality of the signal received is very poor.
While on my old laptop the quality of the signal is ~95, on my new laptop with the Intel(R) 6E AX211 160MHz  quality of the signal is ~25 (almost 1/4 of the other laptop in the house).
this is very disappointing.
I have tried to install/uninstall the device, the driver (manually or trough windows update), NOTHING has changed!.
3Fees
21.311Aufrufe
What router are you using ? Wifi 5-AC, Wifi 6-AX, or Wifi 6E-AXE ? Intel AX211 is an AXE card and it tries to enable the 6 GHZ radio band through the latest Intel drivers for it, if it does not find it, it will not be a level playing field with AC or AX router. Its a cardinal rule that you match technologies for best results, it would be like using a USB 3 flash drive in a USB 2 slot, a downgrade in performance.
Cheers
3Fees
Antworten
