Wireless
8521 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz Ubuntu 24.04 loading Driver fails with error -110
Tismo
Recently my laptop (HP ZBook Fury 16 G10 Mobile) received an update of the firmware by HP (version 01.06.03 Rev.A).
After this update the driver for the WiFi fails to load and reports the following error:
$ sudo dmesg | grep iwlwifi
[  153.261680] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[  153.388943] iwlwifi 0000:00:14.3: CSR_RESET = 0x11
[  153.388949] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x0
[  153.388980] iwlwifi 0000:00:14.3:     value [iter 0]: 0x00000000
[  153.388983] iwlwifi 0000:00:14.3:     value [iter 1]: 0x00000000
[  153.389007] iwlwifi 0000:00:14.3:     value [iter 2]: 0x00000000
[  153.389011] iwlwifi 0000:00:14.3:     value [iter 3]: 0x00000000
[  153.389013] iwlwifi 0000:00:14.3:     value [iter 4]: 0x00000000
[  153.389016] iwlwifi 0000:00:14.3:     value [iter 5]: 0x00000000
[  153.389018] iwlwifi 0000:00:14.3:     value [iter 6]: 0x00000000
[  153.389020] iwlwifi 0000:00:14.3:     value [iter 7]: 0x00000000
[  153.389022] iwlwifi 0000:00:14.3:     value [iter 8]: 0x00000000
[  153.389024] iwlwifi 0000:00:14.3:     value [iter 9]: 0x00000000
[  153.389027] iwlwifi 0000:00:14.3:     value [iter 10]: 0x00000000
[  153.389029] iwlwifi 0000:00:14.3:     value [iter 11]: 0x00000000
[  153.389031] iwlwifi 0000:00:14.3:     value [iter 12]: 0x00000000
[  153.389033] iwlwifi 0000:00:14.3:     value [iter 13]: 0x00000000
[  153.389035] iwlwifi 0000:00:14.3:     value [iter 14]: 0x00000000
[  153.389036] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x1
[  153.389059] iwlwifi 0000:00:14.3:     value [iter 0]: 0x00000000
[  153.389061] iwlwifi 0000:00:14.3:     value [iter 1]: 0x00000000
[  153.389063] iwlwifi 0000:00:14.3:     value [iter 2]: 0x00000000
[  153.389065] iwlwifi 0000:00:14.3:     value [iter 3]: 0x00000000
[  153.389067] iwlwifi 0000:00:14.3:     value [iter 4]: 0x00000000
[  153.389070] iwlwifi 0000:00:14.3:     value [iter 5]: 0x00000000
[  153.389072] iwlwifi 0000:00:14.3:     value [iter 6]: 0x00000000
[  153.389074] iwlwifi 0000:00:14.3:     value [iter 7]: 0x00000000
[  153.389076] iwlwifi 0000:00:14.3:     value [iter 8]: 0x00000000
[  153.389078] iwlwifi 0000:00:14.3:     value [iter 9]: 0x00000000
[  153.389080] iwlwifi 0000:00:14.3:     value [iter 10]: 0x00000000
[  153.389082] iwlwifi 0000:00:14.3:     value [iter 11]: 0x00000000
[  153.389085] iwlwifi 0000:00:14.3:     value [iter 12]: 0x00000000
[  153.389087] iwlwifi 0000:00:14.3:     value [iter 13]: 0x00000000
[  153.389089] iwlwifi 0000:00:14.3:     value [iter 14]: 0x00000000
[  153.389090] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x6
[  153.389113] iwlwifi 0000:00:14.3:     value [iter 0]: 0x00000000
[  153.389115] iwlwifi 0000:00:14.3:     value [iter 1]: 0x00000000
[  153.389117] iwlwifi 0000:00:14.3:     value [iter 2]: 0x00000000
[  153.389119] iwlwifi 0000:00:14.3:     value [iter 3]: 0x00000000
[  153.389122] iwlwifi 0000:00:14.3:     value [iter 4]: 0x00000000
[  153.389124] iwlwifi 0000:00:14.3:     value [iter 5]: 0x00000000
[  153.389126] iwlwifi 0000:00:14.3:     value [iter 6]: 0x00000000
[  153.389128] iwlwifi 0000:00:14.3:     value [iter 7]: 0x00000000
[  153.389130] iwlwifi 0000:00:14.3:     value [iter 8]: 0x00000000
[  153.389133] iwlwifi 0000:00:14.3:     value [iter 9]: 0x00000000
[  153.389135] iwlwifi 0000:00:14.3:     value [iter 10]: 0x00000000
[  153.389137] iwlwifi 0000:00:14.3:     value [iter 11]: 0x00000000
[  153.389139] iwlwifi 0000:00:14.3:     value [iter 12]: 0x00000000
[  153.389142] iwlwifi 0000:00:14.3:     value [iter 13]: 0x00000000
[  153.389144] iwlwifi 0000:00:14.3:     value [iter 14]: 0x00000000
[  153.389145] iwlwifi 0000:00:14.3: Host monitor block 0x22 vector 0x0
[  153.389167] iwlwifi 0000:00:14.3:     value [iter 0]: 0x00000000
[  153.389196] iwlwifi: probe of 0000:00:14.3 failed with error -110
Can you help me to resolve this issue?
