Wireless
8695 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz Ubuntu 24.04 loading Driver fails with error -110
Tismo
Hi, This continuation of this question: https://community.intel.com/t5/Wireless/Intel-R-Wi-Fi-6E-AX211-160MHz-Ubuntu-24-04-loading-Driver-fails/m-p/1639569#M56804 The last question was: https://community.intel.com/t5/Wireless/Intel-R-Wi-Fi-6E-AX211-160MHz-Ubuntu-24-04-loading-Driver-fails/m-p/1639569#M56804 I tried Ubuntu 24.10 which includes Linux Kernel 6.11 which should have the latest version of the drivers which was referred to on this page: https://www.intel.com/content/www/us/en/download/824804/intel-wireless-wi-fi-drivers-for-linux.html But Ubuntu 24.10 reports the same error. Help for this issue is much appreciated.
DeancR_Intel
Hi Tismo,
Thank you for posting in the Community!
This is an acknowledgement message for your inquiry, do please wait as this will be investigated internally to be able to provide a resolution to your request. I will get back to you once I have the necessary information.
Dean R.
DeancR_Intel
Hi Tismo,
Could you please check with your laptop's OEM to confirm if your system supports Linux OS?
If Linux OS is supported, please provide us with the firmware version and filename after installing the Linux driver core89 from Intel® Wireless Wi-Fi Drivers for Linux*.
Thank you for your cooperation!
Dean R.
DeancR_Intel
Hi Tismo,
Dean R.
Tismo
Hi Dean R.,
Thank you for having a look at this topic.
Linux is supported by the OEM on this laptop.
I still need to verify the firmware version and filename after installing core89.
I will get back to you asap.
Tismo
DeancR_Intel
Hi Tismo,
I appreciate your prompt response and understand that gathering the requested information can take time. Please take all the time you need.
If any questions arise or additional assistance is needed in the interim, feel free to reach out.
Dean R.
DeancR_Intel
Hi Tismo,
Dean R.
DeancR_Intel
Hi Tismo,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
