Wireless
8506 Discusiones
Intel(R) Wi-Fi 6E AX211 160MHz internet drop (Netwtw14) Event ID 5010
Anonymous
No aplicable
12.148 Vistas
Since yesterday, my wifi card Intel AX211 keep internet dropping and slowing.
I tried clean installation and downland latest driver 23.20.0 but i have the same problem and the rollback 22.240.0 have exactly the same problem too
My final soluce for AX211 is 22.80.1.1 is working fine.
This ID 5010 keep internet drop.
This original intel keep and slowing internet connection with ID 5010 (Netwtw14)
My patch without or almost connection dropping (Netwtw12)
This stable driver with none error (Netwtw10)
My last question, uninstall all versions drivers before installing intel for admnistrator ?
0 kudos
7 Respuestas
VonM_Intel
Moderador
12.073 Vistas
Hi, Anonymous.
Thank you for posting in our Intel communities.
I understand that you are having issues with the Intel Wifi Card, AX211. I would like to know some information about your system including the wireless/network settings and the wireless software configuration to help you. Please run the SSU report so that I can check for some important details. It would be a great help if you could provide us with the following information:
  • Is the issue happening at home, office environment, or both?
  • Have you checked if this issue happens on different networks?
  • Have you modified any WiFi adapter settings before the issue appears?
In line with your internet that is dropping and slowing, you may check this article/link: (https://www.intel.com/content/www/us/en/support/articles/000005493/wireless.html), where you can find some quick checks to improve or fix Wi-Fi connection issues. I've checked this article/link, (https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html), and opened the release notes, (Release Notes (ReleaseNotes_WiFi_23.20.0.pdf)), I found that on some systems, Windows System Event ID 5002 and 5010 might occur after resuming from Standby/ Hibernate/ Restart mode. Please know, however, that this software release version 23.20.0 has been updated to include functional and security updates. There may be other minor issues addressed that will impact performance, stability, or vendor-specific functionality not listed above. Users should update to the latest version.
Moreover, regarding the uninstallation of all driver versions before installing intel for administrator, you may refer to this link: (https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html), you will see here on how to perform clean installation of wireless drivers
Von M.
jams
Principiante
7.891 Vistas
I am still facing similar issue with driver- 23.40.1.1.......wifi logo goes off . I am also not able to see the intel adapter in device manager > network adapter .
I am having thinkpadx1
Let me know if this know issue and still no solution to it.
VonM_Intel
Moderador
11.961 Vistas
Hi, Anonymous.
I trust you're doing well.
I have not heard back from you we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
fforcezero
Novato
10.654 Vistas
I have th exact same issue as you but the support from Intel has been terrible so far: they just suggest to update my computer rather than fixing their buggy drivers.
fforcezero
Novato
7.304 Vistas
Yes. Intel support is terrible. I'm sure they are aware of the problem but it doesn't seems to be a priority for them to fix.
Babylon87
Principiante
7.688 Vistas
Hello everyone I get the following error every few seconds in my event viewer on my PC with Windows 11: Inter® Wi-Fi 6E AX210 160MHz: The network adapter returned an invalid value to the driver When wireless mode is set to 802.11ac in Intel driver in Windows 11, I don't get any error. I use the latest Intel driver version: 23.70.2. I used Intel's recommended settings: Recommended Settings for 802.11ax Connections (intel.de) Windows 11 completely reinstalled.
VARADHARAJAN
Colaborador Valioso II
7.670 Vistas
@Babylon87
Intel® Wi-Fi 6E AX211 160MHz, currently I am using Realtek Ethernet lan,  but I settled in advanced
802.11a/b/g Wireless mode to Dual band 802.11a/b/g
802.11n/ac/ax Wireless mode to 802.11ax
No errors
Varadharajan K
Responder
