Wireless
8623 Discussions
Intel(R) Wireless-AC 9560 160MHz won't work well when dual-booting windows and ubuntu
ITome1
Just installed newest windows driver from intel's website. when restarting windows, and booting to ubuntu everything goes well.
but when shutting down windows and then booting to ubuntu, I get the message "no wifi adapter found"
AskUbuntu suggest the windows driver does not release the hardware
LeonWaksman
  1. If you have a dual-boot machine with a recent version of Windows and start seeing problems during initialization of the WiFi device when booting Linux, the problem could be due to the “fast startup” feature on Windows. With this feature enabled, Windows don't really shut down the entire system, but leaves things partially running so you can start the machine faster again. Try to disable this option, on Windows 10 it should be in “Control Panel→Hardware and Sound→Power Options→System Settings”, then disable the “Fast Startup” option in “Shutdown Settings”. This will cause Windows to fully shutdown and may solve the issue.
  2. Please also see here https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
Leon
