Wireless
8851 Discussions
Intel(R) Wi-Fi 7 BE201 320MHz WPA3 SUITE-B Authentication not showing supported in Win 11 ENT 25H2
WiFiProblems
New User
netsh wlan show wirelesscapabilities shows WPA3 SUITE-B Authentication is Not Supported
netsh wlan show drivers
Interface name: WiFi
    Driver                    : Intel(R) Wi-Fi 7 BE201 320MHz
    Vendor                    : Intel Corporation
    Provider                  : Intel
    Date                      : 03/03/2026
    Version                   : 24.30.1.1
    INF file                  : oem613.inf
    Type                      : Native Wi-Fi Driver
    Radio types supported     : 802.11b 802.11g 802.11n 802.11a 802.11ac 802.11ax
    FIPS 140 mode supported   : Yes
    802.11w Management Frame Protection supported : Yes
    Hosted network supported  : No
    Authentication and cipher supported in infrastructure mode:
                                Open             None
                                Open             WEP-40bit
                                Open             WEP-104bit
                                Open             WEP
                                WPA-Enterprise   TKIP
                                WPA-Enterprise   CCMP
                                WPA-Personal     TKIP
                                WPA-Personal     CCMP
                                WPA2-Enterprise  TKIP
                                WPA2-Enterprise  CCMP
                                WPA2-Personal    TKIP
                                WPA2-Personal    CCMP
                                Open             Vendor defined
                                WPA3-Personal    CCMP
                                WPA3-Personal    GCMP-256
                                Vendor defined   Vendor defined
                                WPA3-Enterprise 192 Bits GCMP-256
                                OWE              CCMP
                                OWE              GCMP-256
                                WPA3-Enterprise  CCMP
    Number of supported bands : 3
                                2.4 GHz [ 2412 MHz - 2472 MHz]
                                5 GHz [ 5180 MHz - 5885 MHz]
                                6 GHz [ 5955 MHz - 7115 MHz]
    IHV service present       : Yes
    IHV adapter OUI           : [00 00 00], type: [00]
    IHV extensibility DLL path: C:\WINDOWS\System32\DriverStore\FileRepository\netwtw6e.inf_amd64_b0dac78beff3ae84\IntelIHVRouter18.dll
    IHV UI extensibility ClSID: {00000000-0000-0000-0000-000000000000}
    IHV diagnostics CLSID     : {00000000-0000-0000-0000-000000000000}
    Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
Wireless System Capabilities
    Number of antennas connected to the 802.11 radio (value not available)
    Max number of channels the device can operate on, simultaneously (value not available)
    Co-existence Support                        : Unknown
Wireless Device Capabilities
    WDI Version (Windows)                       : 0.2.0.14
    WDI Version (IHV)                           : 0.2.0.13
    WiFiCx Version (Windows)                    : 1.2
    WiFiCx Version (IHV)                        : 1.2
    WiFiCx Framework Type                       : KMDF
    Firmware Version                            : 76.D8
    Station                                     : Supported
    Soft AP                                     : Not supported
    Network monitor mode                        : Not supported
    Wi-Fi Direct Device                         : Supported
    Wi-Fi Direct GO                             : Supported
    Wi-Fi Direct Client                         : Supported
    Protected Management Frames                 : Supported
    DOT11k neighbor report                      : Supported
    ANQP Service Information Discovery          : Supported
    Action Frame                                : Supported
    Diversity Antenna                           : Unknown
    IBSS                                        : Not Supported
    Promiscuous Mode                            : Not Supported
    P2P Device Discovery                        : Supported
    P2P Service Name Discovery                  : Supported
    P2P Service Info Discovery                  : Not Supported
    P2P Background Discovery                    : Supported
    P2P GO on 5 GHz                             : Supported
    P2P GO on 6 GHz                             : Supported
    P2P Sae on GO                               : Supported
    ASP 2.0 Service Name Discovery              : Not Supported
    ASP 2.0 Service Information Discovery       : Not Supported
    IP Docking Capable                          : Not Supported
    Host FIPS Mode                              : Supported
    Instant Connect                             : Supported
    Dx Standby NLO                              : Supported
    Extended Channel Switch Announcement        : Supported
    Function Level Reset                        : Not Supported
    Platform Level Reset                        : Supported
    Bus Level Reset                             : Supported
    MAC Randomization                           : Supported
    Fast Transition                             : Supported
    MU-MIMO                                     : Supported
    Miracast Sink                               : Supported
    BSS Transition (802.11v)                    : Supported
