Hi Tismo,
Thank you for posting in the Community!
This is an acknowledgement message for your inquiry, do please wait as this will be investigated internally to be able to provide a resolution to your request. I will get back to you once I have the necessary information.
Dean R.
Hi Tismo,
Could you please check with your laptop's OEM to confirm if your system supports Linux OS?
If Linux OS is supported, please provide us with the firmware version and filename after installing the Linux driver core89 from Intel® Wireless Wi-Fi Drivers for Linux*.
Thank you for your cooperation!
Dean R.
Hi Tismo,
Dean R.
Hi Dean R.,
Thank you for having a look at this topic.
Linux is supported by the OEM on this laptop.
I still need to verify the firmware version and filename after installing core89.
I will get back to you asap.
Tismo
Hi Tismo,
I appreciate your prompt response and understand that gathering the requested information can take time. Please take all the time you need.
If any questions arise or additional assistance is needed in the interim, feel free to reach out.
Dean R.
Hi Tismo,
Dean R.
Hi Tismo,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
