Wireless
8700 Discussions
Intel(R) wi-fi 6 AX201 160MGZ Access Point Scan Problem
jspark
Débutant
5 642 Visites
I used Intel(R) wi-fi 6 AX201 for scanning Access Point by WlanScan() api in wlanapi.dll
like below
WlanScan(client.clientHandle, info.interfaceGuid, IntPtr.Zero, IntPtr.Zero, IntPtr.Zero);
And I got the WlanNotificationCodeAcm.ScanComplete
then I called WlanGetAvailableNetworkList api in wlanapi.dll
like below
WlanGetAvailableNetworkList(client.clientHandle, info.interfaceGuid, flags, IntPtr.Zero, out availNetListPtr);
But the availableNetworkList were wrong.
Because some of access point change it's mode to station.
But the WlanGetAvailableNetworkList include SSID that changed from Soft AP to Station.
This phenomenon occur in Intel(R) wi-fi 6 AX201.
When I used netgear usb type WLAN for scanning access point that didn't contain SSID that changed from SoftAP to Station.
And I tried to update driver to 20.60.0.6 but this version also happen too.
Please help me how to solve this problem. I also remove AP network profile but it doesn't help.
WlanDeleteProfile(client.clientHandle, info.interfaceGuid, profileName, IntPtr.Zero);
Does it have any duration keeping the result of scanning?
If that how can I modify this value??
Please help me.
0 Compliments
12 Réponses
David_G_Intel
Modérateur
5 607 Visites
Hello jspark
Thank you for posting on the Intel️® communities. Please share with us more information of your current setup and the Intel® System Support Utility (Intel® SSU) results:
David G
0 Compliments
jspark
Débutant
5 602 Visites
Dear David G.
Thanks for your reply.
I attached SSU result.
Sincerely yours.
0 Compliments
David_G_Intel
Modérateur
5 583 Visites
Thank you for the information provided. We are currently working on this request, the updates will be posted on the thread.
David G
0 Compliments
David_G_Intel
Modérateur
5 550 Visites
@jspark, Windows* 10 LTSB/LTSC editions usually have restrictions that may limit the troubleshooting we can provide. Please share with us the following:
  • What happens if you scan other APs networks? Is this happening to any other APs?
  • Besides the networking list, are you able to connect and use your Wifi as expected?
  • Does this happen with a non-LTSB/LTSC Windows 10* version?
David G
0 Compliments
David_G_Intel
Modérateur
5 531 Visites
David G.
0 Compliments
jspark
Débutant
5 506 Visites
Dear David
> All same. Even if AP is off, it is maintanined in the list about 2 minute.
> No. It can not connected.
> I'm not sure about it. The test environment cannot be changed.
   The netgear AC1200 wifi USB adapter works correctly. When the ap turned off the AP list will be clear immediately in same environment.
0 Compliments
jspark
Débutant
5 470 Visites
The result of additional test
> The window 10 enterprise version occurred this issue too. So I think it is not window 10 LTSB/LTSC problem.
0 Compliments
n_scott_pearson
Super utilisateur
5 457 Visites
No, you missed the point. It is an issue of age. Did you test with a release of Windows that is no older than 2004 (i.e. the Spring 2020 update)?
0 Compliments
jspark
Débutant
5 399 Visites
I can't test previous because I'm not home user. I make some equipment that operated by window 10.
0 Compliments
David_G_Intel
Modérateur
5 415 Visites
Did you check Scott's previous post?
David G.
0 Compliments
David_G_Intel
Modérateur
5 310 Visites
David G
0 Compliments
David_G_Intel
Modérateur
5 284 Visites
Hello @jspark
Based on symptoms, information, and troubleshooting performed, it is necessary to reseat the wireless card and also check the physical components. Please contact the system manufacturer for guidance and additional troubleshooting steps.
David G
0 Compliments
Répondre
