Wireless
9021 Discussions
Intel(R) Dual Band Wireless AC 7265 - Code 45
Leine13
This is the longest tome that my Dell computes cannt connect to the internet. Device status says hardware is not connected to the computer (code 45).
I do not understand why it happened. I have always been connected to the internet until few days ago when Network settings status says not connected.
Please help!
JosueO_Intel
Hello Leine13,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Were any changes made to the system before the issue started happening?
  2. Have you reported this issue to Dell?
  3. Is this a desktop or a laptop?
  4. Is this the original wireless adapter of the system?
  5. Have you checked if the adapter is properly connected?
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
Leine13
Thanks for your reply!
To answer all your questions:
1. Were any changes made to the system before the issue started happening? NO
2. Have you reported this issue to Dell? NO, the first thing I thought was to look for infos bout the Intel error until I saw this community.
3. Is this a desktop or a laptop? I’m using a laptop.
4. Is this the original wireless adapter of the system? It is the original wireless adapter of the system.
5. Have you checked if the adapter is properly connected? Sorry I didn’t know how to check for proper connection. I just saw the Intel (R) when I clicked the “show hidden device” as suggested to me. And there is a note that says Code 45.
Thank you!
Leine13
Will try to download and install the Intel System Support Utility (Intel SSU). Will send the necessary data when done. Thanks again!
JosueO_Intel
Hello Leine13,
Thank you for the information provided, we will wait for you to run the Intel® SSU and share with us the results.
Josue O.
JosueO_Intel
Hello Leine13,
Were you able to run the Intel® SSU?
Josue O.
JosueO_Intel
Hello Leine13,
Josue O.
