Wireless
9037 Discussions
Intel(R) Dual Band Wireless-AC 8260 Roaming Issue
We have been experiencing random drops from these devices. It appears that the devices are not roaming to new APs even though the quality has greatly reduced. I have tried various driver versions(18.40.0.9 & 19.10.4.1) and have tried changing the Roaming Aggressiveness. We have a multitude of other devices that do not experience this behavior. Any assistance would be appreciated. Thanks
Machine Details:
OS: Win 7 64
PC: model Dell Latitude E7270
WiFi Nic: Intel(R) Dual Band Wireless-AC 8260
Network Details:
Cisco 5508 controllers
3702i Access Points, (A, B, G, AC, N) bands in use
WPA2/AES, WPA/WPA2/PSK SSIDs
Hello Brian_Pie,
We understand you're having roaming issues on several systems using the Intel® Dual Band Wireless-AC 8260 on Windows* 7.
- Have you downloaded this drivers from our download center, or from your computer manufacturer's support site?
- If possible, download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility on one of the computers having this issue. Please run this tool while connected to one of your wireless networks.
- Have you engaged Dell* support in regards to this problem? If so, please share your service ticket number with us (let us know if you would like a private message to share this information).
We look forward to hearing back from you.
Carlos A.
Hello Brien_Pie,
We noticed you have your adapter set to HT mode, this disables 802.11ac limiting your adapter to 802.11n and legacy networks. If your access points use wireless-AC, this may prevent your adapter from roaming over as easily. Looking at your AP and wireless controllers, we can recommend using VHT Mode instead.
Our main suggestion will be to upgrade to our latest PROSet Wireless Software package version 19.60.0. This new release includes a driver update for your adapter which addresses roaming issues specifically.
- https://downloadcenter.intel.com/download/26784 Intel® PROSet/Wireless Software and Drivers for Windows 7* Version: 19.60.0 or
- https://downloadcenter.intel.com/download/26785 Intel® PROSet/Wireless Software and Drivers for IT Admins Version: 19.60.0 (in case you need to use a silent installation method).
Please let us know your results.
Carlos A.
Hello Brien_Pie,
We have not heard back from you in a while. Has your issue been resolved?
Carlos A.
