Wireless
8856 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz Errors
xhuan
I have Intel(R) Wi-Fi 6E AX211 160MHz on Windows 10, there are may errors in event viewer after upgrad driver to latest version (22.200.2.1).
any suggestion?
Error 2023/4/20 15:34:18 Netwtw12 5002 None
Intel(R) Wi-Fi 6E AX211 160MHz : Has determined that the network adapter is not functioning properly.
Error 2023/4/20 15:34:18 Netwtw12 5005 None
Intel(R) Wi-Fi 6E AX211 160MHz : Has encountered an internal error and has failed.
Warning 2023/4/20 15:25:36 Netwtw12 6062 None
The description for Event ID 6062 from source Netwtw12 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
Information 2023/4/20 15:25:35 Netwtw12 7021 None
The description for Event ID 7021 from source Netwtw12 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
DeividA_Intel
Hello xhuan,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX211.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Is this a laptop or desktop computer?
4. Do you see any errors in the device manager (code 10 or code 43)?
5. Are you having connection issues?
6. Are you having issues with the 2.4GHz band or also the 5GHz band?
Deivid A.
xhuan
original adapter
I didn't use bluetooth and keep it disabled
laptop
no
seems the internet connection do not have any problem
the router are configured to use only 2.4GHz band
DeividA_Intel
Hello xhuan,
Thanks for the confirmation. Before we continue further, I would like to confirm the following:
1. How do the errors affect the wireless performance?
2. Is the issue only related to the error and there are no problems with the computer?
3. Can you provide more details about the issue?
Deivid A.
xhuan
Hi Deivid,
The laptop randomly freeze and reboot, so I try to found the root cause from event viewer.
Currently there many warning and error from Netwtw12, I'm not sure if it causes the freeze and reboot problem but it's better to be fixed.
DeividA_Intel
Hello xhuan,
Thanks for your response. Based on your issue, please try the following:
1. Perform a clean install of the Intel driver:
2. Try the "Recommended Settings for 802.11ax Connectivity":
If the issue persists, I recommend you check this issue with the laptop manufacturer so they can run the tests needed on their device to confirm the root of the issue.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Sumanshu
Hi Team
Today on 27th July 2023, Suddenly the only the computer WiFi get disconnected and then I check there is no more WiFi options available.
I checked the device manager and it is showing
Intel(R) Wi-Fi 6 AX201 160 MHz has stopped working error code 43.
Then I uninstall the device and restarted the machine, so that it get installed fresh automatically.
Then I see the error
The device cannot start (code 10)
The requested operation was unsuccessful.
Could you please let us know the reason and fix.
