netsh wlan show wirelesscapabilities shows WPA3 SUITE-B Authentication is Not Supported
netsh wlan show drivers
Interface name: WiFi
Driver : Intel(R) Wi-Fi 7 BE201 320MHz
Vendor : Intel Corporation
Provider : Intel
Date : 03/03/2026
Version : 24.30.1.1
INF file : oem613.inf
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n 802.11a 802.11ac 802.11ax
FIPS 140 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : No
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
WPA3-Personal CCMP
WPA3-Personal GCMP-256
Vendor defined Vendor defined
WPA3-Enterprise 192 Bits GCMP-256
OWE CCMP
OWE GCMP-256
WPA3-Enterprise CCMP
Number of supported bands : 3
2.4 GHz [ 2412 MHz - 2472 MHz]
5 GHz [ 5180 MHz - 5885 MHz]
6 GHz [ 5955 MHz - 7115 MHz]
IHV service present : Yes
IHV adapter OUI : [00 00 00], type: [00]
IHV extensibility DLL path: C:\WINDOWS\System32\DriverStore\FileRepository\netwtw6e.inf_amd64_b0dac78beff3ae84\IntelIHVRouter18.dll
IHV UI extensibility ClSID: {00000000-0000-0000-0000-000000000000}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)Wireless System Capabilities
Number of antennas connected to the 802.11 radio (value not available)
Max number of channels the device can operate on, simultaneously (value not available)
Co-existence Support : Unknown
Wireless Device Capabilities
WDI Version (Windows) : 0.2.0.14
WDI Version (IHV) : 0.2.0.13
WiFiCx Version (Windows) : 1.2
WiFiCx Version (IHV) : 1.2
WiFiCx Framework Type : KMDF
Firmware Version : 76.D8
Station : Supported
Soft AP : Not supported
Network monitor mode : Not supported
Wi-Fi Direct Device : Supported
Wi-Fi Direct GO : Supported
Wi-Fi Direct Client : Supported
Protected Management Frames : Supported
DOT11k neighbor report : Supported
ANQP Service Information Discovery : Supported
Action Frame : Supported
Diversity Antenna : Unknown
IBSS : Not Supported
Promiscuous Mode : Not Supported
P2P Device Discovery : Supported
P2P Service Name Discovery : Supported
P2P Service Info Discovery : Not Supported
P2P Background Discovery : Supported
P2P GO on 5 GHz : Supported
P2P GO on 6 GHz : Supported
P2P Sae on GO : Supported
ASP 2.0 Service Name Discovery : Not Supported
ASP 2.0 Service Information Discovery : Not Supported
IP Docking Capable : Not Supported
Host FIPS Mode : Supported
Instant Connect : Supported
Dx Standby NLO : Supported
Extended Channel Switch Announcement : Supported
Function Level Reset : Not Supported
Platform Level Reset : Supported
Bus Level Reset : Supported
MAC Randomization : Supported
Fast Transition : Supported
MU-MIMO : Supported
Miracast Sink : Supported
BSS Transition (802.11v) : Supported
IHV Extensibility Module Configured : Supported
SAE Authentication : Supported
SAE Hash-to-Element Authentication : Supported
WPA3 SUITE-B Authentication : Not Supported
OWE Authentication : Supported
FTM as Initiator : Not Supported
MBO Support : Supported
Number of Tx Spatial Streams : 2
Number of Rx Spatial Streams : 2
Number of Concurrent Channels Supported : 0
Number of Radios : 1
P2P GO ports count : 1
P2P Clients Port Count : 1
P2P Max Mobile AP Clients : 8
Max ANQP Service Advertisements Supported : 0
Maximum Number of Secondary STAs Supported : 0
Number of MLO Connections Supported : 4
Wi-Fi 7 Enterprise : Supported
QoS MSCS Supported : Supported
QoS DSCP to UP Mapping Supported : Supported
Max Number of Wake on Incoming Action Frame Patterns Supported: 2
Wpa3-Sae with 384-bit Pmk Supported : Supported
Cross Akm/Cipher Roaming : Supported
Co-existence Support : Wi-Fi performance is maintained- Dell Pro 14 Plus
- Embedded to the system.
- I have installed the driver from the intel website version 24.30.1 (Intel® Wireless Wi-Fi Drivers for Windows® 10 and Windows 11*) and cold booted afterwards (Remove battery, hold down power etc...)
- SSU attached
Hello WiFiProblems,
We understand that you are experiencing an issue where WPA3 Suite-B Authentication is showing as not supported on your system.
To help us investigate further, we kindly request you to try the troubleshooting steps below and share the results with us:
Verify the output of netsh wlan show wirelesscapabilities and confirm if WPA3 Suite-B is listed under supported authentication types
Check if any Group Policy (GPO) or security policy related to WPA3 or FIPS is enabled on the system
Confirm whether FIPS mode is enabled in the system security settings or registry
Validate the Wi-Fi profile configuration (especially if it is using WPA3-Enterprise with Suite-B 192-bit security)
If possible, test the connection with a standard WPA3-Enterprise network (without Suite-B requirement) for comparison
Once you have reviewed the above steps, kindly share the outputs and observations with us. This will help us isolate whether the behavior is related to system configuration, network policy, or platform limitations.
We appreciate your cooperation and look forward to your update.
Goutham
Intel customer support technician
Hello WiFiProblems,
I hope you’re doing well.
We wanted to check if you were able to carry out the troubleshooting steps suggested in our previous message. If so, could you please share the outcome?
We look forward to your response.
Subhankar
Hello WiFiProblems,
I hope you are doing well.
Thank you for sharing the network diagnostic information.
After reviewing the netsh WLAN report, we observed that WPA3-Suite B authentication is not supported on the current configuration. However, we can confirm that WPA3-Enterprise is supported on the Intel wireless adapter in use.
For your reference, Intel provides detailed information on WPA3 support across different modes in the following article:
Support for Wi-Fi Protected Access 3 (WPA3) on Intel® Wireless...
Based on this behavior, the limitation is expected and depends on the specific WPA3 security mode configured on the access point and client compatibility.
We recommend ensuring that the access point is configured to use WPA3-Enterprise (or mixed WPA2/WPA3 mode if required) for compatibility with the Intel wireless adapter.
Please let us know if you need further assistance or if the issue persists after validating the configuration.
We appreciate your understanding and co-operation throughout the process.
Thank you for being a valued customer of Intel.
Best Regards
Chawan
Hello WiFiProblems,
This is a follow-up regarding the WPA3 compatibility discussion, and the network diagnostic results shared earlier.
We had observed that WPA3-Suite B authentication is not supported on the current configuration; however, the Intel wireless adapter does support WPA3-Enterprise. As mentioned, this behavior is expected based on the security mode configured on the access point and client compatibility.
We recommended ensuring that the access point is configured to use WPA3-Enterprise or WPA2/WPA3 mixed mode, depending on your network setup.
Could you please confirm if you were able to check or update the access point configuration? If the issue is still being observed after these changes, kindly share the latest details so we can assist you further.
We look forward to your response and are happy to help if you need any further assistance.
Thank you for your cooperation.
Best Regards
Chawan
Hello WiFiProblems,
This is a follow-up regarding the WPA3 compatibility discussion and the network diagnostic results shared earlier.
As we have not received any update after the previous communication, I will proceed with closing this case for now.
Please note that you may always open a new support thread if further assistance is required, and we will be happy to help you.
We look forward to your response and are happy to assist if you need any further support.
Best Regards
Chawan