Some system information:
$ cat /etc/os-release
PRETTY_NAME="Ubuntu 24.04.1 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04.1 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logo
$ sudo lspci -nnk | grep -A2 0280
00:14.3 Network controller [0280]: Intel Corporation Raptor Lake-S PCH CNVi WiFi [8086:7a70] (rev 11)
	Subsystem: Intel Corporation WiFi 6E AX211 160MHz [8086:0090]
	Kernel modules: iwlwifi
$ uname -r
6.8.0-45-generic
Mike_Intel
Hello Tismo,
  1. When did you purchase this unit?
  2. Was it working fine before?
  3. Did you change any settings before the issue started?
  4. Did you upgrade the Wireless card or this is embedded in this system?
  5. Can you share link of the driver that you used?
Michael L.
Tismo
Hi Michael,
  1. The laptop was purchased at 2024-07-31
  2. Yes it was and within Windows 11 it is still working properly (the laptop is a dual boot with windows 11 and Ubuntu)
  3. No, changes to the settings, only a firmware upgrade was done and new drivers where installed on windows 11
  4. A firmware upgrade was done and new drivers where installed on windows 11
  5. https://ftp.hp.com/pub/softpaq/sp154001-154500/sp154263.exe (firmware update was done by windows itself in the update process but based upon the version I expected this to be the file used for it)
  6. The following version of the iwlwifi module is used:
$ modinfo iwlwifi | grep version
srcversion:     2553DA4DACB6342A2AD9180
vermagic:       6.8.0-47-generic SMP preempt mod_unload modversions
In the meantime I also tried different distributions of linux to see whether they correctly loaded the iwlwifi module but they didn't. I tried the following:
  • ubuntu-24.10-desktop-amd64
  • Fedora-Workstation-Live-x86_64-40-1.14
Let me know if you need more information.
Tismo
Wertun
Same Issue here. Intel(R) Wi-Fi 6E AX211 on Dell Precision 7680 with Ubuntu 24.04 with the latest updates
6.8.0-47-generic #47-Ubuntu
error: iwlwifi: probe of 0000:00:14.3 failed with error -110
Installed the firmware but failed
https://www.intel.com/content/www/us/en/download/824804/intel-wireless-wi-fi-drivers-for-linux.html
I have dual boot. Windows 11 works with the wifi card.
Mike_Intel
Hello Tismo,
Thank you for the update.
Let me gather these additional details about this one.
  1. My question before is did you install this AX211 to this laptop or this is the embedded/onboard wireless controller?
  2. Since it is working fine with Windows, that means that the wireless card is not faulty. Did you check with HP if the laptop is validated for Ubuntu?
  3. Can you share the link of the driver that you installed?
@Wertun
For us to further check your inquiry and configuration, please create a new thread. Thank you.
Michael L.
Tismo
Hi Michael,
  1. The wireless controller is onboard of the laptop.
  2. I didn't check this explicitly with HP, but I would expect it as they deliver a software package for it.
  3. I didn't install a specific driver yet so the driver which is included in Ubuntu 24.04 is used.
Do you mean I need to open a support case for further investigation?
Tismo
Anonymous
Not applicable
Hi all, here the same problem with Dell Latitude 5340 13" and 5440 14", Wifi working on Windows 11, using latest Ubuntu 24.04 and tested with 6.8.0-1014-oem and 6.8.0-47-generic with the same error, both laptops are certified for using with ubuntu. Please help!
uname -r
6.8.0-1014-oem
0000:00:14.3 Network controller [0280]: Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
Subsystem: Intel Corporation Wi-Fi 6E AX211 160MHz [8086:4090]
modinfo iwlwifi
filename: /lib/modules/6.8.0-1014-oem/ubuntu/iwlwifi/iwlwifi.ko.zst
version: iwlwifi-stack-public:master:11510:0106cce5
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
[ 18.222478] iwlwifi: probe of 0000:00:14.3 failed with error -110
Mike_Intel
Hello Tismo,
The instruction to create a new thread is for the other user who posted that he is having the same issue so that we can gather the specific details of his system.
As for your system, let me check. You mentioned that HP has a software package for this system for Ubuntu, does it include a driver for you to install?
And also, Intel has a generic driver that you can try as well. Here is the link:
@Anonymous
Michael L.
Mike_Intel
Hello Tismo,
Michael L.
Mike_Intel
Hello Tismo,
I am sending another follow up on the information that I requested.
Michael L.