    IHV Extensibility Module Configured         : Supported
    SAE Authentication                          : Supported
    SAE Hash-to-Element Authentication          : Supported
    WPA3 SUITE-B Authentication                 : Not Supported
    OWE Authentication                          : Supported
    FTM as Initiator                            : Not Supported
    MBO Support                                 : Supported
    Number of Tx Spatial Streams                : 2
    Number of Rx Spatial Streams                : 2
    Number of Concurrent Channels Supported     : 0
    Number of Radios                            : 1
    P2P GO ports count                          : 1
    P2P Clients Port Count                      : 1
    P2P Max Mobile AP Clients                   : 8
    Max ANQP Service Advertisements Supported   : 0
    Maximum Number of Secondary STAs Supported  : 0
    Number of MLO Connections Supported         : 4
    Wi-Fi 7 Enterprise                          : Supported
    QoS MSCS Supported                          : Supported
    QoS DSCP to UP Mapping Supported            : Supported
    Max Number of Wake on Incoming Action Frame Patterns Supported: 2
    Wpa3-Sae with 384-bit Pmk Supported         : Supported
    Cross Akm/Cipher Roaming                    : Supported
    Co-existence Support                        : Wi-Fi performance is maintained
Goutham_intel
Hello WiFiProblems,
We understand that you are experiencing an issue where WPA3 Suite-B Authentication is showing as not supported on your system.
To help us investigate further, we kindly request you to try the troubleshooting steps below and share the results with us:
Verify the output of netsh wlan show wirelesscapabilities and confirm if WPA3 Suite-B is listed under supported authentication types
Check if any Group Policy (GPO) or security policy related to WPA3 or FIPS is enabled on the system
Confirm whether FIPS mode is enabled in the system security settings or registry
Validate the Wi-Fi profile configuration (especially if it is using WPA3-Enterprise with Suite-B 192-bit security)
If possible, test the connection with a standard WPA3-Enterprise network (without Suite-B requirement) for comparison
Once you have reviewed the above steps, kindly share the outputs and observations with us. This will help us isolate whether the behavior is related to system configuration, network policy, or platform limitations.
We appreciate your cooperation and look forward to your update.
Goutham
Intel customer support technician
Subhankar_Intel
Hello WiFiProblems,
I hope you’re doing well.
We wanted to check if you were able to carry out the troubleshooting steps suggested in our previous message. If so, could you please share the outcome?
We look forward to your response.
Subhankar
Chawan_Intel
Hello WiFiProblems,
I hope you are doing well.
Thank you for sharing the network diagnostic information.
After reviewing the netsh WLAN report, we observed that WPA3-Suite B authentication is not supported on the current configuration. However, we can confirm that WPA3-Enterprise is supported on the Intel wireless adapter in use.
For your reference, Intel provides detailed information on WPA3 support across different modes in the following article:
Support for Wi-Fi Protected Access 3 (WPA3) on Intel® Wireless...
Based on this behavior, the limitation is expected and depends on the specific WPA3 security mode configured on the access point and client compatibility.
We recommend ensuring that the access point is configured to use WPA3-Enterprise (or mixed WPA2/WPA3 mode if required) for compatibility with the Intel wireless adapter.
Please let us know if you need further assistance or if the issue persists after validating the configuration.
We appreciate your understanding and co-operation throughout the process.
Thank you for being a valued customer of Intel.
Best Regards
Chawan
Chawan_Intel
Hello WiFiProblems,
This is a follow-up regarding the WPA3 compatibility discussion, and the network diagnostic results shared earlier.
We had observed that WPA3-Suite B authentication is not supported on the current configuration; however, the Intel wireless adapter does support WPA3-Enterprise. As mentioned, this behavior is expected based on the security mode configured on the access point and client compatibility.
We recommended ensuring that the access point is configured to use WPA3-Enterprise or WPA2/WPA3 mixed mode, depending on your network setup.
Could you please confirm if you were able to check or update the access point configuration? If the issue is still being observed after these changes, kindly share the latest details so we can assist you further.
We look forward to your response and are happy to help if you need any further assistance.
Thank you for your cooperation.
Best Regards
Chawan
Chawan_Intel
Hello WiFiProblems,
This is a follow-up regarding the WPA3 compatibility discussion and the network diagnostic results shared earlier.
As we have not received any update after the previous communication, I will proceed with closing this case for now.
Please note that you may always open a new support thread if further assistance is required, and we will be happy to help you.
We look forward to your response and are happy to assist if you need any further support.
Best Regards
Chawan
