Wireless
8695 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz card gets horrible Wifi speeds on my new Dell XPS 9520
Exflex
Hello,  I have spent more than 20 hours on the phone with Dell as well as having 2 motherboards replaced for my new Dell XPS 9520 laptop and they have been unable to resolve my wifi speed issue.  Dell blames my Google Mesh Wifi which gets me greater than 100mbps download AND upload on a 7 year old Dell Laptop I have as well as my 4 year old Ipad.  These connect via 5g.
The new Dell has the 6e capability but connects via my 5g router and typically gets only 6-10 mpbs download and .36 mbps upload speeds.  I have taken that laptop and my 7 year old laptop to Starbucks and other retail locations and the much older model gets significantly better wifi in those locations as well.
Dell has tried updating drivers, replacing motherboards, switching device settings, re-installing Windows 11 and the operating system.  Now they just give up and send me the same model as a replacement.  I am on my 3rd brand new Dell XPS 9520 laptop and they all work exactly the same.
Have others had this issue with this Dell configuration and the Intel wireless card I listed in the subject heading?
Please help!
Steven_Intel
Hello Exflex,
I am sorry you are having issues with your Intel® Wi-Fi 6E AX211, I will be glad to help.
Please perform the following steps:
Make sure to follow the clean installation instructions: https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html
Steven G.
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
Exflex
Before your initial response to my question, Dell and I decided to part as friends.  I had already returned their laptop and received a refund so I never got to try out your suggestion. I appreciate you answering my query though.  I can't be the only one who couldn't get the brand new laptop's wifi working past a crawl with Google mesh.
Steven_Intel
Thank you for letting us know you were able to solve this with Dell.
Since the thread is solved, we will proceed to close it now. Please keep in mind that this thread will no longer be monitored by Intel.
Steven G.
I_n_t_e_l_Master
Well, I have Intel(R) Wi-Fi 6E AX211 160MHz card on my new Dell XPS 9520 and still get horrible Wifi speeds. It sucks!
Afer starting my computer It's ok, but then after in bteween a few minutes of maybe two days internet speed drops downs, while my old laptops show still pefect internet speed. As there is a lot discussion online it I tried the following:
Without diving into the topic the Dell callcenter support quickly suggested to refresch my W11, which is ... just after setting up you new computer ...
As the issue seems to be common, I wonder if there is any other suggestions for quicker fix?
I_n_t_e_l_Master
Well after going through all the suggestions mentioned above, I reinstalled my W11, flashed the BIOS, got my motherboard replaced and still ... the wifi speed is dropping randomly to levels beyond usability.
I continuously run speed tests to take record of it, see the attached image how bad it can get while other laptops work just fine.
What's next? May try to replace the Intel(R) Wi-Fi 6E AX211 160MHz card with some other model?
Any suggestions?
